04-13-2013 08:52 AM
2013-04-13 14:30:44 Commons Daemon procrun stderr initialized
apr 13, 2013 2:30:46 PM org.apache.catalina.core.AprLifecycleListener init
INFO: Loaded APR based Apache Tomcat Native library 1.1.24 using APR version 1.4.6.
INFO: APR capabilities: IPv6 [true], sendfile [true], accept filters [false], random [true].
apr 13, 2013 2:30:47 PM org.apache.catalina.core.AprLifecycleListener initializeSSL
INFO: OpenSSL successfully initialized (OpenSSL 1.0.1c 10 May 2012)
apr 13, 2013 2:30:48 PM org.apache.coyote.AbstractProtocol init
INFO: Initializing ProtocolHandler ["http-apr-8081"]
INFO: Initializing ProtocolHandler ["ajp-apr-8009"]
INFO: Initializing ProtocolHandler ["http-bio-8443"]
apr 13, 2013 2:30:48 PM org.apache.catalina.startup.Catalina load
INFO: Initialization processed in 3122 ms
apr 13, 2013 2:30:49 PM org.apache.catalina.core.StandardService startInternal
apr 13, 2013 2:30:49 PM org.apache.catalina.core.StandardEngine startInternal
INFO: Starting Servlet Engine: Apache Tomcat/7.0.30
apr 13, 2013 2:30:49 PM org.apache.catalina.startup.HostConfig deployDescriptor
INFO: Deploying configuration descriptor C:\Alfresco\tomcat\conf\Catalina\localhost\solr.xml
apr 13, 2013 2:30:49 PM org.apache.catalina.startup.SetContextPropertiesRule begin
WARNING: [SetContextPropertiesRule]{Context} Setting property 'debug' to '0' did not find a matching property.
apr 13, 2013 2:31:13 PM org.apache.catalina.startup.HostConfig deployWAR
INFO: Deploying web application archive C:\Alfresco\tomcat\webapps\alfresco.war
apr 13, 2013 2:31:45 PM org.apache.catalina.core.StandardContext addApplicationListener
apr 13, 2013 2:32:27 PM org.apache.catalina.core.StandardContext startInternal
SEVERE: Error listenerStart
apr 13, 2013 2:32:28 PM org.apache.catalina.loader.WebappClassLoader checkThreadLocalMapForLeaks
SEVERE: The web application [/alfresco] created a ThreadLocal with key of type [java.lang.ThreadLocal] (value [java.lang.ThreadLocal@13e7b625]) and a value of type [org.alfresco.repo.dictionary.NamespaceDAOImpl.NamespaceRegistry] (value [org.alfresco.repo.dictionary.NamespaceDAOImpl$NamespaceRegistry@51674158]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
SEVERE: The web application [/alfresco] created a ThreadLocal with key of type [java.lang.ThreadLocal] (value [java.lang.ThreadLocal@51f32228]) and a value of type [org.alfresco.util.CachingDateFormat] (value [yyyy-MM-dd]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
SEVERE: The web application [/alfresco] created a ThreadLocal with key of type [com.sun.xml.bind.v2.ClassFactory$1] (value [com.sun.xml.bind.v2.ClassFactory$1@7a8ec5ca]) and a value of type [java.util.WeakHashMap] (value [{class org.alfresco.repo.audit.model._3.RecordValue=java.lang.ref.WeakReference@4fea5230, class org.alfresco.repo.audit.model._3.DataExtractors=java.lang.ref.WeakReference@20b9f64d, class org.alfresco.repo.audit.model._3.DataExtractor=java.lang.ref.WeakReference@10d94a04, class org.alfresco.repo.audit.model._3.PathMappings=java.lang.ref.WeakReference@298a5540, class javax.xml.bind.annotation.W3CDomHandler=java.lang.ref.WeakReference@38e2f20e, class org.alfresco.repo.audit.model._3.Audit=java.lang.ref.WeakReference@3b81924f, class java.util.ArrayList=java.lang.ref.WeakReference@37ac9f0e, class org.alfresco.repo.audit.model._3.DataGenerator=java.lang.ref.WeakReference@25fe6cb0, class org.alfresco.repo.audit.model._3.GenerateValue=java.lang.ref.WeakReference@6291aa4c, class org.alfresco.repo.audit.model._3.AuditPath=java.lang.ref.WeakReference@49439622, class org.alfresco.repo.audit.model._3.DataGenerators=java.lang.ref.WeakReference@7435b7c1, class org.alfresco.repo.audit.model._3.PathMap=java.lang.ref.WeakReference@72b31b81, class org.alfresco.repo.audit.model._3.Application=java.lang.ref.WeakReference@4cd2ecfb}]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
SEVERE: The web application [/alfresco] created a ThreadLocal with key of type [java.lang.ThreadLocal] (value [java.lang.ThreadLocal@7b7ca93d]) and a value of type [org.apache.cxf.bus.CXFBusImpl] (value [org.apache.cxf.bus.CXFBusImpl@354b2321]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
SEVERE: The web application [/alfresco] created a ThreadLocal with key of type [com.sun.xml.bind.v2.runtime.Coordinator$1] (value [com.sun.xml.bind.v2.runtime.Coordinator$1@57ef66dc]) and a value of type [java.lang.Object[]] (value [[Ljava.lang.Object;@264a229e]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
apr 13, 2013 2:32:29 PM org.apache.catalina.startup.HostConfig deployWAR
INFO: Deploying web application archive C:\Alfresco\tomcat\webapps\share.war
apr 13, 2013 2:33:12 PM org.apache.catalina.startup.HostConfig deployDirectory
INFO: Deploying web application directory C:\Alfresco\tomcat\webapps\host-manager
INFO: Deploying web application directory C:\Alfresco\tomcat\webapps\manager
INFO: Deploying web application directory C:\Alfresco\tomcat\webapps\ROOT
apr 13, 2013 2:33:13 PM org.apache.coyote.AbstractProtocol start
INFO: Starting ProtocolHandler ["http-apr-8081"]
INFO: Starting ProtocolHandler ["ajp-apr-8009"]
INFO: Starting ProtocolHandler ["http-bio-8443"]
apr 13, 2013 2:33:13 PM org.apache.catalina.startup.Catalina start
INFO: Server startup in 144182 ms
apr 13, 2013 2:33:13 PM org.apache.catalina.loader.WebappClassLoader loadClass
INFO: Illegal access: this web application instance has been stopped already. Could not load org.bouncycastle.jce.provider.symmetric.AES$ECB. The eventual following stack trace is caused by an error thrown for debugging purposes as well as to attempt to terminate the thread which caused the illegal access, and has no functional impact.
java.lang.IllegalStateException
at org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1600)
at org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1559)
at java.security.Provider$Service.getImplClass(Provider.java:1279)
at java.security.Provider$Service.newInstance(Provider.java:1237)
at javax.crypto.Cipher.chooseProvider(Cipher.java:845)
at javax.crypto.Cipher.init(Cipher.java:1348)
at sun.security.ssl.CipherBox.<init>(CipherBox.java:175)
at sun.security.ssl.CipherBox.newCipherBox(CipherBox.java:208)
at sun.security.ssl.CipherSuite$BulkCipher.newCipher(CipherSuite.java:467)
at sun.security.ssl.CipherSuite$BulkCipher.isAvailable(CipherSuite.java:507)
at sun.security.ssl.CipherSuite$BulkCipher.isAvailable(CipherSuite.java:485)
at sun.security.ssl.CipherSuite.isAvailable(CipherSuite.java:190)
at sun.security.ssl.SSLContextImpl.getApplicableCipherSuiteList(SSLContextImpl.java:342)
at sun.security.ssl.SSLContextImpl.getDefaultCipherSuiteList(SSLContextImpl.java:293)
at sun.security.ssl.SSLSocketImpl.init(SSLSocketImpl.java:576)
at sun.security.ssl.SSLSocketImpl.<init>(SSLSocketImpl.java:494)
at sun.security.ssl.SSLServerSocketImpl.accept(SSLServerSocketImpl.java:313)
at org.apache.tomcat.util.net.jsse.JSSESocketFactory.acceptSocket(JSSESocketFactory.java:182)
at org.apache.tomcat.util.net.JIoEndpoint$Acceptor.run(JIoEndpoint.java:216)
ry.java:222)
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:288)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:190)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:580)
at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:895)
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:425)
at org.springframework.web.context.ContextLoader.createWebApplicationContext(ContextLoader.java:276)
at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:197)
at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4791)
at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5285)
at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:901)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:877)
at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:618)
at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:963)
at org.apache.catalina.startup.HostConfig$DeployWar.run(HostConfig.java:1600)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:471)
at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:334)
at java.util.concurrent.FutureTask.run(FutureTask.java:166)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1110)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:603)
Caused by: java.rmi.server.ExportException: internal error: ObjID already in use
at sun.rmi.transport.ObjectTable.putTarget(ObjectTable.java:186)
at sun.rmi.transport.Transport.exportObject(Transport.java:92)
at sun.rmi.transport.tcp.TCPTransport.exportObject(TCPTransport.java:247)
at sun.rmi.transport.tcp.TCPEndpoint.exportObject(TCPEndpoint.java:411)
at sun.rmi.transport.LiveRef.exportObject(LiveRef.java:147)
at sun.rmi.server.UnicastServerRef.exportObject(UnicastServerRef.java:207)
at sun.rmi.registry.RegistryImpl.setup(RegistryImpl.java:122)
at sun.rmi.registry.RegistryImpl.<init>(RegistryImpl.java:98)
at java.rmi.registry.LocateRegistry.createRegistry(LocateRegistry.java:239)
at org.springframework.remoting.rmi.RmiServiceExporter.getRegistry(RmiServiceExporter.java:371)
at org.springframework.remoting.rmi.RmiServiceExporter.getRegistry(RmiServiceExporter.java:336)
at org.springframework.remoting.rmi.RmiServiceExporter.prepare(RmiServiceExporter.java:268)
at org.springframework.remoting.rmi.RmiServiceExporter.afterPropertiesSet(RmiServiceExporter.java:229)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeInitMethods(AbstractAutowireCapableBeanFactory.java:1477)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1417)
… 27 more
apr 13, 2013 2:32:23 PM com.sun.xml.ws.transport.http.servlet.WSServletContextListener contextInitialized
INFO: WSSERVLET12: JAX-WS context listener initializing
apr 13, 2013 2:32:27 PM com.sun.xml.ws.transport.http.servlet.WSServletDelegate <init>
INFO: WSSERVLET14: JAX-WS servlet initializing
apr 13, 2013 2:32:27 PM com.sun.xml.ws.transport.http.servlet.WSServletDelegate destroy
INFO: WSSERVLET15: JAX-WS servlet destroyed
apr 13, 2013 2:32:27 PM com.sun.xml.ws.transport.http.servlet.WSServletContextListener contextDestroyed
INFO: WSSERVLET13: JAX-WS context listener destroyed
apr 13, 2013 2:32:27 PM org.apache.catalina.core.ApplicationContext log
INFO: Closing Spring root WebApplicationContext
apr 13, 2013 2:32:28 PM org.apache.catalina.core.ApplicationContext log
INFO: Shutting down log4j
04-13-2013 11:52 AM
04-13-2013 12:06 PM
apr 13, 2013 6:01:42 PM org.apache.catalina.core.AprLifecycleListener init
apr 13, 2013 6:01:43 PM org.apache.catalina.core.AprLifecycleListener initializeSSL
apr 13, 2013 6:01:44 PM org.apache.coyote.AbstractProtocol init
apr 13, 2013 6:01:44 PM org.apache.catalina.startup.Catalina load
INFO: Initialization processed in 3443 ms
apr 13, 2013 6:01:45 PM org.apache.catalina.core.StandardService startInternal
apr 13, 2013 6:01:45 PM org.apache.catalina.core.StandardEngine startInternal
apr 13, 2013 6:01:45 PM org.apache.catalina.startup.HostConfig deployDescriptor
apr 13, 2013 6:01:45 PM org.apache.catalina.startup.SetContextPropertiesRule begin
apr 13, 2013 6:01:49 PM org.apache.catalina.startup.HostConfig deployWAR
apr 13, 2013 6:02:02 PM org.apache.catalina.core.StandardContext addApplicationListener
apr 13, 2013 6:02:30 PM org.apache.catalina.core.StandardContext startInternal
apr 13, 2013 6:02:30 PM org.apache.catalina.loader.WebappClassLoader checkThreadLocalMapForLeaks
SEVERE: The web application [/alfresco] created a ThreadLocal with key of type [java.lang.ThreadLocal] (value [java.lang.ThreadLocal@327d09cb]) and a value of type [org.alfresco.repo.dictionary.NamespaceDAOImpl.NamespaceRegistry] (value [org.alfresco.repo.dictionary.NamespaceDAOImpl$NamespaceRegistry@2f0e0852]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
SEVERE: The web application [/alfresco] created a ThreadLocal with key of type [java.lang.ThreadLocal] (value [java.lang.ThreadLocal@424457a0]) and a value of type [org.alfresco.util.CachingDateFormat] (value [yyyy-MM-dd]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
SEVERE: The web application [/alfresco] created a ThreadLocal with key of type [com.sun.xml.bind.v2.ClassFactory$1] (value [com.sun.xml.bind.v2.ClassFactory$1@6c401f89]) and a value of type [java.util.WeakHashMap] (value [{class org.alfresco.repo.audit.model._3.DataExtractor=java.lang.ref.WeakReference@144534a3, class org.alfresco.repo.audit.model._3.GenerateValue=java.lang.ref.WeakReference@4b82c3ba, class org.alfresco.repo.audit.model._3.Audit=java.lang.ref.WeakReference@76000f10, class org.alfresco.repo.audit.model._3.RecordValue=java.lang.ref.WeakReference@7ddd1ff5, class org.alfresco.repo.audit.model._3.DataGenerator=java.lang.ref.WeakReference@405d4e61, class org.alfresco.repo.audit.model._3.DataGenerators=java.lang.ref.WeakReference@2dc4e34a, class java.util.ArrayList=java.lang.ref.WeakReference@592626bf, class org.alfresco.repo.audit.model._3.PathMappings=java.lang.ref.WeakReference@57b9f352, class org.alfresco.repo.audit.model._3.AuditPath=java.lang.ref.WeakReference@7115b97c, class javax.xml.bind.annotation.W3CDomHandler=java.lang.ref.WeakReference@4944b5e4, class org.alfresco.repo.audit.model._3.DataExtractors=java.lang.ref.WeakReference@3e01b150, class org.alfresco.repo.audit.model._3.PathMap=java.lang.ref.WeakReference@61201afd, class org.alfresco.repo.audit.model._3.Application=java.lang.ref.WeakReference@2cc09dc}]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
SEVERE: The web application [/alfresco] created a ThreadLocal with key of type [java.lang.ThreadLocal] (value [java.lang.ThreadLocal@219b4bf3]) and a value of type [org.apache.cxf.bus.CXFBusImpl] (value [org.apache.cxf.bus.CXFBusImpl@5a974fc1]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
SEVERE: The web application [/alfresco] created a ThreadLocal with key of type [com.sun.xml.bind.v2.runtime.Coordinator$1] (value [com.sun.xml.bind.v2.runtime.Coordinator$1@3f5365e]) and a value of type [java.lang.Object[]] (value [[Ljava.lang.Object;@57c45759]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
apr 13, 2013 6:02:30 PM org.apache.catalina.startup.HostConfig deployWAR
apr 13, 2013 6:02:45 PM org.apache.catalina.startup.HostConfig deployDirectory
apr 13, 2013 6:02:45 PM org.apache.coyote.AbstractProtocol start
apr 13, 2013 6:02:45 PM org.apache.catalina.startup.Catalina start
INFO: Server startup in 60753 ms
apr 13, 2013 6:02:45 PM org.apache.catalina.loader.WebappClassLoader loadClass
2013-04-13 18:01:38 Commons Daemon procrun stdout initialized
2013-04-13 18:01:49,056 WARN [handler.component.SpellCheckComponent] [localhost-startStop-1] No queryConverter defined, using default converter
2013-04-13 18:01:49,483 WARN [handler.component.SpellCheckComponent] [localhost-startStop-1] No queryConverter defined, using default converter
2013-04-13 18:02:14,667 INFO [management.subsystems.ChildApplicationContextFactory] [localhost-startStop-1] Starting 'sysAdmin' subsystem, ID: [sysAdmin, default]
2013-04-13 18:02:14,689 INFO [management.subsystems.ChildApplicationContextFactory] [localhost-startStop-1] Startup of 'sysAdmin' subsystem, ID: [sysAdmin, default] complete
2013-04-13 18:02:27,032 INFO [management.subsystems.ChildApplicationContextFactory] [localhost-startStop-1] Stopping 'sysAdmin' subsystem, ID: [sysAdmin, default]
2013-04-13 18:02:27,037 INFO [management.subsystems.ChildApplicationContextFactory] [localhost-startStop-1] Stopped 'sysAdmin' subsystem, ID: [sysAdmin, default]
2013-04-13 18:02:27,044 ERROR [web.context.ContextLoader] [localhost-startStop-1] Context initialization failed
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'avmRemoteService' defined in class path resource [alfresco/remote-services-context.xml]: Invocation of init method failed; nested exception is java.rmi.server.ExportException: internal error: ObjID already in use
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1420)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:519)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:456)
at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:291)
… 27 more
2013-04-13 18:02:39,356 INFO [extensions.webscripts.TemplateProcessorRegistry] [localhost-startStop-1] Registered template processor freemarker for extension ftl
2013-04-13 18:02:39,462 INFO [extensions.webscripts.ScriptProcessorRegistry] [localhost-startStop-1] Registered script processor javascript for extension js
2013-04-13 18:02:39,463 INFO [extensions.webscripts.TemplateProcessorRegistry] [localhost-startStop-1] Registered template processor freemarker for extension ftl
2013-04-13 18:02:39,466 INFO [extensions.webscripts.ScriptProcessorRegistry] [localhost-startStop-1] Registered script processor javascript for extension js
2013-04-13 18:02:45,024 INFO [extensions.webscripts.DeclarativeRegistry] [localhost-startStop-1] Registered 342 Web Scripts (+0 failed), 355 URLs
2013-04-13 18:02:45,024 INFO [extensions.webscripts.DeclarativeRegistry] [localhost-startStop-1] Registered 8 Package Description Documents (+0 failed)
2013-04-13 18:02:45,025 INFO [extensions.webscripts.DeclarativeRegistry] [localhost-startStop-1] Registered 0 Schema Description Documents (+0 failed)
2013-04-13 18:02:45,241 INFO [extensions.webscripts.AbstractRuntimeContainer] [localhost-startStop-1] Initialised Spring Surf Container Web Script Container (in 5765.1885ms)
2013-04-13 18:02:45,248 INFO [extensions.webscripts.TemplateProcessorRegistry] [localhost-startStop-1] Registered template processor freemarker for extension ftl
2013-04-13 18:02:45,255 INFO [extensions.webscripts.ScriptProcessorRegistry] [localhost-startStop-1] Registered script processor javascript for extension js
2013-04-13 18:02:45,984 ERROR [quartz.core.JobRunShell] [SolrTrackerScheduler_Worker-2] Job Solr.CoreTracker-archive threw an unhandled Exception:
org.alfresco.error.AlfrescoRuntimeException: 03130001 GetModelsDiff return status is 404
at org.alfresco.solr.client.SOLRAPIClient.getModelsDiff(SOLRAPIClient.java:1036)
at org.alfresco.solr.tracker.CoreTracker.trackModels(CoreTracker.java:1790)
at org.alfresco.solr.tracker.CoreTracker.trackRepository(CoreTracker.java:1129)
at org.alfresco.solr.tracker.CoreTracker.updateIndex(CoreTracker.java:475)
at org.alfresco.solr.tracker.CoreTrackerJob.execute(CoreTrackerJob.java:45)
2013-04-13 18:02:45,984 ERROR [quartz.core.JobRunShell] [SolrTrackerScheduler_Worker-3] Job Solr.CoreTracker-alfresco threw an unhandled Exception:
org.alfresco.error.AlfrescoRuntimeException: 03130000 GetModelsDiff return status is 404
2013-04-13 18:02:45,985 ERROR [quartz.core.ErrorLogger] [SolrTrackerScheduler_Worker-2] Job (Solr.CoreTracker-archive threw an exception.
org.quartz.SchedulerException: Job threw an unhandled exception. [See nested exception: org.alfresco.error.AlfrescoRuntimeException: 03130001 GetModelsDiff return status is 404]
at org.quartz.core.JobRunShell.run(JobRunShell.java:227)
Caused by: org.alfresco.error.AlfrescoRuntimeException: 03130001 GetModelsDiff return status is 404
… 1 more
2013-04-13 18:02:45,985 ERROR [quartz.core.ErrorLogger] [SolrTrackerScheduler_Worker-3] Job (Solr.CoreTracker-alfresco threw an exception.
org.quartz.SchedulerException: Job threw an unhandled exception. [See nested exception: org.alfresco.error.AlfrescoRuntimeException: 03130000 GetModelsDiff return status is 404]
Caused by: org.alfresco.error.AlfrescoRuntimeException: 03130000 GetModelsDiff return status is 404
… 1 more
2013-04-13 18:03:00,023 ERROR [quartz.core.JobRunShell] [SolrTrackerScheduler_Worker-2] Job Solr.CoreTracker-archive threw an unhandled Exception:
org.alfresco.error.AlfrescoRuntimeException: 03130002 GetModelsDiff return status is 404
2013-04-13 18:03:00,024 ERROR [quartz.core.ErrorLogger] [SolrTrackerScheduler_Worker-2] Job (Solr.CoreTracker-archive threw an exception.
org.quartz.SchedulerException: Job threw an unhandled exception. [See nested exception: org.alfresco.error.AlfrescoRuntimeException: 03130002 GetModelsDiff return status is 404]
Caused by: org.alfresco.error.AlfrescoRuntimeException: 03130002 GetModelsDiff return status is 404
… 1 more
2013-04-13 18:03:00,047 ERROR [quartz.core.JobRunShell] [SolrTrackerScheduler_Worker-1] Job Solr.CoreTracker-alfresco threw an unhandled Exception:
org.alfresco.error.AlfrescoRuntimeException: 03130003 GetModelsDiff return status is 404
2013-04-13 18:03:00,048 ERROR [quartz.core.ErrorLogger] [SolrTrackerScheduler_Worker-1] Job (Solr.CoreTracker-alfresco threw an exception.
org.quartz.SchedulerException: Job threw an unhandled exception. [See nested exception: org.alfresco.error.AlfrescoRuntimeException: 03130003 GetModelsDiff return status is 404]
Caused by: org.alfresco.error.AlfrescoRuntimeException: 03130003 GetModelsDiff return status is 404
… 1 more
2013-04-13 18:03:15,005 ERROR [quartz.core.JobRunShell] [SolrTrackerScheduler_Worker-2] Job Solr.CoreTracker-archive threw an unhandled Exception:
org.alfresco.error.AlfrescoRuntimeException: 03130004 GetModelsDiff return status is 404
2013-04-13 18:03:15,005 ERROR [quartz.core.ErrorLogger] [SolrTrackerScheduler_Worker-2] Job (Solr.CoreTracker-archive threw an exception.
org.quartz.SchedulerException: Job threw an unhandled exception. [See nested exception: org.alfresco.error.AlfrescoRuntimeException: 03130004 GetModelsDiff return status is 404]
Caused by: org.alfresco.error.AlfrescoRuntimeException: 03130004 GetModelsDiff return status is 404
… 1 more
2013-04-13 18:03:15,008 ERROR [quartz.core.JobRunShell] [SolrTrackerScheduler_Worker-3] Job Solr.CoreTracker-alfresco threw an unhandled Exception:
org.alfresco.error.AlfrescoRuntimeException: 03130005 GetModelsDiff return status is 404
2013-04-13 18:03:15,009 ERROR [quartz.core.ErrorLogger] [SolrTrackerScheduler_Worker-3] Job (Solr.CoreTracker-alfresco threw an exception.
org.quartz.SchedulerException: Job threw an unhandled exception. [See nested exception: org.alfresco.error.AlfrescoRuntimeException: 03130005 GetModelsDiff return status is 404]
Caused by: org.alfresco.error.AlfrescoRuntimeException: 03130005 GetModelsDiff return status is 404
… 1 more
2013-04-13 18:03:30,014 ERROR [quartz.core.JobRunShell] [SolrTrackerScheduler_Worker-3] Job Solr.CoreTracker-archive threw an unhandled Exception:
org.alfresco.error.AlfrescoRuntimeException: 03130006 GetModelsDiff return status is 404
2013-04-13 18:03:30,015 ERROR [quartz.core.ErrorLogger] [SolrTrackerScheduler_Worker-3] Job (Solr.CoreTracker-archive threw an exception.
org.quartz.SchedulerException: Job threw an unhandled exception. [See nested exception: org.alfresco.error.AlfrescoRuntimeException: 03130006 GetModelsDiff return status is 404]
Caused by: org.alfresco.error.AlfrescoRuntimeException: 03130006 GetModelsDiff return status is 404
… 1 more
2013-04-13 18:03:30,018 ERROR [quartz.core.JobRunShell] [SolrTrackerScheduler_Worker-2] Job Solr.CoreTracker-alfresco threw an unhandled Exception:
org.alfresco.error.AlfrescoRuntimeException: 03130007 GetModelsDiff return status is 404
2013-04-13 18:03:30,019 ERROR [quartz.core.ErrorLogger] [SolrTrackerScheduler_Worker-2] Job (Solr.CoreTracker-alfresco threw an exception.
org.quartz.SchedulerException: Job threw an unhandled exception. [See nested exception: org.alfresco.error.AlfrescoRuntimeException: 03130007 GetModelsDiff return status is 404]
Caused by: org.alfresco.error.AlfrescoRuntimeException: 03130007 GetModelsDiff return status is 404
… 1 more
2013-04-13 18:03:45,011 ERROR [quartz.core.JobRunShell] [SolrTrackerScheduler_Worker-3] Job Solr.CoreTracker-alfresco threw an unhandled Exception:
org.alfresco.error.AlfrescoRuntimeException: 03130008 GetModelsDiff return status is 404
2013-04-13 18:03:45,012 ERROR [quartz.core.ErrorLogger] [SolrTrackerScheduler_Worker-3] Job (Solr.CoreTracker-alfresco threw an exception.
org.quartz.SchedulerException: Job threw an unhandled exception. [See nested exception: org.alfresco.error.AlfrescoRuntimeException: 03130008 GetModelsDiff return status is 404]
Caused by: org.alfresco.error.AlfrescoRuntimeException: 03130008 GetModelsDiff return status is 404
… 1 more
2013-04-13 18:03:45,012 ERROR [quartz.core.JobRunShell] [SolrTrackerScheduler_Worker-2] Job Solr.CoreTracker-archive threw an unhandled Exception:
org.alfresco.error.AlfrescoRuntimeException: 03130009 GetModelsDiff return status is 404
2013-04-13 18:03:45,014 ERROR [quartz.core.ErrorLogger] [SolrTrackerScheduler_Worker-2] Job (Solr.CoreTracker-archive threw an exception.
org.quartz.SchedulerException: Job threw an unhandled exception. [See nested exception: org.alfresco.error.AlfrescoRuntimeException: 03130009 GetModelsDiff return status is 404]
Caused by: org.alfresco.error.AlfrescoRuntimeException: 03130009 GetModelsDiff return status is 404
… 1 more
2013-04-13 18:04:00,010 ERROR [quartz.core.JobRunShell] [SolrTrackerScheduler_Worker-3] Job Solr.CoreTracker-archive threw an unhandled Exception:
org.alfresco.error.AlfrescoRuntimeException: 03130010 GetModelsDiff return status is 404
2013-04-13 18:04:00,011 ERROR [quartz.core.ErrorLogger] [SolrTrackerScheduler_Worker-3] Job (Solr.CoreTracker-archive threw an exception.
org.quartz.SchedulerException: Job threw an unhandled exception. [See nested exception: org.alfresco.error.AlfrescoRuntimeException: 03130010 GetModelsDiff return status is 404]
Caused by: org.alfresco.error.AlfrescoRuntimeException: 03130010 GetModelsDiff return status is 404
… 1 more
2013-04-13 18:04:00,013 ERROR [quartz.core.JobRunShell] [SolrTrackerScheduler_Worker-1] Job Solr.CoreTracker-alfresco threw an unhandled Exception:
org.alfresco.error.AlfrescoRuntimeException: 03130011 GetModelsDiff return status is 404
2013-04-13 18:04:00,014 ERROR [quartz.core.ErrorLogger] [SolrTrackerScheduler_Worker-1] Job (Solr.CoreTracker-alfresco threw an exception.
org.quartz.SchedulerException: Job threw an unhandled exception. [See nested exception: org.alfresco.error.AlfrescoRuntimeException: 03130011 GetModelsDiff return status is 404]
Caused by: org.alfresco.error.AlfrescoRuntimeException: 03130011 GetModelsDiff return status is 404
… 1 more
04-14-2013 04:07 AM
Caused by: java.rmi.server.ExportException: internal error: ObjID already in use. By any chance, are you running more than one Alfresco at the same time? Please check and make sure that no Alfresco process runs before you start it up using the Alfresco start script.04-14-2013 03:54 PM
