Problems installing Alfresco on x64 running Centos 5
fleetwoodmac
I have tried reinstalling Alfresco five times now on my Centos 5 x64 machine using the instructions from the Wiki "Installing Alfresco Community WAR on Centos 5" with no success.  Tomcat works fine (tested with the sample application), but Alfresco gives me the 404 error message with the following printouts.  The MySQL database seems to be working (I can log in) but it doesn't seem to be populating the alfresco database with any tables.  I rechecked the MySQL configuration file and the passwords and permissions are set up right.
alfresco.log
11:34:24,612 WARN  [org.springframework.remoting.rmi.RmiRegistryFactoryBean] Could not detect RMI registry - creating new one
11:34:24,959 ERROR [org.springframework.web.context.ContextLoader] Context initialization failed
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'dictionaryRepositoryBootstrap' defined in class path resource [alfresco/core-services-context.xml]: Invocation of init method failed; nested exception is org.alfresco.error.AlfrescoRuntimeException: Failure during rollback: org.alfresco.repo.dictionary.DictionaryRepositoryBootstrap$1@10a621a
Caused by:
        at org.alfresco.repo.transaction.RetryingTransactionHelper.doInTransaction(RetryingTransactionHelper.java:281)
        at org.alfresco.repo.transaction.RetryingTransactionHelper.doInTransaction(RetryingTransactionHelper.java:155)
        at org.alfresco.repo.dictionary.DictionaryRepositoryBootstrap.bootstrap(DictionaryRepositoryBootstrap.java:134)
and catalina.out
11:46:09,053 ERROR [web.context.ContextLoader] Context initialization failed
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'dictionaryRepositoryBootstrap' defined in class path resource [alfresco/core-services-context.xml]: Invocation of init method failed; nested exception is org.alfresco.error.AlfrescoRuntimeException: Failure during rollback: org.alfresco.repo.dictionary.DictionaryRepositoryBootstrap$1@15f0876
Caused by:
Appreciate any help
Fleetwoodmac
14 REPLIES 14
alexfisher
I'm having the same issue.
In the web browser, I get:
type Status report
message /alfresco/
description The requested resource (/alfresco/) is not available.
And in the alfresco.log file I have similar output as above.
fleetwoodmac
alexfisher,
Did you resolve your installation problems
steve
Hi alexfisher,
Your post gives no indication of why the server failed to start - you'll need to post the relevant parts from your catalina.out or alfresco.log showing the cause of the problem before anyone can really help you.
Steve
fleetwoodmac
Steve,
I may have resolved the mystery.  You were probably right. It was a permissions problem. In the wiki instruction for installing on Centos http://wiki.alfresco.com/wiki/Installing_Alfresco_Community_WAR_on_Centos_5 the chown instruction may have been mistaken
It says
[root@localhost alfresco]# chown -R tomcat.tomcat /var/lib/alfresco
Don't forget that second step – turns out it's important, or bad things happen later.
When it should say
[root@localhost alfresco]# chown -R tomcat:tomcat /var/lib/alfresco (with a colon between user and group names)
I reinstalled Alfresco on an x64 machine running Centos 5 using the custom properties configuration files and it works fine
steve
Thanks for the correction to the Wiki - I have updated the Centos page.
Note, these instructions were kindly added by a community member because we don't test on Centos currently.
Steve
