09-21-2016 04:08 AM
Even though maven build is successed, when run.sh is executed, error occurred.
I did the following steps
1) Install jdk 1.8 and apache-maven 3.3.9
I referenced Installing and configuring software | Alfresco Documentation
2) Create AIO project according to Creating an All-in-One (AIO) project (WARs) | Alfresco Documentation
After finishing number 11 "maven clean install ", I can see "Build success".
When I execute "./run.sh", error is occurred.
I attached error message.
Thank you very much for reading.
09-21-2016 11:29 AM
Are you behind a proxy? Can you navigate to Index of /groups/public/org/alfresco/alfresco-solr4/5.1.e ?
09-21-2016 11:29 AM
09-22-2016 07:55 AM
Yes, it may be because of bad network connection. When I did again with the good internet connection, this problem is solved. Thank you very much.
