Problems with Alfresco after configuring database (oracle)
pranjesh
I installed Alfresco Labs 3 with the default Derby database. It ran fine. But when I configured the database (Oracle) it ran into trouble.
Below is the log file:
14:53:15,365 INFO  [org.alfresco.config.xml.XMLConfigService$PropertyConfigurer] Loading properties file from class path resource [alfresco/file-servers.properties]
14:53:17,459 WARN  [org.springframework.remoting.rmi.RmiRegistryFactoryBean] Could not detect RMI registry - creating new one
14:53:21,444 INFO  [org.alfresco.repo.domain.schema.SchemaBootstrap] Schema managed by database dialect org.hibernate.dialect.Oracle9Dialect.
14:56:49,810 ERROR [org.alfresco.repo.domain.schema.SchemaBootstrap] Schema auto-update failed
org.alfresco.error.AlfrescoRuntimeException: A previous schema upgrade failed or was not completed.  Revert to the original database before attempting the upgrade again.
   at org.alfresco.repo.domain.schema.SchemaBootstrap.onBootstrap(SchemaBootstrap.java:1018)
14:56:49,825 ERROR [org.springframework.web.context.ContextLoader] Context initialization failed
org.alfresco.error.AlfrescoRuntimeException: Schema auto-update failed
   at org.alfresco.repo.domain.schema.SchemaBootstrap.onBootstrap(SchemaBootstrap.java:1074)
Caused by: org.alfresco.error.AlfrescoRuntimeException: A previous schema upgrade failed or was not completed.  Revert to the original database before attempting the upgrade again.
   … 34 more
14:56:49,841 ERROR [org.apache.catalina.core.ContainerBase.[Catalina].[localhost].[/alfresco]] Exception sending context initialized event to listener instance of class org.springframework.web.context.ContextLoaderListener
   … 34 more
14:56:49,857 ERROR [org.apache.catalina.core.ContainerBase.[Catalina].[localhost].[/alfresco]] Exception sending context initialized event to listener instance of class org.alfresco.web.app.ContextListener
   … 34 more
14:56:54,263 INFO  [org.alfresco.web.site.FrameworkHelper] Successfully Initialized Web Framework
It appears to have created tables (75) in the database fine.
The Tomcat window shows the "server starts in …." message
Alfresco web client page does not open and it gives the HTTP status 404 error message
I have seen a few posts with similar problem description. But none had a clear solution that worked for me. They talked about deleting alf_data, dropping and recreating the database, permissions etc. None of these work.
If anyone has been through this situation, reply with your experiences/work around/solution/fixes… THANKS in advance.
4 REPLIES 4
spillai
Hello Pranjesh,
I too faced the same problem while migrating the data from one instance to another. But for me the below solution worked out and hope so that may work out for you too.
First of all delete all the folders under the dir.root folder i.e. audit.contentstore, backup-lucene-indexes, contentstore, contentstore and   lucene-indexes.
Drop the user named alfresco from Oracle Database, which will delete all the tables related to this user from the database.
Again create the user alfresco and grant appropriate privileges to this user.
Set the index.recovery.mode=FULL in repository.properties.
Now restart the alfresco server.
Hope so this solution works out for you.
Please do revert back with your outcomes with the above solution or you have come across with any other.
sisao
the same problem occures to me when using the Alfresco SDK and an oracle DB…i've found out that even shuting down the server via script the alfresco user wont disconnect from the DB until i restart my os….this may somehow cause coerence problems into the tablespace i guess.
Regards,
Francesco.
pranjesh
Hi Sujay! Thanks for posting a reply. I think the problem was there was not enough space allocated for user 'alfresco' in Oracle. It got resolved after the DBA granted unlimited space.
hansraj
do the following in custom-repository.properties.
db.schema.update=false
then restart the server.
Regards,
Hansraj
