01-13-2012 02:36 PM
package edu.mayo.mi3c.xb3.designer;
import org.activiti.designer.integration.servicetask.AbstractCustomServiceTask;
import org.activiti.designer.integration.servicetask.PropertyType;
import org.activiti.designer.integration.servicetask.annotation.Help;
import org.activiti.designer.integration.servicetask.annotation.Property;
import org.activiti.designer.integration.servicetask.annotation.Runtime;
@DeweyTask
@SuppressWarnings("unused")
@Runtime(delegationClass = "edu.mayo.mi3c.xb3.task.ClassifySeriesTask")
@Help(displayHelpShort = "Classify a series", displayHelpLong = "Assign tags to the BO associated with this series")
public class ClassifySeriesItem extends AbstractCustomServiceTask {
@Property(type = PropertyType.TEXT, displayName = "Extra Tags", required = false, defaultValue = "")
@Help(displayHelpShort = "Tags", displayHelpLong = "Comma-separated list of extra tags to add to the BO")
private String tags;
@Property(type = PropertyType.BOOLEAN_CHOICE, displayName = "Wait for completion", required = true, defaultValue = "true")
@Help(displayHelpShort = "Wait for task completion", displayHelpLong = "If checked, the workflow item does not complete until DEWEY executes the required functionality. If unchecked, execution immediately continues and the next step in the workflow is assumed to be a 'Receive' task")
private Boolean synchronous;
@Override
public String getSmallIconPath() {
return "icons/folder_fill_16x16.png";
@Override
public String getName() {
return "Classify Series";
@DeweyTask
@Override
@Override
09-26-2012 05:00 PM
