CIFS 'phantom files' problem
fschnell
During daily usage my colleague Dave made the following observation regarding CIFS. It is a repeatable, but random problem. We end up in a situation where files are visible in CIFS but not they actually do not exist anymore. Access via CIFS is not possible (file does not exist) an in the webinterface they do not show (as expected).
Can anyone confirm this to be a problem? How can we circumvent that?
Frank
The Background
I have set up three Spaces in my area on Alfresco.
     Distillery
     PDF
     Done
I have set up a Rule in the Distillery Space where any file arriving
there is transformed into pdf, and the pdf file placed in the PDF Space. I
have set the Rule to run in the background. I can then, using the CIFS interface, drag multiple files into the Distillery Space for batch conversion. This is much faster than using Adobe and needs far less user intervention.
Deletion from Spaces is generally very slow. So, following conversion
and copying the pdf files to where they are needed, I drag all the files
from both the Distillery and PDF spaces into the Done Space. I delete
these later, when I have more time. [Of course, it would be very nice if I could set up a Rule to do this deletion, as a background process]
I then drag and drop a further batch of files into the Distillery Space -
and so on.
Typically, the batches for conversion will be two to twelve files.
Most of these files are MS Word files but occasionally they are Excel, or
other MS Office files.
The Problem
Occasionally, having dragged and dropped files from the PDF space
into Done, I will return to the PDF Space and find that they still appear to be there. However, any attempt to open them, delete them or move them will result in an error message of the 'File Cannot be Found' variety. Using the HTML interface, the Space can be seen to be empty, but CIFS is still
showing the files and no amount of refreshing, or re-connecting to the drive will make them disappear. Similarly, these files are not visible in the Done Space using CIFS but using the HTML interface, I can see that they are, in fact, there.
I can still drag and drop new files into the Distillery Space and they will
still be converted to pdf and appear in the PDF space alongside the 'phantom' files. However, it seems to me that the process now takes longer than before. These new pdf files can be opened, deleted or moved as normal.
If I then use the HTML interface to delete the pdf files from where
they really are in the Done Space, I can watch them disappear, one by one from the CIFS view of the PDF Space.
Possibly a Second Problem
This may not be related, but sometimes, in similar circumstances, I
will find that I am prevented by CIFS from re-entering the PDF Space,
being told that I have no rights in that Space. However, I can still enter the PDF Space via the HTML interface. I am also allowed to rename or delete the Space via the HTML interface, so that's what I do at this point but, of course, I then also have to delete and recreate the Rule because, even though the new space has the same name as the old one, Alfresco sees it as a different Space.
The only thing I can offer as to the circumstances of occurrences of these
problems is that it always follows a period of intense use of the Alfresco
server i.e. moving and converting a large number of files in a short period. Also, I have never had this problem with any Space other than one that is target for a Rule.
Dave
14 REPLIES 14
fschnell
We tried the Webdav interface in the community 2.0 version:
"…and the space that I cannot access via CIFS gives the error
=An error occurred whilst generating the directory listing, please contact the system administrator.=
using WebDav."
In the other space, the Phantom Files appear to be there, but give the error when I try opening them
HTTP Status 404 -
type Status report
message
description The requested resource () is not available.
Apache Tomcat/5.5.20
It appears to us, as if the web client shows the true picture while CIFS, FTP and Webdav do not.
Hope that helps.
Frank
fschnell
In the meantime we installed 2.1 RC and after two days intensive tries we were not able to reproduce this error.
simon
Same problem here with Alfresco 1.4.3 Enterprise. We have a space that is not accessible via CIFS, FTP or WebDAV but using the web client we can access it. Same permission error as fschnell but it's not security related as even the administrator users get this problem.
simon
For futher reference: rebuilding the indexes did the trick, it's working again. I set the option to VALIDATE, so let's hope I don't have to rebuild the whole bunch when this happens again.
Anyone knows when this happens? My database is set to InnoDB so I thought there would be a rollback when something went wrong?
rdanner
We use CIFS extensively every day and I have not seen or heard about this issue.  I can confirm that there are weird behaviors in CIFS and FTP while the full index is running – but that should not be happening in a production environment.
