02-09-2018 05:25 AM
I am following below article to customize the Nuxeo WEB UI. Hope following page is up to date.
https://doc.nuxeo.com/nxdoc/web-ui-customization-tutorial/
After performing all steps, when I am trying to build maven project, getting following error. Can you confirm reference to http://maven.nuxeo.org/nexus/content/groups/public is correct as attached pom.xml (rename from txt to xml) is generated by sample nuxeo bootstrap
Can I request you to ask someone from your team to verify the same ?
[ERROR] [ERROR] Some problems were encountered while processing the POMs: [FATAL] Non-resolvable parent POM for org.nuxeo.websample:nuxeo-customization-sample-core:1.0-SNAPSHOT: Could not find artifact org.nuxeo.ecm.distribution:nuxeo-customization-sample:pom:9.3 in public (http://maven.nuxeo.org/nexus/content/groups/public) and 'parent.relativePath' points at wrong local POM @ line 4, column 11 @ [ERROR] The build could not read 1 project -> [Help 1] org.apache.maven.project.ProjectBuildingException: Some problems were encountered while processing the POMs: [FATAL] Non-resolvable parent POM for org.nuxeo.websample:nuxeo-customization-sample-core:1.0-SNAPSHOT: Could not find artifact org.nuxeo.ecm.distribution:nuxeo-customization-sample:pom:9.3 in public (http://maven.nuxeo.org/nexus/content/groups/public) and 'parent.relativePath' points at wrong local POM @ line 4, column 11
at org.apache.maven.project.DefaultProjectBuilder.build (DefaultProjectBuilder.java:382)
at org.apache.maven.graph.DefaultGraphBuilder.collectProjects (DefaultGraphBuilder.java:400)
at org.apache.maven.graph.DefaultGraphBuilder.getProjectsForMavenReactor (DefaultGraphBuilder.java:391)
at org.apache.maven.graph.DefaultGraphBuilder.build (DefaultGraphBuilder.java:78)
at org.apache.maven.DefaultMaven.buildGraph (DefaultMaven.java:511)
at org.apache.maven.DefaultMaven.doExecute (DefaultMaven.java:221)
at org.apache.maven.DefaultMaven.doExecute (DefaultMaven.java:194)
at org.apache.maven.DefaultMaven.execute (DefaultMaven.java:107)
at org.apache.maven.cli.MavenCli.execute (MavenCli.java:955)
at org.apache.maven.cli.MavenCli.doMain (MavenCli.java:290)
at org.apache.maven.cli.MavenCli.main (MavenCli.java:194)
at sun.reflect.NativeMethodAccessorImpl.invoke0 (Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke (NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke (DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke (Method.java:498)
at org.codehaus.plexus.classworlds.launcher.Launcher.launchEnhanced (Launcher.java:289)
at org.codehaus.plexus.classworlds.launcher.Launcher.launch (Launcher.java:229)
at org.codehaus.plexus.classworlds.launcher.Launcher.mainWithExitCode (Launcher.java:415)
at org.codehaus.plexus.classworlds.launcher.Launcher.main (Launcher.java:356)
[ERROR] [ERROR] The project org.nuxeo.websample:nuxeo-customization-sample-core:1.0-SNAPSHOT (E:\installed_apps\Nuxeo\bin\nuxeobundle\nuxeo-customization-sample\pom.xml) has 1 error [ERROR] Non-resolvable parent POM for org.nuxeo.websample:nuxeo-customization-sample-core:1.0-SNAPSHOT: Could not find artifact org.nuxeo.ecm.distribution:nuxeo-customization-sample:pom: 9.3 in public (http://maven.nuxeo.org/nexus/content/groups/public) and 'parent.relativePath' points at wrong local POM @ line 4, column 11 -> [Help 2] org.apache.maven.model.resolution.UnresolvableModelException: Could not find artifact org.nuxeo.ecm.distribution:nuxeo-customization-sample:pom:9.3 in public (http://maven.nuxeo.org/nexus/co ntent/groups/public) at org.apache.maven.project.ProjectModelResolver.resolveModel (ProjectModelResolver.java:197) at org.apache.maven.project.ProjectModelResolver.resolveModel (ProjectModelResolver.java:243) at org.apache.maven.model.building.DefaultModelBuilder.readParentExternally (DefaultModelBuilder.java:1051) at org.apache.maven.model.building.DefaultModelBuilder.readParent (DefaultModelBuilder.java:829) at org.apache.maven.model.building.DefaultModelBuilder.build (DefaultModelBuilder.java:331) at org.apache.maven.project.DefaultProjectBuilder.build (DefaultProjectBuilder.java:429) at org.apache.maven.project.DefaultProjectBuilder.build (DefaultProjectBuilder.java:398) at org.apache.maven.project.DefaultProjectBuilder.build (DefaultProjectBuilder.java:362) at org.apache.maven.graph.DefaultGraphBuilder.collectProjects (DefaultGraphBuilder.java:400) at org.apache.maven.graph.DefaultGraphBuilder.getProjectsForMavenReactor (DefaultGraphBuilder.java:391) at org.apache.maven.graph.DefaultGraphBuilder.build (DefaultGraphBuilder.java:78) at org.apache.maven.DefaultMaven.buildGraph (DefaultMaven.java:511) at org.apache.maven.DefaultMaven.doExecute (DefaultMaven.java:221) at org.apache.maven.DefaultMaven.doExecute (DefaultMaven.java:194) at org.apache.maven.DefaultMaven.execute (DefaultMaven.java:107) at org.apache.maven.cli.MavenCli.execute (MavenCli.java:955) at org.apache.maven.cli.MavenCli.doMain (MavenCli.java:290) at org.apache.maven.cli.MavenCli.main (MavenCli.java:194) at sun.reflect.NativeMethodAccessorImpl.invoke0 (Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke (NativeMethodAccessorImpl.java:62) at sun.reflect.DelegatingMethodAccessorImpl.invoke (DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke (Method.java:498)
