alfresco 5.0c and kerberos
vincent-kali
I'm facing issues to setup kerberos authentication against 2008R2 AD
domain controller on an Alfresco Community 5c platform (on linux debian 7).
I followed the procedure that we applied on alf 4.2, which was working fine.
I made the following:
- create services accounts on AD (alfrescoCIFS & alfrescoHTTP), with correct settings (SPN, UPN, disable Kerberos preauth)
- create keytab files and put it on alfresco server
- create krb5.conf on alfresco server with correct settings
- test kerberos auth from alfresco server (using krb5-user MIT tools)
   >  kinit cifs/myhostname.mydomain.loc@MYDOMAIN.LOC -k -t /etc/keys/keytab
-> success. It should confirm that AD, keytab and krb5.conf configurations are correct. Am'I correct ?
Configure auth chain, CIFS, Kerberos auth in alfresco-global.properties
           ### auth chain   authentication.chain=kerberos1:kerberos,myDomain:ldap-ad,alfrescoNtlm1:alfrescoNtlm      ### ldap auth   ldap.authentication.active=true   ldap.authentication.allowGuestLogin=false   ldap.authentication.userNameFormat=%s@mydomain.loc   ldap.authentication.java.naming.provider.url=ldap://x.x.x.x   ldap.authentication.java.naming.security.authentication=simple   ldap.authentication.defaultAdministratorUserNames=admin      ### KERBEROS auth   kerberos.authentication.realm=MYDOMAIN.LOC   kerberos.authentication.authenticateCIFS=true   kerberos.authentication.sso.enabled=false   kerberos.authentication.user.configEntryName=Alfresco   kerberos.authentication.defaultAdministratorUserNames=admin   kerberos.authentication.cifs.configEntryName=alfrescoCIFS   kerberos.authentication.cifs.password=****************   kerberos.authentication.http.configEntryName=alfrescoHTTP   kerberos.authentication.http.password=****************   kerberos.authentication.browser.ticketLogons=true   kerberos.authentication.stripUsernameSuffix=true      ### ldap sync   ldap.synchronization.active=true   ldap.synchronization.java.naming.security.authentication=simple   ldap.synchronization.java.naming.security.principal=svc-ldapsync@mydomain.loc   ldap.synchronization.java.naming.security.credentials=****************   ldap.synchronization.groupSearchBase=ou\=Groups,dc\=MYDOMAIN,dc=loc   ldap.synchronization.userSearchBase=ou\=Users,dc\=MYDOMAIN,dc=loc   ldap.synchronization.personDifferentialQuery=(&(objectclass\=user)(userAccountControl\:1.2.840.113556.1.4.803\:\=512)(!(whenChanged<\={0})))      ### CIFS-NFS-FTP   filesystem.name=WCM   cifs.enabled=true   cifs.serverName=myhostname   cifs.domain=mydomain.loc   cifs.hostannounce=false   cifs.pseudoFiles.enabled=false   cifs.pseudoFiles.explorerURL.enabled=false   cifs.pseudoFiles.explorerURL.fileName=__Alfresco.url   cifs.pseudoFiles.shareURL.enabled=false   cifs.pseudoFiles.shareURL.fileName=__Share.url   ftp.enabled=false   nfs.enabled=false‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
Now the JAAS config :
- update the /opt/alfresco-5.0.c/java/lib/security/java.security file and add following line:
   login.config.url.1=file:${java.home}/lib/security/java.login.config
- create java.login.config file
         Alfresco {   com.sun.security.auth.module.Krb5LoginModule sufficient;   };      alfrescoCIFS {   com.sun.security.auth.module.Krb5LoginModule required   storeKey=true   useKeyTab=true   doNotPrompt=true   keyTab="/etc/keys/keytab"   principal="cifs/myhostname.mydomain.loc";   };   alfrescoHTTP {   com.sun.security.auth.module.Krb5LoginModule required   storeKey=true   useKeyTab=true   doNotPrompt=true   keyTab="/etc/keys/keytab"   principal="HTTP/myhostname.mydomain.loc";   };   com.sun.net.ssl.client {   com.sun.security.auth.module.Krb5LoginModule sufficient;   };      other {   com.sun.security.auth.module.Krb5LoginModule sufficient;   };‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
Restart Alfresco
-> seems to be OK:  INFO  [management.subsystems.ChildApplicationContextFactory] [localhost-startStop-1] Starting 'Authentication' subsystem, ID: [Authentication, managed, kerberos1]
The problem:
When trying to access to alfresco using CIFS, I get a 'logon failure' on my windows client, and following output in catalina.out:
      2015-02-06 15:14:48,630  ERROR [org.alfresco.fileserver] [AlfJLANWorker18] Error from JLAN
    GSSException: Failure unspecified at GSS-API level (Mechanism level: Specified version of key is not available (44))
         at sun.security.jgss.krb5.Krb5Context.acceptSecContext(Unknown Source)
         at sun.security.jgss.GSSContextImpl.acceptSecContext(Unknown Source)
         at org.alfresco.jlan.server.auth.kerberos.SessionSetupPrivilegedAction.run(SessionSetupPrivilegedAction.java:102)
         at javax.security.auth.Subject.doAs(Unknown Source)
         at org.alfresco.filesys.auth.cifs.EnterpriseCifsAuthenticator.doKerberosLogon(EnterpriseCifsAuthenticator.java:1536)
         at org.alfresco.filesys.auth.cifs.EnterpriseCifsAuthenticator.doSpnegoSessionSetup(EnterpriseCifsAuthenticator.java:1420)
         at org.alfresco.filesys.auth.cifs.EnterpriseCifsAuthenticator.access$200(EnterpriseCifsAuthenticator.java:87)
         at org.alfresco.filesys.auth.cifs.EnterpriseCifsAuthenticator$2.execute(EnterpriseCifsAuthenticator.java:897)
         at org.alfresco.filesys.auth.cifs.EnterpriseCifsAuthenticator$2.execute(EnterpriseCifsAuthenticator.java:881)
         at org.alfresco.repo.transaction.RetryingTransactionHelper.doInTransaction(RetryingTransactionHelper.java:454)
         at org.alfresco.filesys.auth.cifs.CifsAuthenticatorBase.doInTransaction(CifsAuthenticatorBase.java:641)
         at org.alfresco.filesys.auth.cifs.EnterpriseCifsAuthenticator.processAlfrescoSessionSetup(EnterpriseCifsAuthenticator.java:880)
         at org.alfresco.filesys.auth.cifs.EnterpriseCifsAuthenticator.processSessionSetup(EnterpriseCifsAuthenticator.java:682)
         at org.alfresco.repo.management.subsystems.ChainingSubsystemProxyFactory$1.invoke(ChainingSubsystemProxyFactory.java:112)
         at com.sun.proxy.$Proxy188.processSessionSetup(Unknown Source)
         at org.alfresco.jlan.smb.server.NTProtocolHandler.procSessionSetup(NTProtocolHandler.java:417)
         at org.alfresco.jlan.smb.server.NTProtocolHandler.runProtocol(NTProtocolHandler.java:223)
         at org.alfresco.jlan.smb.server.SMBSrvSession.processPacket(SMBSrvSession.java:1480)
         at org.alfresco.jlan.smb.server.nio.NIOCIFSThreadRequest.runRequest(NIOCIFSThreadRequest.java:150)
         at org.alfresco.jlan.server.thread.ThreadRequestPool$ThreadWorker.run(ThreadRequestPool.java:153)
   Caused by: KrbException: Specified version of key is not available (44)
         at sun.security.krb5.EncryptionKey.findKey(Unknown Source)
         at sun.security.krb5.KrbApReq.authenticate(Unknown Source)
         at sun.security.krb5.KrbApReq.<init>(Unknown Source)
         at sun.security.jgss.krb5.InitSecContextToken.<init>(Unknown Source)
         … 29 more
   2015-02-06 15:14:48,633  ERROR [auth.cifs.EnterpriseCifsAuthenticator] [AlfJLANWorker18] No SPNEGO response, Kerberos logon failed
    2015-02-06 15:14:48,834  ERROR [org.alfresco.fileserver] [AlfJLANWorker19] Error from JLAN
         … 29 more
   2015-02-06 15:14:48,837  ERROR [auth.cifs.EnterpriseCifsAuthenticator] [AlfJLANWorker19] No SPNEGO response, Kerberos logon failed
    2015-02-06 15:14:48,854  ERROR [org.alfresco.fileserver] [AlfJLANWorker20] Error from JLAN
         … 29 more
   2015-02-06 15:14:48,857  ERROR [auth.cifs.EnterpriseCifsAuthenticator] [AlfJLANWorker20] No SPNEGO response, Kerberos logon failed
I dont't understand the cause of this error "Specified version of key is not available", as kvno between AD and keytab are matching, and kerberos
auth has been tested successfully using kinit. Could somebody help me ?
Vincent
17 REPLIES 17
vincent-kali
After further analysis, I see that :
- Alfresco is getting the initial TGT correctly for CIFS at startup
- User fails to get TGS for alfresco with error KRB5KDC_ERR_BADOPTION 'STATUS_NOT_SUPPORTED'
any suggestion ?
really nobody can help ?
thanks
Issue has been identified on AD side.
Tricky problem: mixed upper/lowercase in the domain name, and consequently in the Kerberos TGS (refused by alfresco JAAS).
No easy solution at this time.
Vincent.
vincent-kali
After digging out Kerberos and AD, I finally found that the problem was (again) a kvno issue.
conclusions:
-  kinit does NOT validate the keytab file, even if you use it as parameter as it requests to get a TGT. kvno is not checked at this step (it does validate the Kerberos config only - krb5.conf)
-  you need to check the kvno on AD U&C directly, parameters (constructed): msDS-KeyVersionNumber
Vincent
Would you please send me the settings for you installation?
could you please give me some details about the settings you want me to send ?
as explain above the issue is solved (kvno issue), but I'm of course ready to
share everything you need if it can help….
borisstankov
Well, I can see those error messeges in the catalina.out:
2015-04-07 11:22:18,591  DEBUG [app.servlet.KerberosAuthenticationFilter] [http-apr-8080-exec-5] Authentication not required (filter), chaining …
2015-04-07 11:22:18,658  DEBUG [app.servlet.KerberosAuthenticationFilter] [http-apr-8080-exec-10] Authentication not required (filter), chaining …
2015-04-07 11:22:18,674  DEBUG [app.servlet.KerberosAuthenticationFilter] [http-apr-8080-exec-1] Authentication not required (filter), chaining …
2015-04-07 11:22:18,691  DEBUG [app.servlet.KerberosAuthenticationFilter] [http-apr-8080-exec-3] Authentication not required (filter), chaining …
2015-04-07 11:22:18,697  DEBUG [app.servlet.KerberosAuthenticationFilter] [http-apr-8080-exec-6] Authentication not required (filter), chaining …
2015-04-07 11:22:18,720  DEBUG [app.servlet.KerberosAuthenticationFilter] [http-apr-8080-exec-2] Authentication not required (filter), chaining …
2015-04-07 11:22:19,264  DEBUG [app.servlet.KerberosAuthenticationFilter] [http-apr-8080-exec-7] Authentication not required (filter), chaining …
2015-04-07 11:22:19,272  DEBUG [app.servlet.KerberosAuthenticationFilter] [http-apr-8080-exec-9] Authentication not required (filter), chaining …
2015-04-07 11:22:20,093  DEBUG [app.servlet.KerberosAuthenticationFilter] [http-apr-8080-exec-5] New Kerberos auth request from 192.168.192.240 (192.168.192.240:50747)
2015-04-07 11:22:20,093  DEBUG [app.servlet.KerberosAuthenticationFilter] [http-apr-8080-exec-5] Issuing login challenge to browser.
2015-04-07 11:22:20,660  DEBUG [webdav.auth.KerberosAuthenticationFilter] [http-apr-8080-exec-1] Performing fallback authentication…
2015-04-07 11:22:20,697  DEBUG [webdav.auth.KerberosAuthenticationFilter] [http-apr-8080-exec-1] Issuing login challenge to browser.
2015-04-07 11:22:20,698  DEBUG [webdav.auth.KerberosAuthenticationFilter] [http-apr-8080-exec-1] Fallback authentication failed. Restarting login…
11:22:20,699 WARN  [org.alfresco.wcm.client.util.impl.GuestSessionFactoryImpl] WQS unable to connect to repository: Unauthorized
At this time my browser asks me about my password in a loop and never goes our of it.
I edited: global.properties files with:
kerberos.authentication.realm=CORP.INT
kerberos.authentication.sso.enabled=true
kerberos.authentication.authenticateCIFS=false
kerberos.authentication.cifs.password=Password123!
kerberos.authentication.cifs.configEntryName=AlfrescoCIFS
kerberos.authentication.http.password=Password123!
kerberos.authentication.http.configEntryName=AlfrescoHTTP
Also I edited the /opt/alfresco-5.0/tomcat/shared/classes/alfresco/web-extension/share-config-custom.xml as expalined here: http://docs.alfresco.com/community/tasks/auth-kerberos-shareSSO.html
I have this configs in my JAVA_OPTS which are located in this file :
JAVA_HOME=/opt/alfresco-5.0/javaJRE_HOME=$JAVA_HOMEJAVA_OPTS="-XX:+DisableExplicitGC -Djava.awt.headless=true -Dalfresco.home=/opt/alfresco-5.0 -Dcom.sun.management.jmxremote -Dsun.security.krb5.msinterop.kstring=true -XX:ReservedCodeCacheSize=128m $JAVA_OPTS "JAVA_OPTS="-XX:MaxPermSize=5120M -Xms4096M -Xmx5120M $JAVA_OPTS " # java-memory-settingsexport JAVA_HOMEexport JRE_HOMEexport JAVA_OPTS‍‍‍‍‍‍‍‍‍
THose are the configs for my /etc/krb5.conf file (the DOMAIN is my domain and it's the correct one in the real file):
[logging]
default = FILE:/var/log/krb5libs.log
kdc = FILE:/var/log/krb5kdc.log
admin_server = FILE:/var/log/kadmind.log
[libdefaults]
default_realm = DOMAIN
dns_lookup_realm = false
dns_lookup_kdc = false
ticket_lifetime = 24h
renew_lifetime = 7d
default_tkt_enctypes = rc4-hmac
default_tgs_enctypes = rc4-hmac
forwardable = true
proxiable = true
[realms]
DOMAIN= {
  kdc = dc1.domain
  admin_server = dc1.domain
[domain_realm]
.corp.int = DOMAIN
corp.int = DOMAIN
Both keyfiles are location in the /etc dir.
I created a file java.login.config under here:/opt/alfresco-5.0/java/lib/security with the following code (system.domain = my alfresco fqdn):
Alfresco {        com.sun.security.auth.module.Krb5LoginModule sufficient;    };    AlfrescoCIFS {        com.sun.security.auth.module.Krb5LoginModule required        storeKey=true        useKeyTab=true        keyTab="/etc/cifsportal2.keytab"        principal="cifs/system.domain";    };    AlfrescoHTTP {        com.sun.security.auth.module.Krb5LoginModule required        storeKey=true        useKeyTab=true        keyTab="/etc/httpportal2.keytab"        principal="HTTP/system.domain";    };    ShareHTTP {        com.sun.security.auth.module.Krb5LoginModule required        storeKey=true        useKeyTab=true        keyTab="/etc/httpportal2.keytab"        principal="HTTP/system.domain";    };    com.sun.net.ssl.client {        com.sun.security.auth.module.Krb5LoginModule sufficient;    };    other {        com.sun.security.auth.module.Krb5LoginModule sufficient;    };‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
I also edited the java.security file in the same dir by adding this line:
Do you have any idea if I'm missing some and I should add it, or I setup some of the setting not in the right way?
Regards!
Could you first validate your SSO Kerberos config using CIFS (you'll bypass all possible misconfiguration on the client browser) ?
Are you running Alfresco on Linux ?
Here are the main steps to follow: (Assuming your KDC is an MS AD DC)
- Service account creation with correct UPN/SPN
- Linux Keberos client config (krb5.conf)
- Test Kinit (krb5-user package on debian) to check that authentication is correct
   -> kinit -V cifs/alfrescoserver.mydomain.loc@MYDOMAIN.LOC
- Generate keytab (with correct kvno !!)
   -> I'm using ktpass on linux. Check service account's kvno on AD (attribute msDS-KeyVersionNumber, don't forget to show 'constructed' user attributes on AD Users&Computers)
- Test Kinit using keytab
   -> kinit -V cifs/alfrescoserver.mydomain.loc@MYDOMAIN.LOC -k -t myKeytabFile
Could you confirm you did this successfully ? (I'll post my alf config soon if you need).
Vincent
You assumed correctly.
My alfresco version 5.0.c is on centOS 6.5 and our MS AD is on Windows Server 2012.
Thanks for the notes you sent, we checked them closely with our team here. At this point:
kinit -V cifs/alfrescoserver.mydomain.loc@MYDOMAIN.LOC ->>> this one was Authorized, but
kinit -V cifs/alfrescoserver.mydomain.loc@MYDOMAIN.LOC -k -t myKeytabFile ->>> this one failed
Then we generated the keytabs with the correct knvo. It was version 4, but generated it with 0 at first.
Now both commands are returning the Authozired:
However I'm still not able to use the single-sign on authentication and I can't login to alfresco using this type of authentication. here is what I can see now in the "catalina.out":
Apr 08, 2015 11:50:21 AM org.apache.catalina.startup.Catalina start
INFO: Server startup in 139796 ms
2015-04-08 11:50:21,763  WARN  [scripts.solr.AlfrescoModelsDiff] [http-bio-8443-exec-2] Unable to fetch model changes from /alfresco/service/api/solr/modelsdiff
2015-04-08 11:50:21,768  WARN  [scripts.solr.AlfrescoModelsDiff] [http-bio-8443-exec-1] Unable to fetch model changes from /alfresco/service/api/solr/modelsdiff
2015-04-08 11:50:22,233  DEBUG [webdav.auth.KerberosAuthenticationFilter] [http-apr-8080-exec-2] Performing fallback authentication…
Apr 08, 2015 11:50:22 AM org.apache.catalina.core.StandardWrapperValve invoke
SEVERE: Servlet.service() for servlet [cmisatom10] in context with path [/alfresco] threw exception
org.alfresco.service.namespace.InvalidQNameException: A QName must consist of a local name
   at org.alfresco.service.namespace.QName.createQName(QName.java:87)
   at org.alfresco.repo.security.person.PersonServiceImpl.getChildNameLower(PersonServiceImpl.java:1768)
   at org.alfresco.repo.security.person.PersonServiceImpl.getPersonOrNullImpl(PersonServiceImpl.java:537)
   at org.alfresco.repo.security.person.PersonServiceImpl.getUserIdentifier(PersonServiceImpl.java:1880)
   at org.alfresco.repo.security.authentication.AuthenticationComponentImpl$1$1.doWork(AuthenticationComponentImpl.java:93)
   at org.alfresco.repo.security.authentication.AuthenticationComponentImpl$1$1.doWork(AuthenticationComponentImpl.java:90)
   at org.alfresco.repo.tenant.TenantUtil.runAsWork(TenantUtil.java:119)
   at org.alfresco.repo.tenant.TenantUtil.runAsTenant(TenantUtil.java:88)
   at org.alfresco.repo.tenant.TenantUtil$1.doWork(TenantUtil.java:62)
   at org.alfresco.repo.security.authentication.AuthenticationUtil.runAs(AuthenticationUtil.java:548)
   at org.alfresco.repo.tenant.TenantUtil.runAsUserTenant(TenantUtil.java:58)
   at org.alfresco.repo.tenant.TenantUtil.runAsSystemTenant(TenantUtil.java:112)
   at org.alfresco.repo.security.authentication.AuthenticationComponentImpl$1.execute(AuthenticationComponentImpl.java:89)
   at org.alfresco.repo.security.authentication.AuthenticationComponentImpl$1.execute(AuthenticationComponentImpl.java:86)
   at org.alfresco.repo.transaction.RetryingTransactionHelper.doInTransaction(RetryingTransactionHelper.java:342)
   at org.alfresco.repo.security.authentication.AuthenticationComponentImpl.authenticateImpl(AuthenticationComponentImpl.java:84)
   at org.alfresco.repo.security.authentication.AbstractAuthenticationComponent.authenticate(AbstractAuthenticationComponent.java:162)
   at org.alfresco.repo.security.authentication.AuthenticationServiceImpl.authenticate(AuthenticationServiceImpl.java:68)
   at org.alfresco.repo.security.authentication.AbstractChainingAuthenticationService.authenticate(AbstractChainingAuthenticationService.java:195)
   at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:317)
   at org.springframework.transaction.interceptor.TransactionInterceptor$1.proceedWithInvocation(TransactionInterceptor.java:96)
   at org.springframework.transaction.interceptor.TransactionAspectSupport.invokeWithinTransaction(TransactionAspectSupport.java:260)
   at org.springframework.transaction.interceptor.TransactionInterceptor.invoke(TransactionInterceptor.java:94)
   at com.sun.proxy.$Proxy64.authenticate(Unknown Source)
   at org.alfresco.repo.webdav.auth.SSOFallbackBasicAuthenticationDriver.authenticateRequest(SSOFallbackBasicAuthenticationDriver.java:120)
   at org.alfresco.repo.webdav.auth.BaseSSOAuthenticationFilter.performFallbackAuthentication(BaseSSOAuthenticationFilter.java:604)
   at org.alfresco.repo.webdav.auth.BaseKerberosAuthenticationFilter.authenticateRequest(BaseKerberosAuthenticationFilter.java:279)
   at org.alfresco.repo.webdav.auth.BaseSSOAuthenticationFilter.doFilter(BaseSSOAuthenticationFilter.java:155)
   at com.sun.proxy.$Proxy274.doFilter(Unknown Source)
   at org.alfresco.repo.web.filter.beans.BeanProxyFilter.doFilter(BeanProxyFilter.java:82)
   at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241)
   at org.alfresco.web.app.servlet.CmisSecurityContextCleanerFilter.doFilter(CmisSecurityContextCleanerFilter.java:49)
   at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:220)
   at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:122)
   at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:501)
   at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:170)
   at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:98)
   at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:950)
   at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1040)
   at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:607)
   at org.apache.tomcat.util.net.AprEndpoint$SocketWithOptionsProcessor.run(AprEndpoint.java:2378)
<b>
11:50:22,377 WARN  [org.alfresco.wcm.client.util.impl.GuestSessionFactoryImpl] WQS unable to connect to repository: Internal Server Error
2015-04-08 11:50:24,388  DEBUG [webdav.auth.KerberosAuthenticationFilter] [http-apr-8080-exec-3] Performing fallback authentication…
</b>
All the BEST!
vincent-kali
Hi
Sorry for the delay I was in vacation…
To be honest I never tried Kerberos SSO for HTTP with share (does not make sense for us as users needs to log on from the Internet).
I know that you need to configure extra things for HTTP SSO like delegation on AD.
Do you have the opportunity to test Kerberos SSO using on CIFS connector ? (this may help to identify the source of the issue)
Vincent
