05-28-2013 07:50 AM
Hi people, I have 3 questions :
I just search for edit and modify "Subjects" List. Can you said me where they are, i don't use Nuxeo Studio. I just want to have my own list, without "Art, society..." but spécific list to my activty.
Can I Add some Subjects List to an MAss Import documents.
Can I Add some Tag in "mass" for import documents (imagine i have to import 10 documents and want to tag all of them with the tag "Car" and "Assurance" for exemple).
Explain to me where and who I can do this (or not... ) ,
Thank you a lot for your future answer.
Regard,
05-28-2013 08:47 AM
If you don't use studio, you will need to use Nuxeo IDE or generate a maven project to build your bundle alone.
05-28-2013 08:44 AM
For the first point, you may want to check this question & answer.
05-28-2013 08:47 AM
05-28-2013 12:19 PM
Yes I don't use Studio because it's expensive for an Proof of Concept ... ! For the override I don't understand what you mean ?? How I can do it ? (PS : The right link for me is : http://explorer.nuxeo.org/nuxeo/site/distribution/Nuxeo%20Platform-5.6/viewContribution/org.nuxeo.ec... , i'm on 5.6 Nuxeo.)
Or you can modify the vocabulary into your instance in the Admin Center without development. ... yes you can drag a list of document from your desktop and let your list dragged over the target container into your browser waiting that bloc move from blue to green, and select import with metadata
It's the way I choose and look like the more Easier.
@Mathhieu Guillaume : The answer is not realy clear for me ... 😕 ! Can't understand. (Maybe because some thing miss, or because my english is not enough good...)
If it's not possible with TAG is not an trouble if I have another way to do it.
Thanks you.
