SDK samples problem
jcfelicilte
I have 2 questions :
1. I am trying to run the samples of the SDK without success. For exemple, in the FirstFoundationClient, the application creates the database  but with 2 exceptions listed below :
Exception in thread "main" org.alfresco.error.AlfrescoRuntimeException: Bootstrap failed
And
Caused by: org.alfresco.service.cmr.view.ImporterException: Failed to import package at line 8; column 23 due to error: Unable to load analyser for property of type {http://www.alfresco.org/model/dictionary/1.0}text using org.apache.lucene.analysis.fr.FrenchAnalyzer
Why?
2. When I launch the Tomcat server for the first time, the webapp is deployed with success and I can see the database created.
Then when I restart the server, I have some errors telling me that the schema can't be regenerated, Why?
Same thing wiith the SDK samples. I must drop the database and recreate it.
thanks a lot for answers
JC
torcq
You need to add lucene-analyzers-2.0.0.jar in your classpath (this jar is missing in the Java build path inside Eclipse)
Cédric
