Problem with FirstJCRClient
toze
HI. Im trying to get this sample to work, but till now i couldnt.
this is the error log
Exception in thread "main" org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'RepoServerMgmt' defined in class path resource [alfresco/core-services-context.xml]: Cannot resolve reference to bean 'transactionService' while setting bean property 'transactionService'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'transactionService' defined in class path resource [alfresco/core-services-context.xml]: Cannot resolve reference to bean 'transactionManager' while setting bean property 'transactionManager'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'transactionManager' defined in class path resource [alfresco/hibernate-context.xml]: Cannot resolve reference to bean 'sessionFactory' while setting bean property 'sessionFactory'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'sessionFactory' defined in class path resource [alfresco/hibernate-context.xml]: Invocation of init method failed; nested exception is java.io.FileNotFoundException: class path resource [org/alfresco/repo/domain/hibernate/QName.hbm.xml] cannot be opened because it does not exist
        at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:328)
        at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:106)
        at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyPropertyValues(AbstractAutowireCapableBeanFactory.java:1305)
        at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:1067)
        at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:511)
        at org.springframework.context.support.ClassPathXmlApplicationContext.<init>(ClassPathXmlApplicationContext.java:139)
        at org.springframework.context.support.ClassPathXmlApplicationContext.<init>(ClassPathXmlApplicationContext.java:83)
        at provaconceitoupload.FirstJCRClient.main(FirstJCRClient.java:47)
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'transactionService' defined in class path resource [alfresco/core-services-context.xml]: Cannot resolve reference to bean 'transactionManager' while setting bean property 'transactionManager'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'transactionManager' defined in class path resource [alfresco/hibernate-context.xml]: Cannot resolve reference to bean 'sessionFactory' while setting bean property 'sessionFactory'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'sessionFactory' defined in class path resource [alfresco/hibernate-context.xml]: Invocation of init method failed; nested exception is java.io.FileNotFoundException: class path resource [org/alfresco/repo/domain/hibernate/QName.hbm.xml] cannot be opened because it does not exist
        at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:322)
        … 15 more
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'transactionManager' defined in class path resource [alfresco/hibernate-context.xml]: Cannot resolve reference to bean 'sessionFactory' while setting bean property 'sessionFactory'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'sessionFactory' defined in class path resource [alfresco/hibernate-context.xml]: Invocation of init method failed; nested exception is java.io.FileNotFoundException: class path resource [org/alfresco/repo/domain/hibernate/QName.hbm.xml] cannot be opened because it does not exist
        … 25 more
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'sessionFactory' defined in class path resource [alfresco/hibernate-context.xml]: Invocation of init method failed; nested exception is java.io.FileNotFoundException: class path resource [org/alfresco/repo/domain/hibernate/QName.hbm.xml] cannot be opened because it does not exist
        at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1401)
        at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:512)
        … 35 more
Caused by: java.io.FileNotFoundException: class path resource [org/alfresco/repo/domain/hibernate/QName.hbm.xml] cannot be opened because it does not exist
        at org.springframework.core.io.ClassPathResource.getInputStream(ClassPathResource.java:141)
        at org.springframework.orm.hibernate3.LocalSessionFactoryBean.buildSessionFactory(LocalSessionFactoryBean.java:677)
        at org.springframework.orm.hibernate3.AbstractSessionFactoryBean.afterPropertiesSet(AbstractSessionFactoryBean.java:211)
        at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeInitMethods(AbstractAutowireCapableBeanFactory.java:1460)
        at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1398)
        … 42 more
Im using Ubuntu 9.04
Any one can help solve this problem?
5 REPLIES 5
toze
solved that
broken
Could you explain how you solved that please ?
because I've got the same error …
toze
well, first you have to set the same application server where is your alfresco.
second you have to set alfresco embedded jar in you libraries too
Hope that helps
broken
thanks for the reply,
Can you explain me your first sentence please ? I don't understand it ….
openpj
Elite Collaborator
Elite Collaborator
You have to configure a correct dir.root property and database settings for your Alfresco instance, in the custom-repository.properties.
Hope this helps.
