Reporting for Solr indexing and problems
macti
We have an issue where nodes can be found by an admin, but other non-admin users can't find them. We found out that just by editing the properties of the node will fix the issue, so we assume that Solr is re-indexing the node and fix any issues.
Problem is: we would like to see if we have nodes with bad indexing data on them (especially for the ACL part). Alfresco support replied to have a look at this wiki page, but I have two questions about it:
1) How do you find the nodeid? For example, I have tried the NODEREPORT report with nodeid=10, it works, but I don't know which node this is. I have tried a nodeid like 01a8b7ba-ff7c-42a6-8933-f1c863938a85 or workspace://SpacesStore/01a8b7ba-ff7c-42a6-8933-f1c863938a85, and the report is throwing up exceptions.
2) Any way to get the state for any indexing nodes? We would like to build a report that will get the state of indexing, especially ACLs, so that we can found out errors and fix it if needed.
Alfresco Enterprise 4.0.2.9 with Solr.
xarope
can't answer the rest of your question, but for the nodeid, I'd suspect something like:
select an.id from alf_node an where an.uuid ='01a8b7ba-ff7c-42a6-8933-f1c863938a85'
as for NODEREPORT, using https://<host>:8443/solr/admin/cores?action=NODEREPORT&wt=xml&nodeid=<nodeid> failed for me, I had to use dbid= instead of nodeid=, not sure what's going on here?
