02-08-2008 09:18 AM
ECHEC - L'application pour le chemin de contexte /alfresco n'a pas puêtredémarrée
root@aero-linux:/home/ben# /etc/init.d/mysql startJe ne sais pas si cela est lié.
* Starting MySQL database server mysqld [ OK ]
/usr/bin/mysqladmin: connect to server at 'localhost' failed
error: 'Access denied for user 'debian-sys-maint'@'localhost' (using password: YES)'
14:00:46,641 ERROR [org.alfresco.repo.content.transform.magick.AbstractImageMagickContentTransformer] ImageMagickContentTransformer not available: Failed to execute command: convert /usr/local/tomcat/temp/Alfresco/ImageMagickContentTransformer_init_source_6123.gif /usr/local/tomcat/temp/Alfresco/ImageMagickContentTransformer_init_target_6124.png
14:00:48,415 WARN [org.springframework.remoting.rmi.RmiRegistryFactoryBean] Could not detect RMI registry - creating new one
14:00:50,098 WARN [org.alfresco.util.OpenOfficeConnectionTester] A connection to OpenOffice could not be established.
14:00:55,179 WARN [org.alfresco.repo.admin.ConfigurationChecker] The Alfresco 'dir.root' property is set to a relative path './alf_data'. 'dir.root' should be overridden to point to a specific folder.
14:00:55,180 INFO [org.alfresco.repo.admin.ConfigurationChecker] The Alfresco root data directory ('dir.root') is: ./alf_data
14:00:55,380 ERROR [org.alfresco.repo.admin.ConfigurationChecker] CONTENT INTEGRITY ERROR: Indexes not found for 5 stores.
14:00:55,380 INFO [org.alfresco.repo.admin.ConfigurationChecker] You may set 'index.recovery.mode=FULL' if you need to rebuild the indexes.
14:00:55,380 ERROR [org.alfresco.repo.admin.ConfigurationChecker] CONTENT INTEGRITY ERROR: System content not found in content store.
14:00:55,380 ERROR [org.alfresco.repo.admin.ConfigurationChecker] Ensure that the 'dir.root' property is pointing to the correct data location.
14:00:55,401 ERROR [org.springframework.web.context.ContextLoader] Context initialization failed
02-14-2008 08:00 AM
02-14-2008 08:46 AM
02-14-2008 08:51 AM
02-14-2008 09:05 AM
02-14-2008 09:08 AM
cd /opt/alfresco
chmod -R 755 *02-14-2008 09:14 AM
02-14-2008 09:28 AM
06-17-2008 03:54 AM
C'est TOUJOURS le même problème :J'ai également ce problème……Caused by: java.security.AccessControlException: access denied (java.io.FilePermission alfresco.log write)
Il faut que tu donnes des droits d'écriture au user avec lequel tu deploies l'appli sur le repertoire qui contient les logs.
# Use the Java security manager? (yes/no)
TOMCAT5_SECURITY=noTags
