01-24-2018 11:27 AM
After testing in Advanced Capture, the log file produced states it will need manual indexing and instead of continuing onto the Commit folder, it ends up in Awaiting Index. I'm assuming it's because the AFKW sets didn't expand. It says there are multiple instances for same primary value. How do I correct this? I've poked around and can't find the settings.
>>Context Completion: no autofill keyword set(s) expanded on document
>>Context Completion: one or more autofill keyword sets failed to expand due to multiple instances for same primary value
>>Context Completion: document needs manual indexing - document type assigned = YES, all required keywords present = YES, suspect field count = 0, autofill expansion failure = YES, form requires index = NO
Thanks.
Chris
01-24-2022 01:54 PM
3 years later I have the same issues that no one seems to know the answer to. Any help would be appreciated. We just upgraded to EP5. This was not an issue in ver 18
