01-30-2019 08:52 AM
After upgrade our nuxeo platform from 8.10 to 9.10. When we want to run our custom automations chains we got this exception:
****** chain ******
Parent Chain ID: CustomScriptedZippedMergedPDF
Name:
Exception: OperationException
Caught error: Not allowed. You must be administrator to use this operation
Caused by: org.nuxeo.ecm.automation.OperationException: Not allowed. You must be administrator to use this operation
****** Hierarchy calls ******
org.nuxeo.ecm.automation.core.operations.blob.BlobToFile
****** end sub chain ******
2019-01-30 12:54:04,429 ERROR [https-jsse-nio-0.0.0.0-8443-exec-8] [org.nuxeo.ecm.webengine.app.WebEngineExceptionMapper] org.nuxeo.ecm.core.api.NuxeoException: Failed to invoke operation: CustomScriptedZippedMergedPDF
at org.nuxeo.ecm.automation.server.jaxrs.ExecutableResource.doPost(ExecutableResource.java:87)
at sun.reflect.GeneratedMethodAccessor380.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Method.java:498)
at com.sun.jersey.spi.container.JavaMethodInvokerFactory$1.invoke(JavaMethodInvokerFactory.java:60)
at com.sun.jersey.server.impl.model.method.dispatch.AbstractResourceMethodDispatchProvider$ObjectOutInvoker._dispatch(AbstractResourceMethodDispatchProvider.java:258)
at com.sun.jersey.server.impl.model.method.dispatch.ResourceJavaMethodDispatcher.dispatch(ResourceJavaMethodDispatcher.java:75)
at com.sun.jersey.server.impl.uri.rules.HttpMethodRule.accept(HttpMethodRule.java:302)
at com.sun.jersey.server.impl.uri.rules.SubLocatorRule.accept(SubLocatorRule.java:137)
at com.sun.jersey.server.impl.uri.rules.RightHandPathRule.accept(RightHandPathRule.java:147)
at com.sun.jersey.server.impl.uri.rules.ResourceClassRule.accept(ResourceClassRule.java:108)
at com.sun.jersey.server.impl.uri.rules.RootResourceClassesRule.accept(RootResourceClassesRule.java:84)
at com.sun.jersey.server.impl.application.WebApplicationImpl._handleRequest(WebApplicationImpl.java:1542)
at com.sun.jersey.server.impl.application.WebApplicationImpl._handleRequest(WebApplicationImpl.java:1473)
at com.sun.jersey.server.impl.application.WebApplicationImpl.handleRequest(WebApplicationImpl.java:1419)
at com.sun.jersey.server.impl.application.WebApplicationImpl.handleRequest(WebApplicationImpl.java:1409)
at com.sun.jersey.spi.container.servlet.WebComponent.service(WebComponent.java:409)
at com.sun.jersey.spi.container.servlet.ServletContainer.service(ServletContainer.java:558)
at com.sun.jersey.spi.container.servlet.ServletContainer.service(ServletContainer.java:733)
at org.nuxeo.ecm.webengine.app.jersey.WebEngineServlet.containerService(WebEngineServlet.java:72)
at org.nuxeo.ecm.webengine.app.jersey.WebEngineServlet.service(WebEngineServlet.java:56)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:742)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:231)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166)
at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193)
at org.nuxeo.elasticsearch.ElasticSearchFilter.doFilter(ElasticSearchFilter.java:55)
at org.nuxeo.ecm.webengine.jaxrs.session.SessionCleanupFilter.run(SessionCleanupFilter.java:50)
at org.nuxeo.ecm.webengine.jaxrs.HttpFilter.doFilter(HttpFilter.java:49)
at org.nuxeo.ecm.webengine.app.WebEngineFilter$UnitOfWork.doFilter(WebEngineFilter.java:102)
at org.nuxeo.ecm.webengine.app.WebEngineFilter$UnitOfWork.access$100(WebEngineFilter.java:79)
at org.nuxeo.ecm.webengine.app.WebEngineFilter.doFilter(WebEngineFilter.java:76)
at org.nuxeo.ecm.webengine.jaxrs.context.RequestContextFilter.run(RequestContextFilter.java:48)
at org.nuxeo.ecm.webengine.app.HeaderFixFilter.run(HeaderFixFilter.java:62)
at org.nuxeo.ecm.core.management.jtajca.internal.Log4jWebFilter.doFilter(Log4jWebFilter.java:69)
at org.nuxeo.ecm.platform.web.common.requestcontroller.filter.NuxeoRequestControllerFilter.doFilter(NuxeoRequestControllerFilter.java:178)
at org.nuxeo.ecm.platform.ui.web.auth.NuxeoAuthenticationFilter.doFilterInternal(NuxeoAuthenticationFilter.java:626)
at org.nuxeo.ecm.platform.ui.web.auth.service.NuxeoAuthFilterChain.doFilter(NuxeoAuthFilterChain.java:51)
at org.nuxeo.ecm.platform.ui.web.auth.oauth.NuxeoOAuthFilter.doFilter(NuxeoOAuthFilter.java:122)
at org.nuxeo.ecm.platform.ui.web.auth.service.NuxeoAuthFilterChain.doFilter(NuxeoAuthFilterChain.java:49)
at org.nuxeo.ecm.platform.oauth2.NuxeoOAuth2Filter.doFilter(NuxeoOAuth2Filter.java:79)
at org.nuxeo.ecm.platform.ui.web.auth.NuxeoAuthenticationFilter.doFilter(NuxeoAuthenticationFilter.java:421)
at org.nuxeo.ecm.platform.web.common.exceptionhandling.NuxeoExceptionFilter.doFilter(NuxeoExceptionFilter.java:67)
at org.nuxeo.ecm.platform.web.common.encoding.NuxeoEncodingFilter.doFilter(NuxeoEncodingFilter.java:75)
at org.apache.catalina.core.ApplicationDispatcher.invoke(ApplicationDispatcher.java:728)
at org.apache.catalina.core.ApplicationDispatcher.processRequest(ApplicationDispatcher.java:467)
at org.apache.catalina.core.ApplicationDispatcher.doForward(ApplicationDispatcher.java:392)
at org.apache.catalina.core.ApplicationDispatcher.forward(ApplicationDispatcher.java:311)
at org.nuxeo.ecm.restapi.server.APIServlet.service(APIServlet.java:50)
at org.nuxeo.ecm.platform.web.common.requestcontroller.filter.NuxeoThreadTrackerFilter.doFilter(NuxeoThreadTrackerFilter.java:43)
at org.nuxeo.ecm.platform.web.common.requestcontroller.filter.NuxeoStandbyFilter.doFilter(NuxeoStandbyFilter.java:67)
at org.nuxeo.ecm.platform.ui.web.rest.FancyURLFilter.doFilter(FancyURLFilter.java:120)
at org.nuxeo.ecm.platform.web.common.requestcontroller.filter.NuxeoRequestControllerFilter.doFilter(NuxeoRequestControllerFilter.java:148)
at org.nuxeo.ecm.webdav.service.WIRequestFilter.doFilter(WIRequestFilter.java:61)
at com.thetransactioncompany.cors.CORSFilter.doFilter(CORSFilter.java:208)
at com.thetransactioncompany.cors.CORSFilter.doFilter(CORSFilter.java:274)
at org.nuxeo.ecm.platform.web.common.requestcontroller.filter.NuxeoCorsCsrfFilter.doFilter(NuxeoCorsCsrfFilter.java:163)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:199)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:96)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:478)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:140)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:81)
at org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:650)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:87)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:342)
at org.apache.coyote.http11.Http11Processor.service(Http11Processor.java:803)
at org.apache.coyote.AbstractProcessorLight.process(AbstractProcessorLight.java:66)
at org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:868)
at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1459)
at org.apache.tomcat.util.net.SocketProcessorBase.run(SocketProcessorBase.java:49)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at java.lang.Thread.run(Thread.java:748)
Caused by: org.nuxeo.ecm.automation.OperationException: Failed to invoke operation javascript.scriptedZippedMergedPDF
at org.nuxeo.ecm.automation.core.impl.InvokableMethod.invoke(InvokableMethod.java:188)
at org.nuxeo.ecm.automation.core.impl.OperationChainCompiler$OperationMethod.invoke(OperationChainCompiler.java:151)
at org.nuxeo.ecm.automation.core.impl.OperationChainCompiler$CompiledChainImpl.lambda$invoke$0(OperationChainCompiler.java:218)
at org.nuxeo.ecm.automation.OperationContext.call(OperationContext.java:328)
at org.nuxeo.ecm.automation.OperationContext.callWithChainParameters(OperationContext.java:293)
at org.nuxeo.ecm.automation.core.impl.OperationChainCompiler$CompiledChainImpl.invoke(OperationChainCompiler.java:215)
at org.nuxeo.ecm.automation.core.impl.OperationServiceImpl.run(OperationServiceImpl.java:115)
at org.nuxeo.ecm.automation.core.impl.OperationServiceImpl.lambda$run$0(OperationServiceImpl.java:105)
at org.nuxeo.ecm.automation.core.impl.OperationServiceImpl.run(OperationServiceImpl.java:105)
at org.nuxeo.ecm.automation.server.jaxrs.OperationResource.execute(OperationResource.java:58)
at org.nuxeo.ecm.automation.server.jaxrs.ExecutableResource.doPost(ExecutableResource.java:70)
... 130 more
Suppressed: java.lang.Throwable:
I tried to create an extension according to this https://doc.nuxeo.com/910/nxdoc/filtering-exposed-operations/ to avoid the exception but it does'nt work
<extension target="org.nuxeo.ecm.automation.server.AutomationServer" point="bindings">
<binding name="CustomScriptedMergedPDF" chain="true">
<administrator>false</administrator>
<secure>true</secure>
<groups>members</groups>
</binding>
<binding name="CustomScriptedZippedMergedPDF" chain="true">
</binding>
</extension>
Note : In my custom automation, I use
Blob.exportToFSand according nuxeo 8.10 upgrade => Only administrators can use Blob.ExportToFS (and its alias Blob.ToFile) operation. Otherwise an OperationException is thrown. So there is no way to override this change ?
Thanks for help
06-26-2019 02:59 PM
Assuming you are using this as part of an automation chain, you can login as administrator during the chain then log out again after this script is run. http
