Problem adding participants to a workflow
frangarciaguez_
Hello.
I am trying to start a workflow (serial or parallel), but when I am assigning the participants, I get an error, and the workflow doesn't start.
In the log I can see the following messages:
javax.servlet.ServletException: On requestURL ...
at org.nuxeo.ecm.platform.ui.web.rest.FancyURLFilter.doFilter(FancyURLFilter.java:152)
Caused by: javax.servlet.ServletException: [Error: null pointer: WorkflowVariables["participants"][(int)WorkflowVariables.index]]
[Near : {... WorkflowVariables["participant ....}]
[Line: 1, Column: 1]
	at javax.faces.webapp.FacesServlet.service(FacesServlet.java:659)
Caused by: javax.faces.el.EvaluationException: [Error: null pointer: WorkflowVariables["participants"][(int)WorkflowVariables.index]]
	at javax.faces.component.MethodBindingMethodExpressionAdapter.invoke(MethodBindingMethodExpressionAdapter.java:101)
Caused by: [Error: null pointer: WorkflowVariables["participants"][(int)WorkflowVariables.index]]
	at org.mvel2.optimizers.impl.refl.ReflectiveAccessorOptimizer.compileGetChain(ReflectiveAccessorOptimizer.java:427)
	at org.mvel2.optimizers.impl.refl.ReflectiveAccessorOptimizer.getCollectionProperty(ReflectiveAccessorOptimizer.java:774)
What can be the problem?
Thanks in advance!
Best regards.
4 REPLIES 4
Vladimir_Pasqui
Star Collaborator
Star Collaborator
Hi!
nathan1620_
This issue should have been fixed with HF1. I'm running into the same problem still. Maybe try one of these variations:
WorkflowVariables["participants"][WorkflowVariables["index"]]
WorkflowVariables["participants"][(int)WorkflowVariables["index"]]
None of them worked for me, but they might work for you. My issue is from the brackets around the index workflow variable expression, the expression itself works fine.
Instead of brackets have you tried WorkflowVariables["participants"].get(WorkflowVariables["index"]) or variations thereof?
I think for our purposes and how the workflow does its indexing/counting, the expression has to be of the form
