04-25-2013 11:03 AM
We trying to use permanent link like this one "http://localhost/nuxeo/nxdoc/default/5e84c7a3-e40c-4152-9497-b0cfdb916a6a/view_documents" to access document on a "nuxeo-cap-5.6-tomcat" server, with HF15 and DM add-on.
We first test this possibility with a default authentification: it works as expected (direct access).
But, we need use CAS authentication and in this case, the permanent link doesn't work anymore ... It's for us an important issue because we need direct acces on task (workflow context) send via email to our users.
Is it a known problem ?
We've done tests on two differents "Centos (5.9 and 6.4)" servers:
In both case:
On one server (Centos 6.4, nuxeo-5.6-HF10), after a first connection and deconnection (without removing JSESSION cookie) to the plateform, the direct access on a document works even with a CAS access for authentication (the return URL is correct). No error message are seen (with a default log4j configuration).
On the other one (Centos 5.9, nuxeo-5.6-HF15), an access after a first connection and deconnection (without removing JSESSION cookie) doesn't work and an error message is sent in the log:
2013-04-25 14:26:49,819 ERROR [org.nuxeo.ecm.core.api.CoreSession] Permission 'Read' is not granted to 'invite' on document /default-domain/workspaces/niv2/dd (5e84c7a3-e40c-4152-9497-b0cfdb916a6a - Folder)
2013-04-25 14:26:49,821 ERROR [org.apache.catalina.core.ContainerBase.[Catalina].[localhost].[/nuxeo]] L'écouteur d'évènement de session (session event listener) a généré une exception java.lang.IllegalStateException: Please end the HttpSession via org.jboss.seam.web.Session.instance().invalidate()
at org.jboss.seam.contexts.Lifecycle.endSession(Lifecycle.java:221)
Thanks for your help
05-27-2013 12:29 PM
This should be fixed (works in my tests!) and available in the next hotfix (5.6-HF18).
06-03-2013 12:26 PM
06-03-2013 02:30 PM
For the curious, link to our second pb with CAS authentication and permanent links
06-04-2013 11:45 AM
My configuration is pretty much what's in the documentation except for the server names.
11-29-2013 05:21 AM
Hello, is this fixed and if yes can you please tell me what is the hotfix to begin with ?
11-29-2013 05:31 AM
01-14-2014 12:18 PM
Using CAS authentication with anonymous auth enabled, we've got the same problem( the return URL from CAS is appURL not the permanentlink ). This bug is still present in 5.8.
