Afresco Lab 3 authentication issue
ptx
I install Afresco Lab 3 on redhat linux 5.2 Server and over that I installed alfresco-labs-tomcat-3Stable. when I use http://localhost:8080/share I get portal page but user "admin" password "admin" will not work. Its give below error
"The remote server may be unavailable or your authentication details have not been recognized."
10 REPLIES 10
jpv
I'm having a similar problem although with Solaris and not Linux.  My setup is described at:
http://wiki.alfresco.com/wiki/Installing_3.2_CE_on_Solaris_10_SPARC
I have not specified anything regarding authentication in the alfresco-global.properties file, any ideas?
Also, is my log4J debug settings in the alfresco-global.properties supposed to be ignored?
My log file:
19:37:39,091 INFO  [org.alfresco.config.JndiPropertiesFactoryBean] Loading properties file from class path resource [alfresco/repository.properties]
19:37:39,095 INFO  [org.alfresco.config.JndiPropertiesFactoryBean] Loading properties file from class path resource [alfresco/domain/transaction.properties]
19:37:39,095 INFO  [org.alfresco.config.JndiPropertiesFactoryBean] Loading properties file from URL [file:/u01/alfresco/tomcat/shared/classes/alfresco-global.properties]
19:37:39,326 INFO  [org.alfresco.config.JndiPropertyPlaceholderConfigurer] Loading properties file from class path resource [alfresco/alfresco-shared.properties]
19:38:15,908 INFO  [org.alfresco.repo.domain.schema.SchemaBootstrap] Schema managed by database dialect org.hibernate.dialect.MySQLInnoDBDialect.
19:38:20,864 INFO  [org.alfresco.repo.domain.schema.SchemaBootstrap] No changes were made to the schema.
19:38:27,174 INFO  [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Starting 'thirdparty' subsystem, ID: [default]
19:38:27,232 INFO  [org.alfresco.config.JndiPropertyPlaceholderConfigurer] Loading properties file from class path resource [alfresco/alfresco-shared.properties]
19:38:28,575 ERROR [org.alfresco.repo.content.transform.RuntimeExecutableContentTransformerWorker] Failed to start a runtime executable content transformer:
Execution result:
   os:         SunOS
   command:    [./bin/pdf2swf, -V]
   succeeded:  false
   exit code:  1
   out:
   err:        ./bin/pdf2swf: not found
19:38:28,840 WARN  [org.alfresco.util.OpenOfficeConnectionTester] An initial OpenOffice connection could not be established.
19:38:28,843 INFO  [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Startup of 'thirdparty' subsystem, ID: [default] complete
19:38:29,298 WARN  [org.alfresco.repo.admin.ConfigurationChecker] The Alfresco 'dir.root' property is set to a relative path './alf_data'.  'dir.root' should be overridden to point to a specific folder.
19:38:29,298 INFO  [org.alfresco.repo.admin.ConfigurationChecker] The Alfresco root data directory ('dir.root') is: ./alf_data
19:38:29,379 INFO  [org.alfresco.repo.admin.patch.PatchExecuter] Checking for patches to apply …
19:38:29,920 INFO  [org.alfresco.repo.admin.patch.PatchExecuter] No patches were required.
19:38:29,929 INFO  [org.alfresco.repo.module.ModuleServiceImpl] Found 0 module(s).
19:38:29,964 INFO  [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Starting 'fileServers' subsystem, ID: [default]
19:38:30,006 INFO  [org.alfresco.config.JndiPropertyPlaceholderConfigurer] Loading properties file from class path resource [alfresco/alfresco-shared.properties]
19:38:30,523 INFO  [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Starting 'Authentication' subsystem, ID: [managed, passthru1]
19:38:30,567 INFO  [org.alfresco.config.JndiPropertyPlaceholderConfigurer] Loading properties file from class path resource [alfresco/alfresco-shared.properties]
19:38:31,299 INFO  [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Startup of 'Authentication' subsystem, ID: [managed, passthru1] complete
19:38:31,370 INFO  [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Startup of 'fileServers' subsystem, ID: [default] complete
19:38:31,370 INFO  [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Starting 'imap' subsystem, ID: [default]
19:38:31,404 INFO  [org.alfresco.config.JndiPropertyPlaceholderConfigurer] Loading properties file from class path resource [alfresco/alfresco-shared.properties]
19:38:31,517 INFO  [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Startup of 'imap' subsystem, ID: [default] complete
19:38:31,517 INFO  [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Starting 'Synchronization' subsystem, ID: [default]
19:38:31,638 INFO  [org.alfresco.config.JndiPropertyPlaceholderConfigurer] Loading properties file from class path resource [alfresco/alfresco-shared.properties]
19:38:31,660 INFO  [org.alfresco.repo.management.subsystems.ChildApplicationContextFactory] Startup of 'Synchronization' subsystem, ID: [default] complete
19:38:31,703 INFO  [org.alfresco.service.descriptor.DescriptorService] Alfresco JVM - v1.5.0_17-b04; maximum heap size 458.688MB
19:38:31,704 WARN  [org.alfresco.service.descriptor.DescriptorService] Alfresco JVM - WARNING - maximum heap size 458.688MB is less than recommended 512MB
19:38:31,705 INFO  [org.alfresco.service.descriptor.DescriptorService] Alfresco started (Community): Current version 3.2.0 (2039) schema 2019 - Installed version 3.2.0 (2039) schema 2019
19:39:01,930 INFO  [org.alfresco.config.JBossEnabledWebApplicationContext] Refreshing org.alfresco.config.JBossEnabledWebApplicationContext@13ded55: display name [Root WebApplicationContext]; startup date [Wed Aug 26 19:39:01 SAST 2009]; root of context hierarchy
19:39:02,539 INFO  [org.alfresco.config.JBossEnabledWebApplicationContext] Bean factory for application context [org.alfresco.config.JBossEnabledWebApplicationContext@13ded55]: org.springframework.beans.factory.support.DefaultListableBeanFactory@19ac651
19:39:04,732 INFO  [org.alfresco.web.scripts.DeclarativeRegistry] Registered 24 Web Scripts (+0 failed), 26 URLs
19:39:04,774 INFO  [org.alfresco.web.scripts.AbstractRuntimeContainer] Initialised Presentation Web Script Container (in 524.4888ms)
19:39:05,046 INFO  [org.alfresco.web.scripts.DeclarativeRegistry] Registered 42 Web Scripts (+0 failed), 44 URLs
19:39:05,083 INFO  [org.alfresco.web.scripts.AbstractRuntimeContainer] Initialised WebFramework Web Script Container (in 299.4647ms)
19:39:05,176 INFO  [org.alfresco.web.site.FrameworkHelper] Successfully Initialized Web Framework
19:39:10,939 INFO  [org.alfresco.web.site.FrameworkHelper] Successfully Initialized Web Framework
