02-16-2015 01:15 PM
We're testing our Nuxeo 6.0 and we've detected that it doesn't clear the connection pool when we use Funkload to benchmark it. After a Funkload test against Nuxeo 6.0 the pool reach his limit and Nuxeo can not accept more connections, it throws an exception. After 20 minutes waiting the connection pool is full yet.
Nuxeo says that active connections is 20. I've configured in nuxeo.conf session.timeout=1, but it doesn't solve the problem.
Do you know why?
Thank you, Gabriel
02-17-2015 05:59 AM
I think latest Nuxeo versions may not be handling user sessions properly.
02-17-2015 09:27 AM
It only happens using Chrome o Firefox. If we add &conversationId=0NXMAIN10 to the URL open connections don't increment. IE9 adds that paramenter. Firefox and Chrome don't.
02-18-2015 03:32 AM
IdleTimeout set to zero was an error in our extension file.
02-18-2015 01:57 PM
Modifying datasouces-config.xml.nxftl did the trick for jdbc/nuxeo.
