Faceted Search customization running a warn and doesn't work
Nicolas_
I create a custom search with the Faceted Search.
I use this tutorial : http://doc.nuxeo.com/display/NXDOC/Faceted+Search
I followed this tutoriel, but when i try to use the search, the server show me a warn and the search does'nt working :
15:24:21,981 WARN [DocumentModelResolver] Property not found: dc_start.
15:24:21,986 WARN [DocumentModelResolver] Property not found: dc_end.
15:24:21,988 WARN [DocumentModelResolver] Property not found: selectVocabularyField.
Do you have an idea about this problem ?
Thanks a lot for your help.
Best regards, Nicolas
My file extensions.xml : http://pastebin.com/3LWeRED4
My file faceted_search_default.xsd : http://pastebin.com/LHCvXC9b
Nicolas_
I find an issue to this problem.
I tryed to overload the schema faceted_search_default, but it's not working.
I have to create a new schema with a different name to define the new field and it's working now.
Best regards,
Nicolas.
Nicolas_
Best regards,
Nicolas.
