02-16-2015 04:01 PM
I've created a custom button on my infoview slideshow. This button is plugged to an automation chain that updates thé picture property : after clicking, the slideshow restarts from the first picture. Vert painfull when validating hindreds of docs. Any solution?
Regards
02-18-2015 10:19 AM
Also asked as [NXP-16540](https
09-14-2017 07:07 AM
We have the same problem in Nuxeo 7.10 (LTS2015), and we've seen that it occurs only with HTTPS. We have a server that we can access with or without HTTPS, and with HTTP it works, with HTTPS it gets stuck on the first picture.
09-15-2017 07:23 AM
We have fixed our problem, I guess it could be the same thing for you. The post is old, but just in case someone is experiencing the same problem:
Our problem was with our HTTPS configuration.
On file /etc/apache2/sites-available/nuxeo-ssl.conf we had set the header "nuxeo-virtual-host" like this: RequestHeader append nuxeo-virtual-host "https://oururl.com:443/"
We have removed the port (it is not necessary, as we already have put https, I guess).
Now infoview works. The Javascript code behind infoview tried to find the current URL in a list of all the URLs of the page, and it couldn't find it as current URL had no port, but the list was created using "nuxeo-virtual-host", which had 443 port.
