Problems with dates after Updating to 2.9B and 2.9C
tonizz
Hi everybody,
I have updated my alfresco community to 2.9B and after to C too and in both versions I´m getting the same problem: Alfresco WCM is not capable of open any created xml with data types from a web form to modify. All the navigators I´ve tried give me this error:
      dojo.date.fromRfc3339 is not a function
Has somebody found with this issue???
4 REPLIES 4
kvc
Tonizz:
Hmmm … maybe a bug in Community.  Please file a JIRA?  New Community releases can have random bugs at times - not intentional; it just is a artifact that it represents that latest and greatest in-progress work from Engineering (releases do not go through full 4-6 week regression testing/certification).
Kevin
frankweiss
I have also encountered this issue and entered it into Jira
http://issues.alfresco.com/browse/AWC-1841
tonizz
What I have done is to copy the content of the file /alfresco/script/ajax/src/date/serialize.js to /alfresco/script/ajax/xforms.js. Its not very elegant but is valid. Another workaround else…
It is working fine.
kmadel
I am having numerous issues with several of the 2.9 C builds up to and including the 2/22 drop.  For Firefox 2.1.12 (Mac OS X and Windows XP), the increase indeces is not working.  The red Chiba/XForms dialog shows 'Loading 2' and just stays that way until you try again, and then it will display 'Loading 4' but not do anything. This is for example with the included Article.xsl.  If you click finish, and then reopen the content, then there will be two additional elements added (in this case 'body').
For Safari, that increment indeces works, but values that are populated into text areas, and file selectors are not retained when saved.
I was having similar issues with 2.9B. Has anyone else seen these types of issues?
This is from Firebugs console, when clicking on the plus to insert another 'body' element:
fireAction(repeat_0-insert_after)
sending request to XFormsBean.fireAction(id=repeat_0-insert_after)
Loading (2)
The logs don't show anything helpful.
