help! Error after migrating from HSQL -> MySQL -> Orac
gjw
A standard all-in-one Alfresco 2.0.1E/WCM 2.0.1/HSQL combination was running on a pc. Moved entire directory to another test pc. Alfresco and WCM component ran fine with configuration left as is. When migrated from HSQL -> Oracle 10g (2 step migration - HSQL to MySQL using MySQL Migration tool, as advised on Alfresco Wiki, and then from MySQL -> Oracle 10g using Oracle SQL Developer Migration Wizard).
10:21:53,626 ERROR [org.alfresco.util.transaction.SpringAwareUserTransaction] Transaction didn't commit
org.hibernate.exception.ConstraintViolationException: Could not execute JDBC batch update
   at org.hibernate.exception.SQLStateConverter.convert(SQLStateConverter.java:71)
   at org.hibernate.exception.JDBCExceptionHelper.convert(JDBCExceptionHelper.java:43)
   at org.hibernate.jdbc.AbstractBatcher.executeBatch(AbstractBatcher.java:202)
   at org.hibernate.engine.ActionQueue.executeActions(ActionQueue.java:235)
   at org.hibernate.engine.ActionQueue.executeActions(ActionQueue.java:139)
   at org.hibernate.event.def.AbstractFlushingEventListener.performExecutions(AbstractFlushingEventListener.java:297)
   at org.hibernate.event.def.DefaultFlushEventListener.onFlush(DefaultFlushEventListener.java:27)
   at org.hibernate.impl.SessionImpl.flush(SessionImpl.java:985)
   at org.alfresco.repo.node.db.hibernate.HibernateNodeDaoServiceImpl.flush(HibernateNodeDaoServiceImpl.java:281)
   at org.alfresco.repo.transaction.AlfrescoTransactionSupport$TransactionSynchronizationImpl.flush(AlfrescoTransactionSupport.java:569)
   at org.alfresco.repo.transaction.AlfrescoTransactionSupport$TransactionSynchronizationImpl.beforeCommit(AlfrescoTransactionSupport.java:630)
   at org.springframework.transaction.support.AbstractPlatformTransactionManager.triggerBeforeCommit(AbstractPlatformTransactionManager.java:657)
   at org.springframework.transaction.support.AbstractPlatformTransactionManager.processCommit(AbstractPlatformTransactionManager.java:482)
   at org.springframework.transaction.support.AbstractPlatformTransactionManager.commit(AbstractPlatformTransactionManager.java:469)
   at org.springframework.transaction.interceptor.TransactionAspectSupport.doCommitTransactionAfterReturning(TransactionAspectSupport.java:266)
   at org.alfresco.util.transaction.SpringAwareUserTransaction.commit(SpringAwareUserTransaction.java:405)
   at org.alfresco.repo.transaction.TransactionUtil.executeInTransaction(TransactionUtil.java:186)
   at org.alfresco.repo.transaction.TransactionUtil.executeInUserTransaction(TransactionUtil.java:82)
   at org.alfresco.repo.descriptor.DescriptorServiceImpl.onBootstrap(DescriptorServiceImpl.java:182)
   at org.springframework.context.event.SimpleApplicationEventMulticaster.multicastEvent(SimpleApplicationEventMulticaster.java:45)
   at org.springframework.context.support.AbstractApplicationContext.publishEvent(AbstractApplicationContext.java:225)
   at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:323)
   at org.springframework.web.context.support.AbstractRefreshableWebApplicationContext.refresh(AbstractRefreshableWebApplicationContext.java:134)
   at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:3763)
   at org.apache.catalina.core.StandardContext.start(StandardContext.java:4211)
   at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:809)
   at org.apache.catalina.startup.HostConfig.deployWARs(HostConfig.java:698)
   at org.apache.catalina.core.StandardServer.start(StandardServer.java:709)
Caused by: java.sql.BatchUpdateException: ORA-00001: unique constraint (ALFRESCO_MYSQL.PRIMARY_13) violated
   at oracle.jdbc.driver.DatabaseError.throwBatchUpdateException(DatabaseError.java:343)
   at oracle.jdbc.driver.OraclePreparedStatement.executeBatch(OraclePreparedStatement.java:10720)
   at org.apache.commons.dbcp.DelegatingStatement.executeBatch(DelegatingStatement.java:294)
   at org.hibernate.jdbc.BatchingBatcher.doExecuteBatch(BatchingBatcher.java:58)
   at org.hibernate.jdbc.AbstractBatcher.executeBatch(AbstractBatcher.java:195)
   … 48 more
15 REPLIES 15
gjw
That seems to have done the trick. Cheers!
See how the Oracle migration goes now…
gjw
still no luck getting the schema into Oracle…
09:50:45,163 WARN  [org.springframework.remoting.rmi.RmiRegistryFactoryBean] Could not detect RMI registry - creating new one
09:51:37,080 INFO  [org.alfresco.repo.domain.schema.SchemaBootstrap] Executing database script: C:\alfresco201new\tomcat\temp\Alfresco\AlfrescoSchemaUpdate-org.hibernate.dialect.Oracle9Dialect-40029.sql
09:51:45,720 WARN  [org.alfresco.service.descriptor.DescriptorService] Alfresco license: Failed to verify license - Invalid License!
09:51:45,720 WARN  [org.alfresco.service.descriptor.DescriptorService] Alfresco license: Restricted Alfresco Repository to read-only capability
09:51:45,876 ERROR [org.alfresco.util.transaction.SpringAwareUserTransaction] Transaction didn't commit
Caused by: java.sql.BatchUpdateException: ORA-00001: unique constraint (ALFRESCO_MYSQL.PRIMARY_4) violated
   … 48 more
09:51:45,938 ERROR [org.springframework.web.context.ContextLoader] Context initialization failed
org.alfresco.error.AlfrescoRuntimeException: Unexpected rollback of exception:
Transaction didn't commit: Could not execute JDBC batch update
   at org.alfresco.repo.transaction.TransactionUtil.executeInTransaction(TransactionUtil.java:192)
Caused by: javax.transaction.RollbackException: Transaction didn't commit: Could not execute JDBC batch update
   at org.alfresco.util.transaction.SpringAwareUserTransaction.commit(SpringAwareUserTransaction.java:412)
   … 34 more
Caused by: org.hibernate.exception.ConstraintViolationException: Could not execute JDBC batch update
   … 35 more
   … 48 more
Here is the table DDL if that helps:
  CREATE TABLE "ALFRESCO_MYSQL"."ALF_TRANSACTION"
   (   "ID" NUMBER(19,0) NOT NULL ENABLE,
   "SERVER_ID" NUMBER(19,0),
   "CHANGE_TXN_ID" VARCHAR2(56 BYTE) NOT NULL ENABLE,
    CONSTRAINT "PRIMARY_4" PRIMARY KEY ("ID")
  USING INDEX PCTFREE 10 INITRANS 2 MAXTRANS 255 COMPUTE STATISTICS
  STORAGE(INITIAL 65536 NEXT 1048576 MINEXTENTS 1 MAXEXTENTS 2147483645
  PCTINCREASE 0 FREELISTS 1 FREELIST GROUPS 1 BUFFER_POOL DEFAULT)
  TABLESPACE "USERS"  ENABLE,
    CONSTRAINT "FKB8761A3A9AE340B7" FOREIGN KEY ("SERVER_ID")
     REFERENCES "ALFRESCO_MYSQL"."ALF_SERVER" ("ID") ENABLE
   ) PCTFREE 10 PCTUSED 40 INITRANS 1 MAXTRANS 255 NOCOMPRESS LOGGING
  TABLESPACE "USERS" ;
  CREATE INDEX "ALFRESCO_MYSQL"."FKB8761A3A9AE340B7" ON "ALFRESCO_MYSQL"."ALF_TRANSACTION" ("SERVER_ID")
  CREATE UNIQUE INDEX "ALFRESCO_MYSQL"."PRIMARY_4" ON "ALFRESCO_MYSQL"."ALF_TRANSACTION" ("ID")
  CREATE OR REPLACE TRIGGER "ALFRESCO_MYSQL"."ALF_TRANSACTION_ID_TRG" BEFORE INSERT OR UPDATE ON alf_transaction
FOR EACH ROW
BEGIN
  if inserting and :new.ID is NULL then
  SELECT alf_transaction_ID_SEQ.nextval into :new.ID FROM DUAL;
  end if;
END;
ALTER TRIGGER "ALFRESCO_MYSQL"."ALF_TRANSACTION_ID_TRG" ENABLE;
Here is the DDL for the alf_transaction sequence:
CREATE SEQUENCE  "ALFRESCO_MYSQL"."ALF_TRANSACTION_ID_SEQ"  MINVALUE 28 MAXVALUE 999999999999999999999999 INCREMENT BY 1 START WITH 28 CACHE 20 NOORDER  NOCYCLE ;
The last entry in the ID column of ALF_TRANSACTION is 28 so can't see a problem there…
derek
The sequence used in Oracle is a single sequence called hibernate_sequence.  You can discard all other sequences and make sure that the one has a min value greater than any ID value across all the tables.
It's a pain…
gjw
Yes that did the trick. I misunderstood what you had meant in your earlier post and was checking the table specific sequence previously. All good now, but agree that is a pain. Would that info be worth adding to the wiki?Thanks.
gjw
Unfortunately seem to have some other error post -migration with a scheduled clean up task…
09:17:15,992 ERROR [org.alfresco.repo.avm.OrphanReaper] Garbage collector error
org.hibernate.ObjectNotFoundException: No row with the given identifier exists: [org.alfresco.repo.avm.AVMNodeImpl#6265]
            at org.hibernate.ObjectNotFoundException.throwIfNull(ObjectNotFoundException.java:27)
            at org.hibernate.proxy.AbstractLazyInitializer.initialize(AbstractLazyInitializer.java:65)
            at org.hibernate.proxy.AbstractLazyInitializer.getImplementation(AbstractLazyInitializer.java:98)
            at org.hibernate.proxy.CGLIBLazyInitializer.intercept(CGLIBLazyInitializer.java:158)
            at org.alfresco.repo.avm.PlainFileNode$$EnhancerByCGLIB$$7ee5d04a.setAncestor(<generated>)
            at org.alfresco.repo.avm.OrphanReaper$1TxnWork.doWork(OrphanReaper.java:290)
            at org.alfresco.repo.transaction.TransactionUtil.executeInTransaction(TransactionUtil.java:176)
            at org.alfresco.repo.avm.OrphanReaper.doBatch(OrphanReaper.java:340)
            at org.alfresco.repo.avm.OrphanReaper.run(OrphanReaper.java:213)
derek
The Wiki is freely editable  :wink:
