Seriously need help with Authentication
tcordova
I'm desperately trying to put together a technology demo for one of our departments by Friday as a proof of concept and I'm having major issues with authentication.
First I set up NTLM pass through, but that won't work with CIFS right now, so I can't use it.
Then I tried to remove all the references to NTLM and Alfresco still seems to be authenticating against the domain.  Something is seriously wrong.
I removed the ntlm-authentication-context.xml file from the extension folder and put my web.xml back to the way it was on install.  Now I can't login at all, not even using admin/admin.
Before I do a fresh install and lose 2 hours I'd like to know if there's anything else I can try…
11 REPLIES 11
tcordova
Here's the contents of my log4j.xml file:
<!DOCTYPE log4j:configuration SYSTEM "log4j.dtd">
<!–  Log4j Configuration                                                  –>
<!– $Id: log4j.xml,v 1.26.2.5 2005/09/15 09:31:02 dimitris Exp $ –>
   | For more configuration infromation and examples see the Jakarta Log4j
   | owebsite: http://jakarta.apache.org/log4j
<log4j:configuration xmlns:log4j="http://jakarta.apache.org/log4j/" debug="false">
   <!– Preserve messages in a local file –>
   <!– A time/date based rolling appender –>
   <appender name="FILE" class="org.jboss.logging.appender.DailyRollingFileAppender">
      <errorHandler class="org.jboss.logging.util.OnlyOnceErrorHandler"/>
      <param name="File" value="${jboss.server.home.dir}/log/server.log"/>
      <param name="Append" value="false"/>
      <!– Rollover at midnight each day –>
      <param name="DatePattern" value="'.'yyyy-MM-dd"/>
      <param name="Threshold" value="WARN"/>
      <!– Rollover at the top of each hour
      <param name="DatePattern" value="'.'yyyy-MM-dd-HH"/>
      <layout class="org.apache.log4j.PatternLayout">
         <!– The default pattern: Date Priority [Category] Message\n –>
         <param name="ConversionPattern" value="%d %-5p [%c] %m%n"/>
         <!– The full pattern: Date MS Priority [Category] (Thread:NDC) Message\n
         <param name="ConversionPattern" value="%d %-5r %-5p [%c] (%t:%x) %m%n"/>
      </layout>
   </appender>
   <!– A size based file rolling appender
   <appender name="FILE" class="org.jboss.logging.appender.RollingFileAppender">
     <param name="MaxFileSize" value="500KB"/>
     <param name="MaxBackupIndex" value="1"/>
     </layout>
   </appender>
   <!– Append messages to the console –>
   <appender name="CONSOLE" class="org.apache.log4j.ConsoleAppender">
      <param name="Target" value="System.out"/>
      <param name="Threshold" value="INFO"/>
         <param name="ConversionPattern" value="%d{ABSOLUTE} %-5p [%c{1}] %m%n"/>
      </layout>
   </appender>
   <!– More Appender examples –>
   <!– Buffer events and log them asynchronously
   <appender name="ASYNC" class="org.apache.log4j.AsyncAppender">
     <appender-ref ref="FILE"/>
     <appender-ref ref="CONSOLE"/>
     <appender-ref ref="SMTP"/>
   </appender>
   <!– EMail events to an administrator
   <appender name="SMTP" class="org.apache.log4j.net.SMTPAppender">
     <param name="Threshold" value="ERROR"/>
     <param name="To" value="[email protected]"/>
     <param name="From" value="[email protected]"/>
     <param name="Subject" value="JBoss Sever Errors"/>
     <param name="SMTPHost" value="localhost"/>
     <param name="BufferSize" value="10"/>
       <param name="ConversionPattern" value="[%d{ABSOLUTE},%c{1}] %m%n"/>
     </layout>
   </appender>
   <!– Syslog events
   <appender name="SYSLOG" class="org.apache.log4j.net.SyslogAppender">
     <param name="Facility" value="LOCAL7"/>
     <param name="FacilityPrinting" value="true"/>
     <param name="SyslogHost" value="localhost"/>
     </layout>
   </appender>
   <!– Log events to JMS (requires a topic to be created)
   <appender name="JMS" class="org.apache.log4j.net.JMSAppender">
     <param name="TopicConnectionFactoryBindingName" value="java:/ConnectionFactory"/>
     <param name="TopicBindingName" value="topic/MyErrorsTopic"/>
   </appender>
   <!– Log events through SNMP
   <appender name="TRAP_LOG" class="org.apache.log4j.ext.SNMPTrapAppender">
     <param name="ImplementationClassName" value="org.apache.log4j.ext.JoeSNMPTrapSender"/>
     <param name="ManagementHost" value="127.0.0.1"/>
     <param name="ManagementHostTrapListenPort" value="162"/>
     <param name="EnterpriseOID" value="1.3.6.1.4.1.24.0"/>
     <param name="LocalIPAddress" value="127.0.0.1"/>
     <param name="LocalTrapSendPort" value="161"/>
     <param name="GenericTrapType" value="6"/>
     <param name="SpecificTrapType" value="12345678"/>
     <param name="CommunityString" value="public"/>
     <param name="ForwardStackTraceWithTrap" value="true"/>
     <param name="Threshold" value="DEBUG"/>
     <param name="ApplicationTrapOID" value="1.3.6.1.4.1.24.12.10.22.64"/>
            <param name="ConversionPattern" value="%d,%p,[%t],[%c],%m%n"/>
     </layout>
   </appender>
   <!–  Emit events as JMX notifications
   <appender name="JMX" class="org.jboss.monitor.services.JMXNotificationAppender">
      <param name="ObjectName" value="jboss.system:service=Logging,type=JMXNotificationAppender"/>
         <param name="ConversionPattern" value="%d %-5p [%c] %m"/>
      </layout>
   </appender>
   <!– Limit categories –>
   <!– Limit the org.apache category to INFO as its DEBUG is verbose –>
   <category name="org.apache">
      <priority value="INFO"/>
   </category>
   <!– Limit the org.jgroups category to WARN as its INFO is verbose –>
   <category name="org.jgroups">
      <priority value="WARN"/>
   </category>
   <!– Limit jboss axis to INFO as its DEBUG is even more verbose –>
   <category name="org.jboss.axis">
   </category>
   <!– Limit JBoss categories
   <category name="org.jboss">
   </category>
   <!– Limit the JSR77 categories –>
   <category name="org.jboss.management">
   </category>
   <!– Limit JBoss webservice category
   <category name="org.jboss.webservice">
      <priority value="DEBUG"/>
   </category>
   <!– Decrease the priority threshold for the org.jboss.varia category
   <category name="org.jboss.varia">
   </category>
   <!– Show the evolution of the DataSource pool in the logs [inUse/Available/Max]
   <category name="org.jboss.resource.connectionmanager.JBossManagedConnectionPool">
     <priority value="TRACE" class="org.jboss.logging.XLevel"/>
   </category>
      | An example of enabling the custom TRACE level priority that is used
      | by the JBoss internals to diagnose low level details. This example
      | turns on TRACE level msgs for the org.jboss.ejb.plugins package and its
      | subpackages. This will produce A LOT of logging output.
   <category name="org.jboss.system">
   </category>
   <category name="org.jboss.ejb.plugins">
   </category>
       | Logs these events to SNMP:
           - server starts/stops
           - cluster evolution (node death/startup)
           - When an EJB archive is deployed (and associated verified messages)
           - When an EAR archive is deployed
   <category name="org.jboss.system.server.Server">
     <priority value="INFO" />
     <appender-ref ref="TRAP_LOG"/>
   </category>
   <category name="org.jboss.ha.framework.interfaces.HAPartition.lifecycle">
   </category>
   <category name="org.jboss.deployment.MainDeployer">
     <priority value="ERROR" />
   </category>
   <category name="org.jboss.ejb.EJBDeployer">
   </category>
   <category name="org.jboss.deployment.EARDeployer">
   </category>
   <!– Setup the Root category –>
   <root>
   </root>
   <!– Clustering logging –>
   <!– Uncomment the following to redirect the org.jgroups and
      org.jboss.ha categories to a cluster.log file.
   <appender name="CLUSTER" class="org.jboss.logging.appender.RollingFileAppender">
     <param name="File" value="${jboss.server.home.dir}/log/cluster.log"/>
     </layout>
   </appender>
     <priority value="DEBUG" />
     <appender-ref ref="CLUSTER"/>
   </category>
   <category name="org.jboss.ha">
   </category>
</log4j:configuration>
kevinr
As per this forum post: http://forums.alfresco.com/viewtopic.php?t=2202
Can you change this section:
   <root>
   </root>
To read as follows:
   <root>
   </root>
You may also wish to uncomment this section:
   </category>
Please let us know if this helps.
Kevin
