I am using alfresco-community-war-3.2r2 with tomcat6 on Centos5.4. Alfresco is working fine as war file on tomcat but when I try to integrate it with our existing ldap server its not working.
I need to ask two things?
1. I cant find any alfresco.log fine. Should it be created by default ?
2. May be my configuration files are not in right place. When I was installing alfresco I had to move "alfresco-global.properties" /opt/tomcat/shared/classes/alfresco/extension/alfresco-global.properties to /opt/tomcat/lib/alfresco-global.properties
When I moved into /opt/tomcat/lib it worked.
I read from few forums and again I created a soft link of /opt/tomcat/webapps/alfresco/WEB-INF/classes/alfresco/subsystems in /opt/tomcat/shared/classes/alfresco/extension/subsystems
Here is my ldap-authentication.properties configuration # cat /opt/tomcat/shared/classes/alfresco/extension/subsystems/Authentication/ldap/ldap-authentication.properties
## I created a new user SVC_ALF in ldap and trying to login with that user I have tried (SVC_ALF, and [email protected]) but both dont work.
ldap.synchronization.active=false ldap.synchronization.java.naming.security.principal=SVC_ALF # I dont know whether this line needed or not ldap.synchronization.java.naming.security.credentials=abc123 # I dont know whether this line needed or not
Note: this file "ldap-authentication.properties" had other lines for ldap.synchronization which I commented.
Now tomcat comes up with alfresco but I can see these errors in catalina.out and I cant login to ldap server.
12:05:38,374 INFO [management.subsystems.ChildApplicationContextFactory] Starting 'Authentication' subsystem, ID: [Authentication, managed, alfrescoNtlm1] 12:05:38,400 INFO [alfresco.config.JndiPropertyPlaceholderConfigurer] Loading properties file from class path resource [alfresco/alfresco-shared.properties] 12:05:38,515 INFO [management.subsystems.ChildApplicationContextFactory] Startup of 'Authentication' subsystem, ID: [Authentication, managed, alfrescoNtlm1] complete 12:05:43,653 ERROR [org.alfresco.fileserver] Failed to get local domain/workgroup name, using default of WORKGROUP 12:05:43,653 ERROR [org.alfresco.fileserver] (This may be due to firewall settings or incorrect <broadcast> setting) 12:05:43,697 INFO [management.subsystems.ChildApplicationContextFactory] Startup of 'fileServers' subsystem, ID: [fileServers, default] complete 12:05:43,697 INFO [management.subsystems.ChildApplicationContextFactory] Starting 'imap' subsystem, ID: [imap, default] 12:05:43,708 ERROR [org.alfresco.fileserver] [SMB] Server error : org.alfresco.jlan.server.config.InvalidConfigurationException: Error initializing TCP-IP SMB session handler, Permission denied 12:05:43,709 ERROR [org.alfresco.fileserver] org.alfresco.jlan.server.config.InvalidConfigurationException: Error initializing TCP-IP SMB session handler, Permission denied 12:05:43,709 ERROR [org.alfresco.fileserver] at org.alfresco.jlan.smb.server.nio.NIOCifsConnectionsHandler.initializeHandler(NIOCifsConnectionsHandler.java:265) 12:05:43,710 ERROR [org.alfresco.fileserver] at org.alfresco.jlan.smb.server.SMBServer.run(SMBServer.java:478) 12:05:43,710 ERROR [org.alfresco.fileserver] at java.lang.Thread.run(Thread.java:619) 12:05:43,730 INFO [alfresco.config.JndiPropertyPlaceholderConfigurer] Loading properties file from class path resource [alfresco/alfresco-shared.properties] 12:05:43,763 ERROR [org.alfresco.fileserver] [FTP] FTP Socket error : java.net.BindException: Permission denied 12:05:43,795 ERROR [org.alfresco.fileserver] java.net.BindException: Permission denied 12:05:43,795 ERROR [org.alfresco.fileserver] at java.net.PlainSocketImpl.socketBind(Native Method) 12:05:43,795 ERROR [org.alfresco.fileserver] at java.net.PlainSocketImpl.bind(PlainSocketImpl.java:365) 12:05:43,795 ERROR [org.alfresco.fileserver] at java.net.ServerSocket.bind(ServerSocket.java:319) 12:05:43,795 ERROR [org.alfresco.fileserver] at java.net.ServerSocket.<init>(ServerSocket.java:185) 12:05:43,795 ERROR [org.alfresco.fileserver] at java.net.ServerSocket.<init>(ServerSocket.java:141) 12:05:43,795 ERROR [org.alfresco.fileserver] at org.alfresco.jlan.ftp.FTPServer.run(FTPServer.java:561) 12:05:43,795 ERROR [org.alfresco.fileserver] at java.lang.Thread.run(Thread.java:619)
I will really appreciate for any suggestions please.
Lets take in this way to troubleshoot where exactly the issue is ??
I have disabled the following in "/opt/alfresco/tomcat/shared/classes/alfresco/extension/subsystems/Authentication/ldap/ldap1/ldap-authentication.properties" file ldap.synchronization.active=false
For me I think when tomcat restart it loads the same file and get the Authentication complete messages.
11:47:13,020 INFO [alfresco.config.JndiPropertiesFactoryBean] Loading properties file from file [/opt/alfresco/tomcat/shared/classes/alfresco/extension/subsystems/Authentication/ldap/ldap1/ldap-authentication.properties] 11:47:24,653 INFO [domain.schema.SchemaBootstrap] Schema managed by database dialect org.hibernate.dialect.MySQLInnoDBDialect.
11:47:31,892 Userystem INFO [management.subsystems.ChildApplicationContextFactory] Starting 'Authentication' subsystem, ID: [Authentication, managed, ldap1] 11:47:31,915 Userystem INFO [alfresco.config.JndiPropertyPlaceholderConfigurer] Loading properties file from class path resource [alfresco/alfresco-shared.properties] 11:47:31,974 Userystem INFO [management.subsystems.ChildApplicationContextFactory] Startup of 'Authentication' subsystem, ID: [Authentication, managed, ldap1] complete 11:47:31,974 Userystem INFO [management.subsystems.ChildApplicationContextFactory] Starting 'Authentication' subsystem, ID: [Authentication, managed, alfrescoNtlm1] 11:47:31,995 Userystem INFO [alfresco.config.JndiPropertyPlaceholderConfigurer] Loading properties file from class path resource [alfresco/alfresco-shared.properties] 11:47:32,098 Userystem INFO [management.subsystems.ChildApplicationContextFactory] Startup of 'Authentication' subsystem, ID: [Authentication, managed, alfrescoNtlm1] complete 11:47:32,105 INFO [management.subsystems.ChildApplicationContextFactory] Startup of 'Synchronization' subsystem, ID: [Synchronization, default] complete 11:47:32,278 INFO [service.descriptor.DescriptorService] Alfresco JVM - v1.6.0_18-b07; maximum heap size 1979.750MB 11:47:32,278 INFO [service.descriptor.DescriptorService] Alfresco started (Community): Current version 3.2.0 (r2 2440) schema 3300 - Originally installed version 3.2.0 (r2 2440) schema 3300
When I stop tomcat I see the following messages in log
12:02:19,160 INFO [management.subsystems.ChildApplicationContextFactory] Stopping 'Authentication' subsystem, ID: [Authentication, managed, ldap1] 12:02:19,160 INFO [management.subsystems.ChildApplicationContextFactory] Stopped 'Authentication' subsystem, ID: [Authentication, managed, ldap1]
Is there a way I can get debug log like when i enter user-name/password in alfresco home page what happens exactly? Can we configure a log like that? I have seen many comments on alfresco.log but in my system I can't find alfresco.log. Any help with this?
Any idea to solve this issue will highly be appreciated.
