HELP :-)
testingit
Is there a way to get NODE ID by it's path , ie:
input: /PATH/TO/DIR123/FILE.DOC
output: 282af6f5-508c-11dc-800c-d5564c95a581
testingit
I can't find the solution by myself, maybe someone can look and help ?
10x!
rdanner
FileFolderService offers the following API
resolveNamePath [Source]
FileInfo resolveNamePath(NodeRef rootNodeRef,
                         java.util.List<java.lang.String> pathElements)
                         throws FileNotFoundException
    Resolve a file or folder name path from a given root node down to the final node.
    Parameters:
        rootNodeRef - the start of the path given, i.e. the '/' in '/A/B/C' for example
        pathElements - a list of names in the path
    Returns:
        Returns the info of the file or folder
    Throws:
        FileNotFoundException - if no file or folder exists along the path
from there you get a FileInfo from which you can obtain a NodeRef from which you can obtain a node ID
