[ Alf v3.4.0(E) ]
Trying to follow the example Java-backed WebScript from the Professional Alfresco book published by Wrox (Chapter 11). I can't seem to get the Repository.findNodeRef function to work when searching for just "Company Home". Searching for a folder underneath Company Home (e.g. Data Dictionary) works, however.
This code sample highlights the issue:
package org.example;
import java.util.HashMap;
import java.util.Map;
import org.alfresco.repo.model.Repository;
import org.alfresco.service.cmr.repository.NodeRef;
import org.springframework.extensions.webscripts.Cache;
import org.springframework.extensions.webscripts.DeclarativeWebScript;
import org.springframework.extensions.webscripts.Status;
import org.springframework.extensions.webscripts.WebScriptException;
import org.springframework.extensions.webscripts.WebScriptRequest;
public class JavaDir extends DeclarativeWebScript {
private Repository repository;
public void setRepository(Repository repository) {
this.repository = repository;
protected Map<String, Object> executeImpl(WebScriptRequest req, Status status, Cache cache) {
// Test code:
System.out.println("/Company Home ==> " + repository.findNodeRef("path", "workspace/SpacesStore/Company Home".split("/")));
System.out.println("/Company Home/Data Dictionary ==> " + repository.findNodeRef("path", "workspace/SpacesStore/Company Home/Data Dictionary".split("/")));
The output from the above is:
/Company Home ==> null
/Company Home/Data Dictionary ==> workspace://SpacesStore/0a9446f3-6cc0-4619-b31a-442c2ca183a7
When searching by path for just /Company Home, it returns null. Yet, searching for "/Company Home/Data Dictionary" works. Why is this? Am I doing something wrong? Is this a bug?
Karl
