ISSUE - RepositoryServiceComponent is unable to start when using Nuxeo with Oracle11g or 12C
06-02-2016 11:51 PM
I have fresh Nuxeo installed on RHEL7.1. Everything works fine when using along with MySQL/H2 platform; however, with Oracle I have got the 'RepositoryServiceComponent' starting failure.
The server.log generated from Nuxeo restarting process shows that some DB components (Procedure, Function, Trigger) cannot be deployed successfully while 'RepositoryServiceComponent' requires those components in starting process. I have to workaround by disabling the following nodes located inside ../nxserver/config/default-repository-config.xml which will allow the Nuxeo startup process to ignore those required DB components.
The server.log had been attached. Could someone guiding me whether I miss some configuration/ or this could potentially be the Nuxeo's bug?
Appreciate for all helps in advance.
