12-05-2007 08:39 AM
10:25:16,702 WARN [org.springframework.remoting.rmi.RmiRegistryFactoryBean] Could not detect RMI registry - creating new one
10:25:21,451 INFO [org.alfresco.repo.domain.schema.SchemaBootstrap] Schema managed by database dialect org.hibernate.dialect.MySQLInnoDBDialect.
10:25:24,247 INFO [org.alfresco.repo.domain.schema.SchemaBootstrap] No changes were made to the schema.
10:25:26,559 INFO [org.alfresco.repo.admin.ConfigurationChecker] The Alfresco root data directory ('dir.root') is: D:programmeAlfresco2.0alf_data
10:25:26,653 ERROR [org.alfresco.repo.admin.ConfigurationChecker] CONTENT INTEGRITY ERROR: Indexes not found for 5 stores.
10:25:26,653 INFO [org.alfresco.repo.admin.ConfigurationChecker] You may set 'index.recovery.mode=FULL' if you need to rebuild the indexes.
10:25:26,668 ERROR [org.alfresco.repo.admin.ConfigurationChecker] Ensure that the 'dir.root' property is pointing to the correct data location.
10:25:26,668 ERROR [org.springframework.web.context.ContextLoader] Context initialization failed
org.alfresco.error.AlfrescoRuntimeException: Ensure that the 'dir.root' property is pointing to the correct data location.
at org.alfresco.repo.admin.ConfigurationChecker.check(ConfigurationChecker.java:312)
11:35:46,920 INFO [org.alfresco.repo.node.index.FullIndexRecoveryComponent] Index recovery started: 388 transactions.
11:35:50,764 INFO [org.alfresco.repo.node.index.FullIndexRecoveryComponent] 10 % complete.
11:35:51,279 INFO [org.alfresco.repo.node.index.FullIndexRecoveryComponent] 20 % complete.
11:35:51,701 INFO [org.alfresco.repo.node.index.FullIndexRecoveryComponent] 30 % complete.
11:35:52,436 INFO [org.alfresco.repo.node.index.FullIndexRecoveryComponent] 40 % complete.
11:35:53,123 INFO [org.alfresco.repo.node.index.FullIndexRecoveryComponent] 50 % complete.
11:35:53,748 INFO [org.alfresco.repo.node.index.FullIndexRecoveryComponent] 60 % complete.
11:35:54,373 INFO [org.alfresco.repo.node.index.FullIndexRecoveryComponent] 70 % complete.
11:35:55,139 INFO [org.alfresco.repo.node.index.FullIndexRecoveryComponent] 80 % complete.
11:35:55,967 INFO [org.alfresco.repo.node.index.FullIndexRecoveryComponent] 90 % complete.
11:35:56,670 INFO [org.alfresco.repo.node.index.FullIndexRecoveryComponent] 100 % complete.
11:35:56,686 INFO [org.alfresco.repo.node.index.FullIndexRecoveryComponent] Index recovery completed.
11:36:41,484 ERROR [org.springframework.web.context.ContextLoader] Context initialization failed
org.alfresco.error.AlfrescoRuntimeException: Unknown Exception in Transaction.
at org.alfresco.repo.transaction.RetryingTransactionHelper.doInTransaction(RetryingTransactionHelper.java:292)
at org.alfresco.repo.transaction.RetryingTransactionHelper.doInTransaction(RetryingTransactionHelper.java:155)
at org.alfresco.repo.node.index.AbstractReindexComponent.reindex(AbstractReindexComponent.java:220)
at org.alfresco.repo.node.index.IndexRecoveryBootstrapBean.onBootstrap(IndexRecoveryBootstrapBean.java:35)
at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:3763)
at org.apache.catalina.core.StandardContext.start(StandardContext.java:4211)
at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:809)
at org.apache.catalina.startup.HostConfig.deployWARs(HostConfig.java:698)
at org.apache.catalina.core.StandardServer.start(StandardServer.java:709)
Caused by: javax.transaction.RollbackException: Transaction didn't commit: Class definition status does not exist.
at org.alfresco.util.transaction.SpringAwareUserTransaction.commit(SpringAwareUserTransaction.java:430)
at org.alfresco.repo.transaction.RetryingTransactionHelper.doInTransaction(RetryingTransactionHelper.java:239)
… 37 more
Caused by: org.alfresco.repo.policy.PolicyException: Class definition status does not exist.
at org.alfresco.repo.policy.ClassBehaviourBinding.generaliseBinding(ClassBehaviourBinding.java:90)
at org.alfresco.repo.policy.ClassBehaviourIndex.find(ClassBehaviourIndex.java:148)
at org.alfresco.repo.policy.ClassBehaviourIndex.find(ClassBehaviourIndex.java:44)
at org.alfresco.repo.policy.PolicyFactory.createList(PolicyFactory.java:119)
at org.alfresco.repo.policy.CachedPolicyFactory.createList(CachedPolicyFactory.java:166)
at org.alfresco.repo.policy.PolicyFactory.create(PolicyFactory.java:105)
at org.alfresco.repo.policy.CachedPolicyFactory.create(CachedPolicyFactory.java:117)
at org.alfresco.repo.policy.ClassPolicyDelegate.getList(ClassPolicyDelegate.java:182)
at org.alfresco.repo.policy.ClassPolicyDelegate.get(ClassPolicyDelegate.java:157)
at org.alfresco.repo.content.RoutingContentService.getReader(RoutingContentService.java:372)
at org.alfresco.repo.content.RoutingContentService.getReader(RoutingContentService.java:308)
at org.alfresco.repo.search.impl.lucene.ADMLuceneIndexerImpl.indexProperty(ADMLuceneIndexerImpl.java:781)
at org.alfresco.repo.search.impl.lucene.ADMLuceneIndexerImpl.createDocuments(ADMLuceneIndexerImpl.java:546)
at org.alfresco.repo.search.impl.lucene.AbstractLuceneIndexerImpl.indexImpl(AbstractLuceneIndexerImpl.java:631)
at org.alfresco.repo.search.impl.lucene.AbstractLuceneIndexerImpl.indexImpl(AbstractLuceneIndexerImpl.java:656)
at org.alfresco.repo.search.impl.lucene.AbstractLuceneIndexerImpl.flushPending(AbstractLuceneIndexerImpl.java:788)
at org.alfresco.repo.search.impl.lucene.ADMLuceneIndexerImpl.doPrepare(ADMLuceneIndexerImpl.java:1337)
at org.alfresco.repo.search.impl.lucene.AbstractLuceneIndexerImpl.prepare(AbstractLuceneIndexerImpl.java:471)
at org.alfresco.repo.search.impl.lucene.AbstractLuceneIndexerAndSearcherFactory.prepare(AbstractLuceneIndexerAndSearcherFactory.java:679)
at org.alfresco.repo.transaction.AlfrescoTransactionSupport$TransactionSynchronizationImpl.beforeCommit(AlfrescoTransactionSupport.java:634)
at org.springframework.transaction.support.TransactionSynchronizationUtils.triggerBeforeCommit(TransactionSynchronizationUtils.java:48)
at org.springframework.transaction.support.AbstractPlatformTransactionManager.triggerBeforeCommit(AbstractPlatformTransactionManager.java:821)
at org.springframework.transaction.support.AbstractPlatformTransactionManager.processCommit(AbstractPlatformTransactionManager.java:637)
at org.springframework.transaction.support.AbstractPlatformTransactionManager.commit(AbstractPlatformTransactionManager.java:624)
at org.springframework.transaction.interceptor.TransactionAspectSupport.commitTransactionAfterReturning(TransactionAspectSupport.java:307)
at org.alfresco.util.transaction.SpringAwareUserTransaction.commit(SpringAwareUserTransaction.java:420)
… 38 more
11:36:41,484 ERROR [org.apache.catalina.core.ContainerBase.[Catalina].[localhost].[/alfresco]] Exception sending context initialized event to listener instance of class org.springframework.web.context.ContextLoaderListener
… 37 more
… 38 more
11:36:41,562 ERROR [org.apache.catalina.core.ContainerBase.[Catalina].[localhost].[/alfresco]] Exception sending context initialized event to listener instance of class org.alfresco.web.app.ContextListener
… 37 more
… 38 more
index.recovery.mode=VALIDATE
the following exception comes:13:38:44,324 INFO [org.alfresco.repo.domain.schema.SchemaBootstrap] No changes were made to the schema.
13:38:46,872 INFO [org.alfresco.repo.node.index.IndexRecoveryBootstrapBean] Checking/Recovering indexes …
13:38:46,872 DEBUG [org.alfresco.repo.node.index.FullIndexRecoveryComponent] Performing index recovery for type: VALIDATE
13:38:46,872 DEBUG [org.alfresco.repo.node.index.AbstractReindexComponent] Checking for transaction in index: 393
13:38:46,872 DEBUG [org.alfresco.repo.node.index.AbstractReindexComponent] Transaction 393 has 1 updates and 0 deletes.
13:38:46,950 DEBUG [org.alfresco.repo.node.index.AbstractReindexComponent] Transaction 393 not in index for store archive://SpacesStore. Possibly out of date.
13:38:46,950 DEBUG [org.alfresco.repo.node.index.AbstractReindexComponent] Index has results for txn 393 for store system://system
13:38:46,950 DEBUG [org.alfresco.repo.node.index.AbstractReindexComponent] Transaction 393 present in indexes: YES
13:38:46,950 DEBUG [org.alfresco.repo.node.index.AbstractReindexComponent] Reindex work completed: org.alfresco.repo.node.index.FullIndexRecoveryComponent@801919
13:38:46,950 INFO [org.alfresco.repo.node.index.IndexRecoveryBootstrapBean] Checking/Recovering indexes …
13:38:46,965 DEBUG [org.alfresco.repo.node.index.AbstractReindexComponent] Reindex work completed: org.alfresco.repo.node.index.AVMFullIndexRecoveryComponent@1ad44f6
13:38:46,965 DEBUG [org.alfresco.repo.admin.ConfigurationChecker] Starting bootstrap configuration check: ConfigurationChecker[indexRecoveryMode=VALIDATE]
13:38:46,965 INFO [org.alfresco.repo.admin.ConfigurationChecker] The Alfresco root data directory ('dir.root') is: D:\programme\Alfresco2.0\programmeAlfresco2.0alf_data
13:38:46,965 DEBUG [org.alfresco.repo.admin.ConfigurationChecker] Checking index for store: archive://SpacesStore
13:38:46,965 DEBUG [org.alfresco.repo.admin.ConfigurationChecker] Index missing for store:
13:38:46,965 DEBUG [org.alfresco.repo.admin.ConfigurationChecker] Checking index for store: system://system
13:38:46,981 DEBUG [org.alfresco.repo.admin.ConfigurationChecker] Index missing for store:
13:38:46,981 DEBUG [org.alfresco.repo.admin.ConfigurationChecker] Checking index for store: user://alfrescoUserStore
13:38:46,981 DEBUG [org.alfresco.repo.admin.ConfigurationChecker] Checking index for store: workspace://lightWeightVersionStore
13:38:46,997 DEBUG [org.alfresco.repo.admin.ConfigurationChecker] Index missing for store:
13:38:46,997 DEBUG [org.alfresco.repo.admin.ConfigurationChecker] Checking index for store: workspace://SpacesStore
13:38:47,012 ERROR [org.alfresco.repo.admin.ConfigurationChecker] CONTENT INTEGRITY ERROR: Indexes not found for 5 stores.
13:38:47,012 INFO [org.alfresco.repo.admin.ConfigurationChecker] You may set 'index.recovery.mode=FULL' if you need to rebuild the indexes.
13:38:47,043 ERROR [org.alfresco.repo.admin.ConfigurationChecker] Ensure that the 'dir.root' property is pointing to the correct data location.
13:38:47,043 ERROR [org.springframework.web.context.ContextLoader] Context initialization failed
at org.alfresco.repo.admin.ConfigurationChecker.access$000(ConfigurationChecker.java:72)
at org.alfresco.repo.admin.ConfigurationChecker$1.execute(ConfigurationChecker.java:178)
at org.alfresco.repo.transaction.RetryingTransactionHelper.doInTransaction(RetryingTransactionHelper.java:225)
at org.alfresco.repo.admin.ConfigurationChecker.onBootstrap(ConfigurationChecker.java:182)
13:38:47,059 ERROR [org.apache.catalina.core.ContainerBase.[Catalina].[localhost].[/alfresco]] Exception sending context initialized event to listener instance of class org.springframework.web.context.ContextLoaderListener
13:38:47,059 ERROR [org.apache.catalina.core.ContainerBase.[Catalina].[localhost].[/alfresco]] Exception sending context initialized event to listener instance of class org.alfresco.web.app.ContextListener
dir.root=D:\\programme\\Alfresco2.0\\programmeAlfresco2.0alf_data
12-10-2007 02:34 AM
12-10-2007 05:07 AM
The dir.root property is:That's your problem then.dir.root=D:\\programme\\Alfresco2.0\\programmeAlfresco2.0alf_data
dir.root=D:/programme/Alfresco2.0/programmeAlfresco2.0alf_data
12-10-2007 08:05 AM
and the same exception was thrown as I described above:13:48:06,699 ERROR [org.alfresco.repo.admin.ConfigurationChecker] CONTENT INTEGRITY ERROR: Indexes not found for 5 stores.
13:48:06,699 INFO [org.alfresco.repo.admin.ConfigurationChecker] You may set 'index.recovery.mode=FULL' if you need to rebuild the indexes.
13:48:06,699 ERROR [org.alfresco.repo.admin.ConfigurationChecker] Ensure that the 'dir.root' property is pointing to the correct data location.
13:48:06,714 ERROR [org.springframework.web.context.ContextLoader] Context initialization failed
the indexes will be recovered successfully and after then the org.alfresco.error.AlfrescoRuntimeException: Unknown Exception in Transaction. still exists.
12-10-2007 09:19 AM
12-10-2007 09:52 AM
12-10-2007 10:18 AM
12-10-2007 10:33 AM
12-12-2007 02:27 AM
12-17-2007 03:24 AM
