Problem while login with Authentication plugin in Nuxeo-jboss-5.3.1
veera_
I created one authenticator plugin. After that,
I add the authenticator plugin to the authentication chain.
I add the plugin into plugin folder and xml into config folder.
After restart nuxeo-jboss-5.3.1,
The Logs shows
15:46:01,164 ERROR [OSGiRuntimeService] Nuxeo EP Started
= Nuxeo EP Started
= Component Loading Errors:
  * Failed to instantiate component: org.nuxeo.ecm.platform.ui.web.auth.AuthenticationServiceImpl (java.lang.ClassNotFoundException: org.nuxeo.ecm.platform.ui.web.auth.AuthenticationServiceImpl)
  * Failed to create component: service:org.nuxeo.ecm.platform.ui.web.auth.AuthenticationService (java.lang.ClassNotFoundException: org.nuxeo.ecm.platform.ui.web.auth.AuthenticationServiceImpl)
  * Failed to register extension to: service:org.nuxeo.ecm.platform.ui.web.auth.service.PluggableAuthenticationService, xpoint: authenticators in component: service:org.nuxeo.ecm.platform.login. (java.lang.NullPointerException)
= Component Loading Status: Pending: 2 / Unstarted: 0 / Total: 376
  * service:fr.takoma.project.erudis.core-types requires [service:org.nuxeo.ecm.platform.versioning.listeners.DocVersioningListener]
  * service:org.nuxeo.ecm.platform.login. requires [service:org.nuxeo.ecm.platform.ui.web.auth.AuthenticationService]
After Login,
12:53:32,431 ERROR [NuxeoAuthenticationFilter] Auth plugin ADMINSITRATOR_FILTER_AUTH can not be retrieved from service
12:53:32,434 ERROR [DefaultNuxeoExceptionHandler] java.lang.NullPointerException
	at org.nuxeo.ecm.platform.ui.web.auth.NuxeoAuthenticationFilter.initUnAuthenticatedURLPrefix(NuxeoAuthenticationFilter.java:736)
	at org.nuxeo.ecm.platform.ui.web.auth.NuxeoAuthenticationFilter.bypassAuth(NuxeoAuthenticationFilter.java:746)
	at org.nuxeo.ecm.platform.ui.web.auth.NuxeoAuthenticationFilter.doFilter(NuxeoAuthenticationFilter.java:385)
	at org.nuxeo.ecm.platform.web.common.requestcontroller.filter.NuxeoRequestControllerFilter.doFilter(NuxeoRequestControllerFilter.java:132)
	at org.nuxeo.ecm.platform.web.common.exceptionhandling.NuxeoExceptionFilter.doFilter(NuxeoExceptionFilter.java:80)
	at org.jboss.web.tomcat.filters.ReplyHeaderFilter.doFilter(ReplyHeaderFilter.java:96)
	at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:230)
	at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:175)
	at org.jboss.web.tomcat.security.SecurityAssociationValve.invoke(SecurityAssociationValve.java:182)
	at org.jboss.web.tomcat.security.JaccContextValve.invoke(JaccContextValve.java:84)
	at org.jboss.web.tomcat.service.jca.CachedConnectionValve.invoke(CachedConnectionValve.java:157)
	at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:262)
	at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:844)
	at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:446)
12:53:32,434 ERROR [nuxeo-error-log] java.lang.NullPointerException
12:53:32,482 ERROR [nuxeo-error-log]
Request Attributes:
nuxeo.disable.redirect.wrapper : true
stackTrace : java.lang.NullPointerException
NuxeoExceptionHandlerMarker : true
securityError : false
user_message : an unexpected error occurred
Can anyone help me?
Julien_Carsique
Elite Collaborator
Elite Collaborator
What are the errors in logs before the "Nuxeo EP Started" summary, before login?
Is org.nuxeo.ecm.platform.ui.web.auth.AuthenticationServiceImpl the code you wrote?
Maybe you should try to put your plugin into the bundles directory instead of plugins.
Julien_Carsique
Elite Collaborator
Elite Collaborator
Hi bjalon & Julien Carsique,
Benjamin_Jalon1
Elite Collaborator
Elite Collaborator
Any update ?
