Problem with the structure template
Dirk_Wenke
I am quite new to nuxeo and I am trying to configure my nuxeo instance with Nuxeo Studio. I have my own document types and I defined my own structure for a domain using a Structure Template. In this template, the domain has one sub element, let's call it MyWorkspace, which extends WorkspaceRoot. MyWorkspace can only contain my own type of documents and additionally it may contain notes. But if I update my nuxeo installation and try to create a new note, an exception is thrown (see below). What am I doing wrong? It seems like it a sections element is required, but I don't need the sections area as there will be no publication process of the content. What am I doing wrong?
Thanks, Dirk
Exception: org.nuxeo.ecm.core.model.NoSuchDocumentException. message: No such document: No such document: /default-domain/sections
javax.servlet.ServletException: exception invoking: getAvailablePublicationTrees
at javax.faces.webapp.FacesServlet.service(FacesServlet.java:277)
at org.nuxeo.wss.servlet.BaseWSSFilter.doFilter(BaseWSSFilter.java:135)
at org.nuxeo.wss.servlet.FailSafeWSSFilter.doFilter(FailSafeWSSFilter.java:55)
at org.jboss.seam.servlet.SeamFilter$FilterChainImpl.doFilter(SeamFilter.java:83)
at org.nuxeo.ecm.platform.ui.web.multipart.MultipartFilter.doFilter(MultipartFilter.java:73)
at org.jboss.seam.servlet.SeamFilter$FilterChainImpl.doFilter(SeamFilter.java:69)
at org.jboss.seam.web.ExceptionFilter.doFilter(ExceptionFilter.java:64)
at org.jboss.seam.web.RedirectFilter.doFilter(RedirectFilter.java:45)
at org.ajax4jsf.webapp.BaseXMLFilter.doXmlFilter(BaseXMLFilter.java:178)
at org.ajax4jsf.webapp.BaseFilter.handleRequest(BaseFilter.java:290)
at org.ajax4jsf.webapp.BaseFilter.processUploadsAndHandleRequest(BaseFilter.java:368)
at org.ajax4jsf.webapp.BaseFilter.doFilter(BaseFilter.java:495)
at org.jboss.seam.web.Ajax4jsfFilter.doFilter(Ajax4jsfFilter.java:56)
at org.jboss.seam.servlet.SeamFilter.doFilter(SeamFilter.java:158)
at org.nuxeo.ecm.platform.ui.web.auth.NuxeoAuthenticationFilter.doFilterInternal(NuxeoAuthenticationFilter.java:362)
at org.nuxeo.ecm.platform.ui.web.auth.service.NuxeoAuthFilterChain.doFilter(NuxeoAuthFilterChain.java:35)
at org.nuxeo.ecm.platform.ui.web.auth.oauth.NuxeoOAuthFilter.doFilter(NuxeoOAuthFilter.java:167)
at org.nuxeo.ecm.platform.ui.web.auth.service.NuxeoAuthFilterChain.doFilter(NuxeoAuthFilterChain.java:33)
at org.nuxeo.ecm.platform.ui.web.auth.NuxeoAuthenticationFilter.doFilter(NuxeoAuthenticationFilter.java:340)
at org.nuxeo.ecm.platform.web.common.exceptionhandling.NuxeoExceptionFilter.doFilter(NuxeoExceptionFilter.java:79)
at org.nuxeo.ecm.platform.web.common.encoding.NuxeoEncodingFilter.doFilter(NuxeoEncodingFilter.java:59)
at org.apache.catalina.core.ApplicationDispatcher.invoke(ApplicationDispatcher.java:646)
at org.apache.catalina.core.ApplicationDispatcher.processRequest(ApplicationDispatcher.java:436)
at org.apache.catalina.core.ApplicationDispatcher.doForward(ApplicationDispatcher.java:374)
at org.apache.catalina.core.ApplicationDispatcher.forward(ApplicationDispatcher.java:302)
at org.nuxeo.ecm.platform.ui.web.rest.FancyURLFilter.doFilter(FancyURLFilter.java:123)
at org.nuxeo.ecm.platform.wi.filter.WIRequestFilter.doFilter(WIRequestFilter.java:120)
at org.nuxeo.ecm.platform.web.common.requestcontroller.filter.NuxeoRequestControllerFilter.doFilter(NuxeoRequestControllerFilter.java:141)
at org.nuxeo.ecm.platform.ui.web.auth.NuxeoAuthenticationFilter.doFilterInternal(NuxeoAuthenticationFilter.java:518)
at org.nuxeo.platform.login.web.LoginStackCleaner.doFilter(LoginStackCleaner.java:49)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:128)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:293)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:849)
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:454)
Caused by: java.lang.RuntimeException: exception invoking: getAvailablePublicationTrees
at org.jboss.seam.util.Reflections.invokeAndWrap(Reflections.java:148)
at org.jboss.seam.Component.callComponentMethod(Component.java:2201)
at org.jboss.seam.Component.getInstanceFromFactory(Component.java:2033)
at org.jboss.seam.Component.getInstance(Component.java:1968)
at org.jboss.seam.Component.getInstance(Component.java:1940)
at org.jboss.seam.Component.getInstance(Component.java:1934)
at org.jboss.seam.Namespace.getComponentInstance(Namespace.java:55)
at org.jboss.seam.Namespace.getComponentInstance(Namespace.java:50)
at org.jboss.seam.el.SeamELResolver.resolveBase(SeamELResolver.java:166)
at org.jboss.seam.el.SeamELResolver.getValue(SeamELResolver.java:53)
at javax.el.CompositeELResolver.getValue(CompositeELResolver.java:54)
at com.sun.faces.el.FacesCompositeELResolver.getValue(FacesCompositeELResolver.java:72)
at org.jboss.el.parser.AstIdentifier.getValue(AstIdentifier.java:44)
at org.jboss.el.ValueExpressionImpl.getValue(ValueExpressionImpl.java:186)
at com.sun.facelets.el.TagValueExpression.getValue(TagValueExpression.java:71)
at com.sun.facelets.tag.TagAttribute.getObject(TagAttribute.java:233)
at com.sun.facelets.tag.TagAttribute.getObject(TagAttribute.java:166)
at org.nuxeo.ecm.platform.ui.web.tag.handler.RepeatTagHandler.getDataModel(RepeatTagHandler.java:90)
at org.nuxeo.ecm.platform.ui.web.tag.handler.RepeatTagHandler.apply(RepeatTagHandler.java:110)
at com.sun.facelets.tag.CompositeFaceletHandler.apply(CompositeFaceletHandler.java:47)
at com.sun.facelets.compiler.NamespaceHandler.apply(NamespaceHandler.java:49)
at com.sun.facelets.compiler.EncodingHandler.apply(EncodingHandler.java:25)
at org.nuxeo.theme.jsf.facelets.vendor.DefaultFacelet.include(DefaultFacelet.java:256)
at org.nuxeo.theme.jsf.facelets.vendor.DefaultFacelet.include(DefaultFacelet.java:306)
at org.nuxeo.theme.jsf.facelets.vendor.DefaultFacelet.include(DefaultFacelet.java:280)
at org.nuxeo.theme.jsf.facelets.vendor.DefaultFaceletContext.includeFacelet(DefaultFaceletContext.java:169)
at com.sun.facelets.tag.ui.DecorateHandler.apply(DecorateHandler.java:105)
at org.nuxeo.ecm.platform.ui.web.binding.alias.AliasTagHandler.apply(AliasTagHandler.java:152)
at org.nuxeo.ecm.platform.ui.web.binding.alias.AliasTagHandler.apply(AliasTagHandler.java:104)
at org.nuxeo.ecm.platform.forms.layout.facelets.WidgetTagHandler.applyWidgetHandler(WidgetTagHandler.java:167)
at org.nuxeo.ecm.platform.forms.layout.facelets.WidgetTagHandler.apply(WidgetTagHandler.java:109)
at org.nuxeo.ecm.platform.forms.layout.facelets.LayoutRowWidgetTagHandler.apply(LayoutRowWidgetTagHandler.java:126)
at org.nuxeo.ecm.platform.forms.layout.facelets.LayoutRowTagHandler.apply(LayoutRowTagHandler.java:116)
at com.sun.facelets.tag.jsf.ComponentHandler.applyNextHandler(ComponentHandler.java:314)
at com.sun.facelets.tag.jsf.ComponentHandler.apply(ComponentHandler.java:169)
at com.sun.facelets.tag.ui.IncludeHandler.apply(IncludeHandler.java:65)
at org.nuxeo.ecm.platform.forms.layout.facelets.LayoutTagHandler.apply(LayoutTagHandler.java:260)
at com.sun.facelets.tag.ui.DefineHandler.applyDefinition(DefineHandler.java:64)
at org.nuxeo.theme.jsf.facelets.CompositionHandler.apply(CompositionHandler.java:191)
at org.nuxeo.theme.jsf.facelets.vendor.DefaultFaceletContext$TemplateManager.apply(DefaultFaceletContext.java:385)
at org.nuxeo.theme.jsf.facelets.vendor.DefaultFaceletContext.includeDefinition(DefaultFaceletContext.java:353)
at com.sun.facelets.tag.ui.InsertHandler.apply(InsertHandler.java:68)
at com.sun.facelets.tag.jsf.core.ViewHandler.apply(ViewHandler.java:109)
at org.nuxeo.theme.jsf.facelets.vendor.DefaultFaceletContext.includeFacelet(DefaultFaceletContext.java:308)
at org.nuxeo.theme.jsf.facelets.CompositionHandler.apply(CompositionHandler.java:167)
at org.nuxeo.theme.jsf.facelets.vendor.DefaultFacelet.apply(DefaultFacelet.java:104)
at com.sun.facelets.FaceletViewHandler.buildView(FaceletViewHandler.java:524)
at com.sun.facelets.FaceletViewHandler.renderView(FaceletViewHandler.java:567)
at org.ajax4jsf.application.ViewHandlerWrapper.renderView(ViewHandlerWrapper.java:100)
at org.ajax4jsf.application.AjaxViewHandler.renderView(AjaxViewHandler.java:176)
at com.sun.faces.lifecycle.RenderResponsePhase.execute(RenderResponsePhase.java:110)
at com.sun.faces.lifecycle.Phase.doPhase(Phase.java:100)
at com.sun.faces.lifecycle.LifecycleImpl.render(LifecycleImpl.java:139)
at org.nuxeo.ecm.platform.ui.web.lifecycle.NuxeoLifeCycleImpl.render(NuxeoLifeCycleImpl.java:98)
at javax.faces.webapp.FacesServlet.service(FacesServlet.java:266)
... 74 more
Caused by: org.nuxeo.ecm.platform.publisher.api.PublicationTreeNotAvailable: Error during tree init
at org.nuxeo.ecm.platform.publisher.impl.service.PublisherServiceImpl.getPublicationTree(PublisherServiceImpl.java:387)
at org.nuxeo.ecm.platform.publisher.impl.service.PublisherServiceImpl.buildTree(PublisherServiceImpl.java:272)
at org.nuxeo.ecm.platform.publisher.impl.service.PublisherServiceImpl.getOrBuildTree(PublisherServiceImpl.java:255)
at org.nuxeo.ecm.platform.publisher.impl.service.PublisherServiceImpl.getPublicationTree(PublisherServiceImpl.java:205)
at org.nuxeo.ecm.platform.publisher.web.PublishActionsBean.filterEmptyTrees(PublishActionsBean.java:165)
at org.nuxeo.ecm.platform.publisher.web.PublishActionsBean.filterEmptyTrees(PublishActionsBean.java:152)
at org.nuxeo.ecm.platform.publisher.web.PublishActionsBean.getAvailablePublicationTrees(PublishActionsBean.java:186)
at org.jboss.seam.util.Reflections.invoke(Reflections.java:22)
at org.jboss.seam.intercept.RootInvocationContext.proceed(RootInvocationContext.java:31)
at org.jboss.seam.intercept.SeamInvocationContext.proceed(SeamInvocationContext.java:56)
at org.jboss.seam.transaction.RollbackInterceptor.aroundInvoke(RollbackInterceptor.java:28)
at org.jboss.seam.intercept.SeamInvocationContext.proceed(SeamInvocationContext.java:68)
at org.nuxeo.ecm.platform.ui.web.util.NuxeoBijectionInterceptor.aroundInvoke(NuxeoBijectionInterceptor.java:68)
at org.jboss.seam.core.MethodContextInterceptor.aroundInvoke(MethodContextInterceptor.java:44)
at org.jboss.seam.intercept.RootInterceptor.invoke(RootInterceptor.java:107)
at org.jboss.seam.intercept.JavaBeanInterceptor.interceptInvocation(JavaBeanInterceptor.java:166)
at org.jboss.seam.intercept.JavaBeanInterceptor.invoke(JavaBeanInterceptor.java:102)
at org.nuxeo.ecm.platform.publisher.web.PublishActionsBean_$$_javassist_74.getAvailablePublicationTrees(PublishActionsBean_$$_javassist_74.java)
at org.jboss.seam.util.Reflections.invokeAndWrap(Reflections.java:138)
... 165 more
Caused by: org.nuxeo.ecm.core.api.WrappedException: Exception: org.nuxeo.ecm.core.api.ClientException. message: Failed to resolve document ref: /default-domain/sections
at org.nuxeo.ecm.core.api.AbstractSession.hasPermission(AbstractSession.java:507)
at sun.reflect.GeneratedMethodAccessor206.invoke(Unknown Source)
at org.nuxeo.ecm.core.api.TransactionalCoreSessionWrapper.invoke(TransactionalCoreSessionWrapper.java:129)
at $Proxy24.hasPermission(Unknown Source)
at org.nuxeo.ecm.platform.publisher.impl.core.SectionPublicationTree.initTree(SectionPublicationTree.java:65)
at org.nuxeo.ecm.platform.publisher.impl.core.RootSectionsPublicationTree.initTree(RootSectionsPublicationTree.java:44)
at org.nuxeo.ecm.platform.publisher.impl.service.PublisherServiceImpl.getPublicationTree(PublisherServiceImpl.java:384)
... 194 more
Caused by: org.nuxeo.ecm.core.api.WrappedException: Exception: org.nuxeo.ecm.core.model.NoSuchDocumentException. message: No such document: No such document: /default-domain/sections
at org.nuxeo.ecm.core.storage.sql.coremodel.SQLSession.resolvePath(SQLSession.java:237)
at org.nuxeo.ecm.core.api.DocumentResolver.resolveReference(DocumentResolver.java:63)
at org.nuxeo.ecm.core.api.AbstractSession.hasPermission(AbstractSession.java:504)
... 202 more
schambon_
Nuxeo complains that it can't find the "sections" document at the root of the domain. It is certainly used to display the "publication" tab, but possibly elsewhere too.
At a guess there are two ways I'd address that issue:
  • the hard way would be to track and debug all usages of Sections
  • the easy way would be to create the "sections" document (type = SectionRoot, name = sections, title etc. = whatever you like) BUT add to it the HiddenInNavigation facet so that it doesn't show anywhere.
schambon_
and if i'm not mistaken this has been solved by https
