Problems using Alfresco 2.9 on Ubuntu VPS!! Please help
rscheele
I have been trying to install the very latest Alfresco 2.9 on an VPS Server with Ubuntu Linux 7.10 and 128 MB of garanteed RAM
using http://wiki.alfresco.com/wiki/Installing_Alfresco_on_Ubuntu_7.10
Im getting a time-out when connecting to http://alfresco.xlshosting.nl:8080/alfresco
Can some-one please assist?? If you pm me a can give you root access, if you're willing to help me.
root@alfresco:~# sudo /etc/init.d/alfresco start
Starting OpenOffice service …
Setting up iptables …
Redirecting port 21 to 2021 (tcp)
Bad argument `tcp'
Try `iptables -h' or 'iptables –help' for more information.
Bad argument `tcp'
Redirecting port 445 to 1445 (tcp)
Bad argument `tcp'
Bad argument `tcp'
Redirecting port 139 to 1139 (tcp)
Bad argument `tcp'
Bad argument `tcp'
Redirecting port 137 to 1137 (udp)
Bad argument `udp'
Bad argument `udp'
Redirecting port 138 to 1138 (udp)
Bad argument `udp'
Bad argument `udp'
Starting Alfresco …
Using CATALINA_BASE:   /opt/alfresco/tomcat
Using CATALINA_HOME:   /opt/alfresco/tomcat
Using CATALINA_TMPDIR: /opt/alfresco/tomcat/temp
Using JRE_HOME:       /usr/lib/jvm/java-6-sun-1.6.0.03
root@alfresco:~# I18N: Operating system doesn't support locale "en_US"
Mar 4, 2008 8:10:35 AM org.apache.catalina.startup.Catalina stopServer
SEVERE: Catalina.stop:
java.net.ConnectException: Connection refused
   at java.net.PlainSocketImpl.socketConnect(Native Method)
   at java.net.PlainSocketImpl.doConnect(PlainSocketImpl.java:333)
   at java.net.PlainSocketImpl.connectToAddress(PlainSocketImpl.java:195)
   at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:182)
   at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:366)
   at java.net.Socket.connect(Socket.java:519)
   at java.net.Socket.connect(Socket.java:469)
   at java.net.Socket.<init>(Socket.java:366)
   at java.net.Socket.<init>(Socket.java:180)
   at org.apache.catalina.startup.Catalina.stopServer(Catalina.java:395)
   at org.apache.catalina.startup.Bootstrap.stopServer(Bootstrap.java:344)
   at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:435)
Mar 4, 2008 8:10:49 AM org.apache.coyote.http11.Http11BaseProtocol init
Mar 4, 2008 8:10:49 AM org.apache.catalina.startup.Catalina load
INFO: Initialization processed in 5190 ms
Mar 4, 2008 8:10:50 AM org.apache.catalina.core.StandardService start
Mar 4, 2008 8:10:50 AM org.apache.catalina.core.StandardEngine start
INFO: Starting Servlet Engine: Apache Tomcat/5.5.23
Mar 4, 2008 8:10:51 AM org.apache.catalina.core.StandardHost start
INFO: XML validation disabled
Mar 4, 2008 8:10:52 AM org.apache.catalina.startup.HostConfig deployWAR
Mar 4, 2008 8:39:41 AM org.apache.catalina.startup.Catalina stopServer
Mar 4, 2008 8:42:02 AM org.apache.coyote.http11.Http11BaseProtocol init
Mar 4, 2008 8:42:06 AM org.apache.catalina.startup.Catalina load
INFO: Initialization processed in 13950 ms
Mar 4, 2008 8:42:11 AM org.apache.catalina.core.StandardService start
Mar 4, 2008 8:42:11 AM org.apache.catalina.core.StandardEngine start
Mar 4, 2008 8:42:11 AM org.apache.catalina.core.StandardHost start
Mar 4, 2008 8:42:23 AM org.apache.catalina.startup.HostConfig deployWAR
Mar 4, 2008 8:56:20 AM org.apache.catalina.startup.Catalina stopServer
Mar 4, 2008 8:57:00 AM org.apache.coyote.http11.Http11BaseProtocol init
Mar 4, 2008 8:57:00 AM org.apache.catalina.startup.Catalina load
INFO: Initialization processed in 1929 ms
Mar 4, 2008 8:57:00 AM org.apache.catalina.core.StandardService start
Mar 4, 2008 8:57:00 AM org.apache.catalina.core.StandardEngine start
Mar 4, 2008 8:57:00 AM org.apache.catalina.core.StandardHost start
Mar 4, 2008 8:57:02 AM org.apache.catalina.startup.HostConfig deployWAR
Mar 4, 2008 9:05:09 AM org.apache.catalina.startup.Catalina stopServer
Mar 4, 2008 9:10:57 AM org.apache.coyote.http11.Http11BaseProtocol init
Mar 4, 2008 9:10:57 AM org.apache.catalina.startup.Catalina load
INFO: Initialization processed in 26459 ms
Mar 4, 2008 9:11:00 AM org.apache.catalina.core.StandardService start
Mar 4, 2008 9:11:00 AM org.apache.catalina.core.StandardEngine start
Mar 4, 2008 9:11:00 AM org.apache.catalina.core.StandardHost start
Mar 4, 2008 9:11:16 AM org.apache.catalina.startup.HostConfig deployWAR
Mar 4, 2008 10:02:40 AM org.apache.catalina.startup.Catalina stopServer
Mar 4, 2008 10:05:53 AM org.apache.coyote.http11.Http11BaseProtocol init
Mar 4, 2008 10:05:53 AM org.apache.catalina.startup.Catalina load
INFO: Initialization processed in 4795 ms
Mar 4, 2008 10:05:55 AM org.apache.catalina.core.StandardService start
Mar 4, 2008 10:05:55 AM org.apache.catalina.core.StandardEngine start
Mar 4, 2008 10:05:55 AM org.apache.catalina.core.StandardHost start
filipe
i had the same problem with iptables
then i re-boot the machine and start alfresco again. work for me.
but i still have a problem:
/opt/alfresco# Xlib:  extension "XInputExtension" missing on display ":99.0".
Failed to get list of devices
any idea?
