how can I solve problem about internationalization in an bundle
geekonspace
I'm developing an bundle using nuxeo ide and have one messages.property for internationalization, but when I tried deploy my bundle on server, it shows this error:
    2012-01-26 12:50:47,327 ERROR [org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor] java.io.IOException: Could not create C:\nuxeo-cap-5.5-tomcat-sdk\nxserver\nuxeo.war\WEB-INF\classes\messages.properties
	at org.nuxeo.runtime.deployment.preprocessor.install.commands.AppendCommand.exec(AppendCommand.java:75)
	at org.nuxeo.runtime.deployment.preprocessor.install.CommandProcessorImpl.exec(CommandProcessorImpl.java:49)
	at org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor.predeploy(DeploymentPreprocessor.java:279)
	at org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor.predeploy(DeploymentPreprocessor.java:246)
	at org.nuxeo.runtime.deployment.preprocessor.DeploymentPreprocessor.main(DeploymentPreprocessor.java:565)
	at org.nuxeo.runtime.tomcat.NuxeoDeployer.handleEvent(NuxeoDeployer.java:107)
	at org.nuxeo.runtime.tomcat.NuxeoDeployer.lifecycleEvent(NuxeoDeployer.java:53)
	at org.apache.catalina.core.StandardHost.start(StandardHost.java:722)
	at org.apache.catalina.startup.Catalina.start(Catalina.java:583)
Caused by: java.io.IOException: El sistema no puede encontrar la ruta especificada
	at java.io.WinNTFileSystem.createFileExclusively(Native Method)
	at java.io.File.createNewFile(File.java:883)
	at org.nuxeo.runtime.deployment.preprocessor.install.commands.AppendCommand.exec(AppendCommand.java:73)
I'm working on windows 7 64bit, nuxeo 5.5, tomcat
Julien_Carsique
Elite Collaborator
Elite Collaborator
The failing code is new File("C:\nuxeo-cap-5.5-tomcat-sdk\nxserver\nuxeo.war\WEB-INF\classes\messages.properties").createNewFile();.
The first issue is it shouldn't fail at creating it. Could you check if the file exist, and if not, if you can manually create it?
The second issue I don't understand is it should not try to create the file but append into it... why isn't the file already existing..? Maybe your bundle is started to early: adding "org.nuxeo.ecm.platform.lang" to the OSGI-INF/deployment-fragment.xml file will ensure it's deployed after the default translation files.
Julien_Carsique
Elite Collaborator
Elite Collaborator
Hi, thanks for your answer. About to
Maybe your WebEngine module is deployed after nuxeo-platform-lang, even without the require tag.<br>
