Problems customizing model in unattended installation
Options
04-20-2012 11:33 AM
I am having problems customizing the content model using the bootstrap mode described in the official documentation here: http://docs.alfresco.com/4.0/index.jsp?topic=%2Fcom.alfresco.enterprise.doc%2Ftasks%2Fdeploy-bootstr...
We have spring context file that looks like this:
<beans>
<!– Registration of new models –>
<bean id="custom.dictionaryBootstrap" parent="dictionaryModelBootstrap" depends-on="dictionaryBootstrap">
<property name="models">
<list>
<value>alfresco/extension/customContentModel.xml</value>
</list>
</property>
</bean>
</beans>
customContentModel.xml is located in the <alfresco_install>/tomcat/shared/classes/alfresco/extension as well as the spring context file above.
After doing this we start alfresco for the first time but the content model customizations are not taking place.
I am installing alfresco on ubuntu 11.04 64bits using the unattended mode and passing an options file. Alfresco is properly installed and the web ui is perfectly visible after the process. I can log in and browse around without problems.I am installing alfresco community 4.0.d.
The tomcat logs show no sign of errors.
What could be the problem?
Thanks in advance.
Erick.
<beans>
<list>
</list>
</property>
</bean>
</beans>
Thanks in advance.
Erick.
Labels:
Archive
Options
04-20-2012 05:41 PM
What Alfresco UI are you using, Share or Explorer?
If you are using Share, you will have to add a few items to "share-config-custom.xml" before you will see anything related to your new model (properties, aspects, etc)
