Problem with searchs
menesthevs
In our corporation repository, I created a logical structure where I established different permissions so that our employees (who have "contributor" roles) can navigate and have access to several folders, depending on their own permissions. I've noticed that, although they can access the folders they have permission for, when they try to use the search bar, the following message appears:
01170047 Wrapped Exception (with status template): 0117145730 Failed to execute script 'classpath*:alfresco/templates/webscripts/org/alfresco/slingshot/search/search.get.js': 0117145728 Access denied. You do not have the appropriate permissions to perform this operation.
Where am I wrong? Thank you in advance!
4 REPLIES 4
scouil
Could you please post your logs?
menesthevs
Here you are:
12:58:11,573 ERROR [org.springframework.extensions.webscripts.AbstractRuntime] Exception from executeScript - redirecting to status template error: 01200004 Wrapped Exception (with status template): 01208032 Failed to execute script 'classpath*:alfresco/templates/webscripts/org/alfresco/slingshot/search/search.get.js': 01208031 Acceso denegado.  Usted carece de los permisos adecuados para realizar esta operaci?n.
org.springframework.extensions.webscripts.WebScriptException: 01200004 Wrapped Exception (with status template): 01208032 Failed to execute script 'classpath*:alfresco/templates/webscripts/org/alfresco/slingshot/search/search.get.js': 01208031 Acceso denegado.  Usted carece de los permisos adecuados para realizar esta operaci?n.
   at org.springframework.extensions.webscripts.AbstractWebScript.createStatusException(AbstractWebScript.java:1067)
   at org.alfresco.repo.web.scripts.RepositoryContainer$3.execute(RepositoryContainer.java:426)
   at org.alfresco.repo.transaction.RetryingTransactionHelper.doInTransaction(RetryingTransactionHelper.java:433)
   at org.alfresco.repo.web.scripts.RepositoryContainer.transactionedExecute(RepositoryContainer.java:495)
   at org.alfresco.repo.web.scripts.RepositoryContainer.transactionedExecuteAs(RepositoryContainer.java:533)
   at org.alfresco.repo.web.scripts.RepositoryContainer.executeScript(RepositoryContainer.java:349)
   at org.springframework.extensions.webscripts.AbstractRuntime.executeScript(AbstractRuntime.java:377)
   at javax.servlet.http.HttpServlet.service(HttpServlet.java:722)
   at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:472)
   at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:168)
   at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:99)
   at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:929)
   at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:407)
   at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1002)
   at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:585)
   at org.apache.tomcat.util.net.AprEndpoint$SocketProcessor.run(AprEndpoint.java:1813)
   at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1110)
   at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:603)
Caused by: org.alfresco.scripts.ScriptException: 01208032 Failed to execute script 'classpath*:alfresco/templates/webscripts/org/alfresco/slingshot/search/search.get.js': 01208031 Acceso denegado.  Usted carece de los permisos adecuados para realizar esta operaci?n.
   at org.alfresco.repo.jscript.RhinoScriptProcessor.execute(RhinoScriptProcessor.java:202)
   at org.alfresco.repo.processor.ScriptServiceImpl.execute(ScriptServiceImpl.java:212)
   at org.alfresco.repo.processor.ScriptServiceImpl.executeScript(ScriptServiceImpl.java:174)
   at org.alfresco.repo.web.scripts.RepositoryScriptProcessor.executeScript(RepositoryScriptProcessor.java:102)
   at org.springframework.extensions.webscripts.AbstractWebScript.executeScript(AbstractWebScript.java:1305)
   at org.springframework.extensions.webscripts.DeclarativeWebScript.execute(DeclarativeWebScript.java:86)
   … 28 more
Caused by: org.alfresco.repo.security.permissions.AccessDeniedException: 01208031 Acceso denegado.  Usted carece de los permisos adecuados para realizar esta operaci?n.
   at org.alfresco.repo.security.permissions.impl.ExceptionTranslatorMethodInterceptor.invoke(ExceptionTranslatorMethodInterceptor.java:50)
   at org.alfresco.repo.audit.AuditMethodInterceptor.proceed(AuditMethodInterceptor.java:187)
   at org.alfresco.repo.audit.AuditMethodInterceptor.invoke(AuditMethodInterceptor.java:164)
   at org.alfresco.repo.transaction.RetryingTransactionInterceptor$1.execute(RetryingTransactionInterceptor.java:69)
   at org.alfresco.repo.transaction.RetryingTransactionInterceptor.invoke(RetryingTransactionInterceptor.java:59)
   at org.alfresco.repo.audit.AuditMethodInterceptor.proceedWithAudit(AuditMethodInterceptor.java:245)
   at org.alfresco.repo.audit.AuditMethodInterceptor.proceed(AuditMethodInterceptor.java:211)
   at $Proxy9.getPath(Unknown Source)
   at org.alfresco.repo.jscript.ScriptNode.getQnamePath(ScriptNode.java:1159)
   at sun.reflect.GeneratedMethodAccessor642.invoke(Unknown Source)
   at java.lang.reflect.Method.invoke(Method.java:601)
   at org.mozilla.javascript.JavaMembers.get(JavaMembers.java:117)
   at org.mozilla.javascript.NativeJavaObject.get(NativeJavaObject.java:113)
   at org.mozilla.javascript.ScriptableObject.getProperty(ScriptableObject.java:1544)
   at org.mozilla.javascript.ScriptRuntime.getObjectProp(ScriptRuntime.java:1375)
   at org.mozilla.javascript.ScriptRuntime.getObjectProp(ScriptRuntime.java:1364)
   at org.mozilla.javascript.gen.c12._c13(file:/opt/alfresco-4.2.c/tomcat/webapps/alfresco/WEB-INF/classes/alfresco/templates/webscripts/org/alfresco/slingshot/search/search.get.js:522)
   at org.mozilla.javascript.gen.c12.call(file:/opt/alfresco-4.2.c/tomcat/webapps/alfresco/WEB-INF/classes/alfresco/templates/webscripts/org/alfresco/slingshot/search/search.get.js)
   at org.mozilla.javascript.optimizer.OptRuntime.callName(OptRuntime.java:97)
   at org.mozilla.javascript.gen.c12._c14(file:/opt/alfresco-4.2.c/tomcat/webapps/alfresco/WEB-INF/classes/alfresco/templates/webscripts/org/alfresco/slingshot/search/search.get.js:585)
   at org.mozilla.javascript.gen.c12._c20(file:/opt/alfresco-4.2.c/tomcat/webapps/alfresco/WEB-INF/classes/alfresco/templates/webscripts/org/alfresco/slingshot/search/search.get.js:1021)
   at org.mozilla.javascript.gen.c12._c22(file:/opt/alfresco-4.2.c/tomcat/webapps/alfresco/WEB-INF/classes/alfresco/templates/webscripts/org/alfresco/slingshot/search/search.get.js:1057)
   at org.mozilla.javascript.optimizer.OptRuntime.callName0(OptRuntime.java:108)
   at org.mozilla.javascript.gen.c12._c0(file:/opt/alfresco-4.2.c/tomcat/webapps/alfresco/WEB-INF/classes/alfresco/templates/webscripts/org/alfresco/slingshot/search/search.get.js:1060)
   at org.mozilla.javascript.gen.c12.exec(file:/opt/alfresco-4.2.c/tomcat/webapps/alfresco/WEB-INF/classes/alfresco/templates/webscripts/org/alfresco/slingshot/search/search.get.js)
   at org.alfresco.repo.jscript.RhinoScriptProcessor.executeScriptImpl(RhinoScriptProcessor.java:492)
   at org.alfresco.repo.jscript.RhinoScriptProcessor.execute(RhinoScriptProcessor.java:198)
   … 33 more
Caused by: net.sf.acegisecurity.AccessDeniedException: Access is denied.
   at net.sf.acegisecurity.vote.AffirmativeBased.decide(AffirmativeBased.java:86)
   at net.sf.acegisecurity.intercept.AbstractSecurityInterceptor.beforeInvocation(AbstractSecurityInterceptor.java:398)
   … 83 more
Greetings,
scouil
could you please try to disable auditing to see if that's related?
audit.enabled=false
audit.alfresco-access.enabled=false
menesthevs
Hi Scouil,
I disabled auditing, but it still doesn't work. Any other suggestion?
Greetings.
