03-05-2010 09:40 PM
06-01-2010 02:44 PM
06-01-2010 04:57 PM
06-01-2010 09:03 PM
21:01:51,133 INFO [org.alfresco.config.JndiPropertiesFactoryBean] Loading properties file from class path resource [alfresco/repository.properties]
21:01:51,153 INFO [org.alfresco.config.JndiPropertiesFactoryBean] Loading properties file from class path resource [alfresco/domain/transaction.properties]
21:01:51,153 INFO [org.alfresco.config.JndiPropertiesFactoryBean] Loading properties file from URL [file:/usr/local/alfresco/tomcat/shared/classes/alfresco-global.properties]
21:01:51,261 INFO [org.alfresco.config.JndiPropertyPlaceholderConfigurer] Loading properties file from class path resource [alfresco/alfresco-shared.properties]
21:01:55,591 WARN [org.hibernate.cfg.SettingsFactory] Could not obtain connection metadata
org.apache.commons.dbcp.SQLNestedException: Cannot create PoolableConnectionFactory (Communications link failure
The last packet sent successfully to the server was 0 milliseconds ago. The driver has not received any packets from the server.)
at org.apache.commons.dbcp.BasicDataSource.createDataSource(BasicDataSource.java:1225)
at org.apache.commons.dbcp.BasicDataSource.getConnection(BasicDataSource.java:880)
at org.springframework.orm.hibernate3.LocalDataSourceConnectionProvider.getConnection(LocalDataSourceConnectionProvider.java:81)
at org.hibernate.cfg.SettingsFactory.buildSettings(SettingsFactory.java:84)
at org.hibernate.cfg.Configuration.buildSettings(Configuration.java:2073)
at org.hibernate.cfg.Configuration.buildSessionFactory(Configuration.java:1298)
at org.springframework.orm.hibernate3.LocalSessionFactoryBean.newSessionFactory(LocalSessionFactoryBean.java:805)
at org.springframework.orm.hibernate3.LocalSessionFactoryBean.buildSessionFactory(LocalSessionFactoryBean.java:745)
at org.springframework.orm.hibernate3.AbstractSessionFactoryBean.afterPropertiesSet(AbstractSessionFactoryBean.java:134)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeInitMethods(AbstractAutowireCapableBeanFactory.java:1203)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1172)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:427)
at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:249)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:155)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:246)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:160)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:267)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:110)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyPropertyValues(AbstractAutowireCapableBeanFactory.java:1100)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:862)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:423)
at org.springframework.aop.framework.ProxyFactoryBean.freshTargetSource(ProxyFactoryBean.java:546)
at org.springframework.aop.framework.ProxyFactoryBean.getSingletonInstance(ProxyFactoryBean.java:291)
at org.springframework.aop.framework.ProxyFactoryBean.getObject(ProxyFactoryBean.java:228)
at org.springframework.beans.factory.support.AbstractBeanFactory.getObjectFromFactoryBean(AbstractBeanFactory.java:1246)
at org.springframework.beans.factory.support.AbstractBeanFactory.getObjectForBeanInstance(AbstractBeanFactory.java:1217)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:260)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.getBeansOfType(DefaultListableBeanFactory.java:248)
at org.springframework.context.support.AbstractApplicationContext.getBeansOfType(AbstractApplicationContext.java:820)
at org.springframework.context.support.AbstractApplicationContext.registerListeners(AbstractApplicationContext.java:597)
Caused by: com.mysql.jdbc.exceptions.jdbc4.CommunicationsException: Communications link failure
at com.mysql.jdbc.Util.handleNewInstance(Util.java:409)
at com.mysql.jdbc.SQLError.createCommunicationsException(SQLError.java:1122)
at com.mysql.jdbc.ConnectionImpl.createNewIO(ConnectionImpl.java:2260)
at com.mysql.jdbc.ConnectionImpl.<init>(ConnectionImpl.java:787)
at com.mysql.jdbc.JDBC4Connection.<init>(JDBC4Connection.java:49)
at com.mysql.jdbc.ConnectionImpl.getInstance(ConnectionImpl.java:357)
at com.mysql.jdbc.NonRegisteringDriver.connect(NonRegisteringDriver.java:285)
at org.apache.commons.dbcp.DriverConnectionFactory.createConnection(DriverConnectionFactory.java:38)
at org.apache.commons.dbcp.PoolableConnectionFactory.makeObject(PoolableConnectionFactory.java:294)
at org.apache.commons.dbcp.BasicDataSource.validateConnectionFactory(BasicDataSource.java:1247)
at org.apache.commons.dbcp.BasicDataSource.createDataSource(BasicDataSource.java:1221)
… 117 more
at com.mysql.jdbc.MysqlIO.<init>(MysqlIO.java:344)
at com.mysql.jdbc.ConnectionImpl.createNewIO(ConnectionImpl.java:2181)
… 130 more
Caused by: java.net.ConnectException: Connection refused
at java.net.PlainSocketImpl.socketConnect(Native Method)
at java.net.PlainSocketImpl.doConnect(PlainSocketImpl.java:333)
at java.net.PlainSocketImpl.connectToAddress(PlainSocketImpl.java:195)
at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:182)
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:366)
at java.net.Socket.connect(Socket.java:525)
at java.net.Socket.connect(Socket.java:475)
at java.net.Socket.<init>(Socket.java:372)
at java.net.Socket.<init>(Socket.java:215)
at com.mysql.jdbc.StandardSocketFactory.connect(StandardSocketFactory.java:256)
at com.mysql.jdbc.MysqlIO.<init>(MysqlIO.java:293)
… 131 more
06-02-2010 04:13 AM
06-03-2010 02:27 PM
# hosts This file describes a number of hostname-to-address
# mappings for the TCP/IP subsystem. It is mostly
# used at boot time, when no name servers are running.
# On small systems, this file can be used instead of a
# "named" name server. Just add the names, addresses
# and any aliases to this file…
# By the way, Arnt Gulbrandsen <[email protected]> says that 127.0.0.1
# should NEVER be named with the name of the machine. It causes problems
# for some (stupid) programs, irc and reputedly talk. :^)
# For loopbacking.
127.0.0.1 localhost
127.0.0.1 lhost2.ldomain276 lhost2
# End of hosts.
telnet lhost2 3306 will giveTrying 192.168.0.101…
Connected to lhost2.
Escape character is '^]'.
8
5.0.84-log(#96D3qbv,LUIN+,8uh')6Connection closed by foreign host.telnet localhost 3306 will giveTrying 127.0.0.1…
Connected to localhost.
8
5.0.84-log)I|X!<H6u,j6lA=LJjZccGConnection closed by foreign host.06-07-2010 03:17 AM
06-07-2010 07:14 AM
06-12-2010 11:20 PM
06-13-2010 03:32 PM
