04-27-2012 07:16 AM
HTTP Status 500 -
type Exception report
message
description The server encountered an internal error () that prevented it from fulfilling this request.
exception
org.springframework.web.util.NestedServletException: Request processing failed; nested exception is org.springframework.extensions.surf.exception.PlatformRuntimeException: 03270001 Unable to retrieve object: slingshot.site.configuration of type: configuration
org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:659)
org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:552)
javax.servlet.http.HttpServlet.service(HttpServlet.java:617)
javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
root cause
org.springframework.extensions.surf.ObjectPersistenceService.getObject(ObjectPersistenceService.java:130)
org.springframework.extensions.surf.ModelObjectService.getObject(ModelObjectService.java:507)
org.springframework.extensions.surf.ModelObjectService.getConfiguration(ModelObjectService.java:135)
org.springframework.extensions.surf.site.SiteUtil.getSiteConfiguration(SiteUtil.java:99)
org.springframework.extensions.surf.support.AbstractRequestContext.getSiteConfiguration(AbstractRequestContext.java:138)
org.springframework.extensions.surf.mvc.ThemeInterceptor.preHandle(ThemeInterceptor.java:66)
org.springframework.web.servlet.handler.WebRequestHandlerInterceptorAdapter.preHandle(WebRequestHandlerInterceptorAdapter.java:54)
org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:761)
org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:716)
org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:647)
root cause
org.springframework.extensions.surf.exception.ModelObjectPersisterException: Error loading object id: slingshot.site.configuration from persister id: webframework.slingshot.persister.remote
org.springframework.extensions.surf.persister.MultiObjectPersister.getObject(MultiObjectPersister.java:102)
org.springframework.extensions.surf.ObjectPersistenceService.getObject(ObjectPersistenceService.java:126)
root cause
org.springframework.extensions.surf.exception.ModelObjectPersisterException: Failure to load model object for path: alfresco/site-data/configurations/slingshot.site.configuration.xml
org.springframework.extensions.surf.persister.PathStoreObjectPersister.getObject(PathStoreObjectPersister.java:251)
org.springframework.extensions.surf.persister.MultiObjectPersister.getObject(MultiObjectPersister.java:98)
root cause
java.io.IOException: Unable to test document path: alfresco/site-data/configurations/slingshot.site.configuration.xml in remote store: alfresco due to error: 404
org.springframework.extensions.webscripts.RemoteStore.hasDocument(RemoteStore.java:347)
org.springframework.extensions.surf.persister.PathStoreObjectPersister.getObject(PathStoreObjectPersister.java:216)
note The full stack trace of the root cause is available in the Apache Tomcat/6.0.18 logs.
05-01-2012 10:55 PM
05-02-2012 01:31 AM
"C:\Program Files\OrangeHRM\2.5.0.3\mysql\bin\mysqld" "–defaults-file=C:\Program Files\OrangeHRM\2.5.0.3\mysql\bin\my.cnf" mysqlC:\Alfresco\tomcat\webapps\alfresco.war
C:\Alfresco\tomcat\webapps\mobile.war
C:\Alfresco\tomcat\webapps\share.war05-02-2012 02:03 AM
05-03-2012 10:10 AM
120110 18:24:40 [Note] Event Scheduler: Purging the queue. 0 events
120110 18:24:40 InnoDB: Starting shutdown…
120110 18:24:41 InnoDB: Shutdown completed; log sequence number 0 614692849
120110 18:24:41 [Note] C:\Program Files\OrangeHRM\2.5.0.3\mysql\bin\mysqld: Shutdown complete
120110 18:26:07 InnoDB: Started; log sequence number 0 614692849
120110 18:26:07 [Note] Event Scheduler: Loaded 0 events
120110 18:26:07 [Note] C:\Program Files\OrangeHRM\2.5.0.3\mysql\bin\mysqld: ready for connections.
Version: '5.1.30-community' socket: '' port: 3306 MySQL Community Server (GPL)
InnoDB: The log sequence number in ibdata files does not match
InnoDB: the log sequence number in the ib_logfiles!
120229 10:43:20 InnoDB: Database was not shut down normally!
InnoDB: Starting crash recovery.
InnoDB: Reading tablespace information from the .ibd files…
InnoDB: Restoring possible half-written data pages from the doublewrite
InnoDB: buffer…
120229 10:43:21 InnoDB: Started; log sequence number 0 657548674
120229 10:43:21 [Note] Event Scheduler: Loaded 0 events
120229 10:43:21 [Note] C:\Program Files\OrangeHRM\2.5.0.3\mysql\bin\mysqld: ready for connections.
120301 12:42:14 InnoDB: Database was not shut down normally!
InnoDB: buffer…
120301 12:42:15 InnoDB: Started; log sequence number 0 657548674
120301 12:42:15 [Note] Event Scheduler: Loaded 0 events
120301 12:42:15 [Note] C:\Program Files\OrangeHRM\2.5.0.3\mysql\bin\mysqld: ready for connections.
120306 11:37:11 [Note] C:\Program Files\OrangeHRM\2.5.0.3\mysql\bin\mysqld: Normal shutdown
120306 11:37:11 [Note] Event Scheduler: Purging the queue. 0 events
120306 11:37:12 InnoDB: Starting shutdown…
120306 11:37:14 InnoDB: Shutdown completed; log sequence number 0 657708134
120306 11:37:14 [Note] C:\Program Files\OrangeHRM\2.5.0.3\mysql\bin\mysqld: Shutdown complete
120306 11:38:37 InnoDB: Started; log sequence number 0 657708134
120306 11:38:38 [Note] Event Scheduler: Loaded 0 events
120306 11:38:38 [Note] C:\Program Files\OrangeHRM\2.5.0.3\mysql\bin\mysqld: ready for connections.
120413 17:02:11 [Note] C:\Program Files\OrangeHRM\2.5.0.3\mysql\bin\mysqld: Normal shutdown
120413 17:02:14 [Note] Event Scheduler: Purging the queue. 0 events
120413 17:02:19 InnoDB: Starting shutdown…
120413 17:02:24 InnoDB: Shutdown completed; log sequence number 0 744108726
120413 17:02:24 [Note] C:\Program Files\OrangeHRM\2.5.0.3\mysql\bin\mysqld: Shutdown complete
120413 17:07:02 - mysqld got exception 0xc0000005 ;
This could be because you hit a bug. It is also possible that this binary
or one of the libraries it was linked against is corrupt, improperly built,
or misconfigured. This error can also be caused by malfunctioning hardware.
We will try our best to scrape up some info that will hopefully help diagnose
the problem, but since we have already crashed, something is definitely wrong
and this may fail.
key_buffer_size=16777216
read_buffer_size=262144
max_used_connections=0
max_threads=151
threads_connected=0
It is possible that mysqld could use up to
key_buffer_size + (read_buffer_size + sort_buffer_size)*max_threads = 133305 K
bytes of memory
Hope that's ok; if not, decrease some variables in the equation.
thd: 0x0
Attempting backtrace. You can use the following information to find out
where mysqld died. If you see no messages after this, something went
terribly wrong…
006B8853 mysqld.exe!???
The manual page at http://dev.mysql.com/doc/mysql/en/crashing.html contains
information that should help you find out what is causing the crash.
120413 17:16:46 - mysqld got exception 0xc0000005 ;
and this may fail.
max_threads=151
threads_connected=0
bytes of memory
thd: 0x0
terribly wrong…
120413 17:18:04 - mysqld got exception 0xc0000005 ;
and this may fail.
max_threads=151
threads_connected=0
bytes of memory
thd: 0x0
terribly wrong…
120413 17:21:20 - mysqld got exception 0xc0000005 ;
and this may fail.
max_threads=151
threads_connected=0
bytes of memory
thd: 0x0
terribly wrong…
120413 17:21:52 - mysqld got exception 0xc0000005 ;
and this may fail.
max_threads=151
threads_connected=0
bytes of memory
thd: 0x0
terribly wrong…
120413 17:21:59 - mysqld got exception 0xc0000005 ;
and this may fail.
max_threads=151
threads_connected=0
bytes of memory
thd: 0x0
terribly wrong…
120413 17:22:02 - mysqld got exception 0xc0000005 ;
and this may fail.
max_threads=151
threads_connected=0
bytes of memory
thd: 0x0
terribly wrong…
120413 17:22:06 - mysqld got exception 0xc0000005 ;
and this may fail.
max_threads=151
threads_connected=0
bytes of memory
thd: 0x0
terribly wrong…
120420 14:18:37 - mysqld got exception 0xc0000005 ;
and this may fail.
max_threads=151
threads_connected=0
bytes of memory
thd: 0x0
terribly wrong…
120420 15:47:29 - mysqld got exception 0xc0000005 ;
and this may fail.
max_threads=151
threads_connected=0
bytes of memory
thd: 0x0
terribly wrong…
120420 15:54:25 - mysqld got exception 0xc0000005 ;
and this may fail.
max_threads=151
threads_connected=0
bytes of memory
thd: 0x0
terribly wrong…
120420 16:00:40 - mysqld got exception 0xc0000005 ;
and this may fail.
max_threads=151
threads_connected=0
bytes of memory
thd: 0x0
terribly wrong…
120420 16:25:11 - mysqld got exception 0xc0000005 ;
and this may fail.
max_threads=151
threads_connected=0
bytes of memory
thd: 0x0
terribly wrong…
120420 16:52:22 - mysqld got exception 0xc0000005 ;
and this may fail.
max_threads=151
threads_connected=0
bytes of memory
thd: 0x0
terribly wrong…
120501 14:16:29 - mysqld got exception 0xc0000005 ;
and this may fail.
max_threads=151
threads_connected=0
bytes of memory
thd: 0x0
terribly wrong…
120501 20:02:33 - mysqld got exception 0xc0000005 ;
and this may fail.
max_threads=151
threads_connected=0
bytes of memory
thd: 0x0
terribly wrong…
120501 20:04:39 - mysqld got exception 0xc0000005 ;
and this may fail.
max_threads=151
threads_connected=0
bytes of memory
thd: 0x0
terribly wrong…
120501 20:06:42 - mysqld got exception 0xc0000005 ;
and this may fail.
max_threads=151
threads_connected=0
bytes of memory
thd: 0x0
terribly wrong…
120501 20:06:52 - mysqld got exception 0xc0000005 ;
and this may fail.
max_threads=151
threads_connected=0
bytes of memory
thd: 0x0
terribly wrong…
120502 13:14:10 - mysqld got exception 0xc0000005 ;
and this may fail.
max_threads=151
threads_connected=0
bytes of memory
thd: 0x0
terribly wrong…
120502 13:37:12 - mysqld got exception 0xc0000005 ;
and this may fail.
max_threads=151
threads_connected=0
bytes of memory
thd: 0x0
terribly wrong…
120503 1:53:30 - mysqld got exception 0xc0000005 ;
and this may fail.
max_threads=151
threads_connected=0
bytes of memory
thd: 0x0
terribly wrong…
120503 21:33:42 - mysqld got exception 0xc0000005 ;
and this may fail.
max_threads=151
threads_connected=0
bytes of memory
thd: 0x0
terribly wrong…
120503 21:36:25 - mysqld got exception 0xc0000005 ;
and this may fail.
max_threads=151
threads_connected=0
bytes of memory
thd: 0x0
terribly wrong…
120503 21:37:05 - mysqld got exception 0xc0000005 ;
and this may fail.
max_threads=151
threads_connected=0
bytes of memory
thd: 0x0
terribly wrong…
05-04-2012 06:20 AM
