Problem in assigning users
pavan_bukka_ait
as show in the below process diagram a user uploads a document after that Verify Document task gets activated this task will be assigned to three people if all the three people accepts the document then only it should go to next task.
I have assigned the users to Verify Document task using Candidate Users. But the problem is if i assign users in this way if either of the three approves the document it will go to next task. What my requirement is it should go to next if and only if all the three users assigned to Verify document task approve the document.
Thanks in advance.
Best regards,
Bukka pavan kumar.
ronald_van_kuij
You should use "multi instance" for this. See the documentation
pavan_bukka_ait
Thank you so much for the reply i got the idea of how to do.
With regards,
Bukka pavan kumar.
