09-15-2023 07:35 AM
Caused by: java.lang.InterruptedException ... 18 more 2023-09-15T16:58:49,767 WARN [stream/introspectionPool-00,in:0,inCheckpoint:0,out:0,lastRead:1694777329767,lastTimer:0,wm:0,loop:17,rebalance assigned] [org.nuxeo.ecm.core.bulk.introspection.StreamIntrospectionComputation] Instance elected to introspect Nuxeo Stream activity 2023-09-15T16:58:50,731 WARN [main] [org.nuxeo.lib.stream.computation.log.ComputationPool] audit/writer: Timeout on wait for pool termination 2023-09-15T16:58:50,731 ERROR [audit/writerPool-00] [org.apache.kafka.clients.consumer.KafkaConsumer] [Consumer clientId=nuxeo-audit-writer-21, groupId=nuxeo-audit-writer] Failed to close coordinator org.apache.kafka.common.errors.InterruptException: java.lang.InterruptedException at org.apache.kafka.clients.consumer.internals.ConsumerNetworkClient.maybeThrowInterruptException(ConsumerNetworkClient.java:520) ~[kafka-clients-2.6.0.jar:?] at org.apache.kafka.clients.consumer.internals.ConsumerNetworkClient.poll(ConsumerNetworkClient.java:281) ~[kafka-clients-2.6.0.jar:?] at org.apache.kafka.clients.consumer.internals.ConsumerNetworkClient.poll(ConsumerNetworkClient.java:236) ~[kafka-clients-2.6.0.jar:?] at org.apache.kafka.clients.consumer.internals.ConsumerNetworkClient.poll(ConsumerNetworkClient.java:227) ~[kafka-clients-2.6.0.jar:?] at org.apache.kafka.clients.consumer.internals.ConsumerNetworkClient.awaitPendingRequests(ConsumerNetworkClient.java:338) ~[kafka-clients-2.6.0.jar:?] at org.apache.kafka.clients.consumer.internals.AbstractCoordinator.close(AbstractCoordinator.java:985) ~[kafka-clients-2.6.0.jar:?] at org.apache.kafka.clients.consumer.internals.ConsumerCoordinator.close(ConsumerCoordinator.java:895) ~[kafka-clients-2.6.0.jar:?] at org.apache.kafka.clients.consumer.KafkaConsumer.close(KafkaConsumer.java:2373) [kafka-clients-2.6.0.jar:?] at org.apache.kafka.clients.consumer.KafkaConsumer.close(KafkaConsumer.java:2340) [kafka-clients-2.6.0.jar:?] at org.apache.kafka.clients.consumer.KafkaConsumer.close(KafkaConsumer.java:2290) [kafka-clients-2.6.0.jar:?] at org.nuxeo.lib.stream.log.kafka.KafkaLogTailer.close(KafkaLogTailer.java:442) [nuxeo-stream-2021.1.19.jar:?] at org.nuxeo.lib.stream.computation.log.ComputationRunner.closeTailer(ComputationRunner.java:264) [nuxeo-stream-2021.1.19.jar:?] at org.nuxeo.lib.stream.computation.log.ComputationRunner.run(ComputationRunner.java:230) [nuxeo-stream-2021.1.19.jar:?] at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:515) [?:?] at java.util.concurrent.FutureTask.run(FutureTask.java:264) [?:?] at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128) [?:?] at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628) [?:?] at java.lang.Thread.run(Thread.java:834) [?:?] Caused by: java.lang.InterruptedException ... 18 more
Getting this error while starting the nuxeo
09-20-2023 04:28 AM
Are you on Windows, and are you trying to start the server using "nuxeoctl start" by any chance? If yes, can you try instead to use "nuxeoctl console"?
