12-01-2017 04:25 PM
I'm using the API to write a series of documents to OnBase using the Unity API. In some cases I have to go back an add keywords to the newly created documents because they were unknown at the beginning of the process. The keywords are getting added correctly, however the AutoName string on the Document does NOT get updated?
Here's the code I'm using to make the change:
using (DocumentLock docLock = PackageDoc.LockDocument())
if (docLock.Status == DocumentLockStatus.LockObtained)
KeywordModifier MemberNoKWModifier = PackageDoc.CreateKeywordModifier();
MemberNoKWModifier.AddKeyword(MemberNoKW);
MemberNoKWModifier.ApplyChanges();
Is there something I need to do after the ApplyChanges() or an option I need to set before ApplyChanges() that would affect an update to the AutoName string?
Thanks!
Brett Booz
Systems Analyst
Spokane Teachers Credit Union (STCU)
12-19-2017 10:48 AM
