[solved] problem with customized titlebar.jsp
ethan
Hi : )
I made some changes to the file /alfresco/jsp/parts/titlebar.jsp to remove the list of links (company home / my alfresco / guest home …) because I don't need it. I replaced the original file with my custom titlebar.jsp and restarded Alfresco. The modification does work on almost every pages but when I click on the Details button to show the document's details page, this part of the titlebar reappear !
How can it be possible  :?:
Thanks for your help : )
8 REPLIES 8
savic_prvoslav
hi, if you want to change some of hard coded jsp's you must change it where it is so, if you want to change /jsp/parts/titlebar.jsp you change the file, also you must keep war file in consistent state ( change file in it too if you are running in tomcat).
Dialog container should always work if you are doing this right. because of jsp/dialog/container.jsp has line
<td colspan="2"><%@ include file="../parts/titlebar.jsp"%>‍
where it uses jsp include to include file. also may be that tomcat is using temp data, so delete this first, and delete alfresco dir in tomcat webapp , so new one will be created.
PS: you should see what I have done with title bar Smiley Happy , anyway this works and you should get it in no time.
ethan
Hi Smiley Happy
I modified my ant script to include my custom titlebar.jsp in the alfresco war. I deleted the alfresco folder and replaced the original war by the one I modified and then I deleted the alfresco folder in the tomcat temp folder. I also deleted the cache of my browser (Firefox) and started alfresco.
The war is deployed and I checked the titlebar.jsp inside the /jsp/parts/ folder to see if it was the right file (with the modification) and it was ! But the problem is still here 😕 The supposedly part (with the links) still appear when I'm on the Details page : (
ps: I agree to see what you have done with titlebar but you don't provide any link ? : o
savic_prvoslav
why do not you send title bar .jsp code to see.
and image where you tell me what is wrong, and I will provide you with the code or pointer to how to do this..
ethan
Here is the link to download the titlebar.jsp file.  (I uploaded it on a Windows Live skydrive account because I don't have any ftp access at hand.)
this is the UI which should be displayed each time :
[img]http://img251.imageshack.us/img251/3783/alfrescowebclient1.th.png[/img]
And this is the way it is displayed on the Details page :
[img]http://img153.imageshack.us/img153/6315/alfrescowebclient2.th.png[/img]
Thank you for your help : )
savic_prvoslav
that is because you made a mistake, this is html organization problem.
use ff and fire bug, you will fix this in 5 min tops, it is easier for you to do this this way than for me to solve html problem. Smiley Very Happy
ethan
What do you mean by html organization problem? I used firebug to look a the html code. I see that the html code for the link menu is still there but it shouldn't be because the container.jsp load the correct ../parts/titlebar.jsp file. Obviously I'm missing something but I don't know what 😕
savic_prvoslav
<td style="width:100%;">
         <table cellspacing="0" cellpadding="0" width="100%">
            <tr>
               <td style="padding-right:4px;"><a:actionLink id="about_alfresco" image="/images/logo/AlfrescoLogo32.png" value="#{msg.title_about}" tooltip="#{msg.title_about}" showLink="false" action="dialog:aboutDialog" /></td>
            </tr>
         </table>
      </td>‍‍‍‍‍‍‍
edit this part.
PS: you do not have to restart server when y ou change jsp, just refresh (crtl + R) . you will get this faster.
ethan
ok you were right. I deleted this part and it removed the link menu but I don't understand why  :?: I mean this part of the code was just supposed to display the alfresco logo on the left side of the titlebar. Where did the menu link code come from ? : o
Well, thank you for your time and help Smiley Happy
