Problem with Call_WS
mtomi
My goal is to call succesfully a WebService in activity process.
I'm working with Servicemix 5.0.0. I started with example apache-servicemix-5.0.0/examples/activiti/activiti-camel , which I run succesfully via features:install.
Then I modified file OrderProcess.bpmn.xml and the main process in it looks like below now:
<process id="OrderProcess" isExecutable="true">
        <startEvent id="start"/>
        <sequenceFlow id="flow1" sourceRef="start" targetRef="Call_WS"/>
<serviceTask id="Call_WS" name="Call WS" activiti:class="org.apache.servicemix.examples.activiti.WsDelegate" >
      <extensionElements>
        <activiti:field name="wsdl" expression="http://localhost:8282/dodawanie?wsdl" />
        <activiti:field name="operation" expression="sayHi" />
        <activiti:field name="parameters" expression="${arg0}" />
        <activiti:field name="returnValue" expression="sayHiResponse" />
      </extensionElements>
    </serviceTask>
     <sequenceFlow id="flow2" sourceRef="Call_WS" targetRef="end"/>
<endEvent id="end"/>
    </process>
I use the class WsDelegate I found as a sample to help calling WebService from activiti process, and it looks like below:
package org.apache.servicemix.examples.activiti;
import java.util.ArrayList;
import java.util.StringTokenizer;
import org.activiti.engine.delegate.Expression;
import org.activiti.engine.delegate.JavaDelegate;
import org.apache.cxf.endpoint.Client;
import org.apache.cxf.jaxws.endpoint.dynamic.JaxWsDynamicClientFactory;
import javax.xml.namespace.*;
public class WsDelegate implements JavaDelegate {
    private Expression wsdl;
     private Expression operation;
     private Expression parameters;
     private Expression returnValue;
       String wsdlString = (String)wsdl.getValue(execution);
       JaxWsDynamicClientFactory dcf = JaxWsDynamicClientFactory.newInstance();
       Client client = dcf.createClient(wsdlString);
       ArrayList paramStrings = new ArrayList();
       if (parameters!=null) {
         StringTokenizer st = new StringTokenizer( (String)parameters.getValue(execution), ",");
         while (st.hasMoreTokens()) {
           paramStrings.add(st.nextToken().trim());
       Object response = client.invoke((String)operation.getValue(execution), paramStrings.toArray(new Object[0]));
       if (returnValue!=null) {
         String returnVariableName = (String) returnValue.getValue(execution);
         execution.setVariable(returnVariableName, response);
I modified example class ActivitiRouteBuilder and this is the code after modification:
import static org.activiti.camel.ActivitiProducer.PROCESS_KEY_PROPERTY;
import java.util.HashMap;
import java.util.Map;
import org.apache.camel.Exchange;
import org.apache.camel.Handler;
import org.apache.camel.Message;
import org.apache.camel.builder.RouteBuilder;
* Camel routes that interact with the business process defined in the
* OSGI-INF/activiti/OrderProcess.bpmn20.xml file
public class ActivitiRouteBuilder extends RouteBuilder {
    private final Helper helper = new Helper();
    @Override
    public void configure() throws Exception {
         * This route will start a new OrderProcess instance.  Using the PROCESS_KEY_PROPERTY, we are assigning a
         * business key to our process to allow for easier correlation in later processing steps.  We are also
         * sending a Map containing additional variables to add to the process instance.
        from("jetty:http://0.0.0.0:8484/test")
            .setBody(bean(helper))
            .setProperty(PROCESS_KEY_PROPERTY, simple("file:name"))
            .to("activiti:OrderProcess")
            .log("Process to handle incoming order file has been started (process instance id ${body})");
         * This route will notify a running OrderProcess of an order delivery event.  Here too, we are setting the
         * PROCESS_KEY_PROPERTY to correlate the delivery message with right order process instance.
        from("file:var/activiti-camel/delivery")
            .log("Notifying process about delivery for order ${file:name}")
            .to("activiti:OrderProcess:receiveDelivery");
         * The BPMN process can also trigger Camel routes as part of the process.  In these routes, the variables that
         * you added to the process are available as Exchange properties.  The next two routes will be triggered while
         * processing the order and the order delivery.
        from("activiti:OrderProcess:processOrder")
            .log("Processing order ${property.orderid} created on ${property:timestamp}")
            .log("  original message: ${property.message}");
        from("activiti:OrderProcess:processDelivery")
            .log("Processing delivery for order ${property.orderid} created on ${property:timestamp}")
     * A few helper methods used for routing
    public static final class Helper {
         * This method will extract information from the Exchange (using Camel annotations) and put them in a
         * Map that will be used for setting up the process' variables.
        @Handler
        public Map getProcessVariables(Exchange exchange) {
           Message in = exchange.getIn();
            Map<String, Object> variables = new HashMap<String, Object>();
            variables.put("message", "pusto");
            variables.put("orderid", in.getHeader("id"));
            variables.put("timestamp", "teraz");
            return variables;
And when I try to start the process through calling http://localhost:8484/test
i get this stack trace:
org.apache.camel.CamelExecutionException: Exception occurred during execution on the exchange: Exchange[Message: {timestamp=teraz, message=pusto, orderid=null}]
   at org.apache.camel.util.ObjectHelper.wrapCamelExecutionException(ObjectHelper.java:1379)
   at org.apache.camel.impl.DefaultExchange.setException(DefaultExchange.java:283)
   at org.apache.camel.util.AsyncProcessorConverterHelper$ProcessorToAsyncProcessorBridge.process(AsyncProcessorConverterHelper.java:64)
   at org.apache.camel.processor.SendProcessor.process(SendProcessor.java:110)
   at org.apache.camel.management.InstrumentationProcessor.process(InstrumentationProcessor.java:72)
   at org.apache.camel.processor.RedeliveryErrorHandler.process(RedeliveryErrorHandler.java:398)
   at org.apache.camel.processor.CamelInternalProcessor.process(CamelInternalProcessor.java:191)
   at org.apache.camel.processor.Pipeline.process(Pipeline.java:118)
   at org.apache.camel.processor.Pipeline.process(Pipeline.java:80)
   at org.apache.camel.component.jetty.CamelContinuationServlet.service(CamelContinuationServlet.java:151)
   at javax.servlet.http.HttpServlet.service(HttpServlet.java:806)
   at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:652)
   at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1320)
   at org.eclipse.jetty.servlets.MultiPartFilter.doFilter(MultiPartFilter.java:119)
   at org.apache.camel.component.jetty.CamelFilterWrapper.doFilter(CamelFilterWrapper.java:44)
   at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1291)
   at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:443)
   at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1044)
   at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:372)
   at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:978)
   at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:135)
   at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:116)
   at org.eclipse.jetty.server.Server.handle(Server.java:363)
   at org.eclipse.jetty.server.AbstractHttpConnection.handleRequest(AbstractHttpConnection.java:486)
   at org.eclipse.jetty.server.AbstractHttpConnection.headerComplete(AbstractHttpConnection.java:926)
   at org.eclipse.jetty.server.AbstractHttpConnection$RequestHandler.headerComplete(AbstractHttpConnection.java:988)
   at org.eclipse.jetty.http.HttpParser.parseNext(HttpParser.java:640)
   at org.eclipse.jetty.http.HttpParser.parseAvailable(HttpParser.java:235)
   at org.eclipse.jetty.server.AsyncHttpConnection.handle(AsyncHttpConnection.java:82)
   at org.eclipse.jetty.io.nio.SelectChannelEndPoint.handle(SelectChannelEndPoint.java:628)
   at org.eclipse.jetty.io.nio.SelectChannelEndPoint$1.run(SelectChannelEndPoint.java:52)
   at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:608)
   at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:543)
Caused by: java.lang.NoClassDefFoundError: Ljavax/xml/namespace/QName;
   at java.lang.Class.getDeclaredFields0(Native Method)
   at java.lang.Class.privateGetDeclaredFields(Class.java:2308)
   at java.lang.Class.getDeclaredFields(Class.java:1760)
   at com.sun.xml.bind.v2.model.nav.ReflectionNavigator.getDeclaredFields(ReflectionNavigator.java:274)
   at com.sun.xml.bind.v2.model.nav.ReflectionNavigator.getDeclaredFields(ReflectionNavigator.java:57)
   at com.sun.xml.bind.v2.model.impl.ClassInfoImpl.findFieldProperties(ClassInfoImpl.java:377)
   at com.sun.xml.bind.v2.model.impl.ClassInfoImpl.getProperties(ClassInfoImpl.java:308)
   at com.sun.xml.bind.v2.model.impl.RuntimeClassInfoImpl.getProperties(RuntimeClassInfoImpl.java:176)
   at com.sun.xml.bind.v2.model.impl.ModelBuilder.getClassInfo(ModelBuilder.java:243)
   at com.sun.xml.bind.v2.model.impl.RuntimeModelBuilder.getClassInfo(RuntimeModelBuilder.java:100)
   at com.sun.xml.bind.v2.model.impl.RuntimeModelBuilder.getClassInfo(RuntimeModelBuilder.java:81)
   at com.sun.xml.bind.v2.model.impl.ModelBuilder.getClassInfo(ModelBuilder.java:209)
   at com.sun.xml.bind.v2.model.impl.RuntimeModelBuilder.getClassInfo(RuntimeModelBuilder.java:95)
   at com.sun.xml.bind.v2.model.impl.ModelBuilder.getTypeInfo(ModelBuilder.java:315)
   at com.sun.xml.bind.v2.model.impl.ModelBuilder.getTypeInfo(ModelBuilder.java:330)
   at com.sun.xml.bind.v2.runtime.JAXBContextImpl.getTypeInfoSet(JAXBContextImpl.java:466)
   at com.sun.xml.bind.v2.runtime.JAXBContextImpl.<init>(JAXBContextImpl.java:302)
   at com.sun.xml.bind.v2.runtime.JAXBContextImpl$JAXBContextBuilder.build(JAXBContextImpl.java:1140)
   at com.sun.xml.bind.v2.ContextFactory.createContext(ContextFactory.java:154)
   at com.sun.xml.bind.v2.ContextFactory.createContext(ContextFactory.java:121)
   at com.sun.xml.bind.v2.ContextFactory.createContext(ContextFactory.java:202)
   at java.lang.reflect.Method.invoke(Method.java:601)
   at javax.xml.bind.ContextFinder.newInstance(ContextFinder.java:143)
   at javax.xml.bind.ContextFinder.find(ContextFinder.java:310)
   at javax.xml.bind.JAXBContext.newInstance(JAXBContext.java:446)
   at org.apache.cxf.endpoint.dynamic.DynamicClientFactory.createClient(DynamicClientFactory.java:393)
   at org.apache.cxf.endpoint.dynamic.DynamicClientFactory.createClient(DynamicClientFactory.java:240)
   at org.apache.cxf.endpoint.dynamic.DynamicClientFactory.createClient(DynamicClientFactory.java:233)
   at org.apache.cxf.endpoint.dynamic.DynamicClientFactory.createClient(DynamicClientFactory.java:188)
   at org.apache.servicemix.examples.activiti.WsDelegate.execute(WsDelegate.java:22)
   at org.activiti.engine.impl.delegate.JavaDelegateInvocation.invoke(JavaDelegateInvocation.java:34)
   at org.activiti.engine.impl.delegate.DelegateInvocation.proceed(DelegateInvocation.java:37)
   at org.activiti.engine.impl.delegate.DefaultDelegateInterceptor.handleInvocation(DefaultDelegateInterceptor.java:25)
   at org.activiti.engine.impl.bpmn.behavior.ServiceTaskJavaDelegateActivityBehavior.execute(ServiceTaskJavaDelegateActivityBehavior.java:49)
   at org.activiti.engine.impl.bpmn.behavior.ServiceTaskJavaDelegateActivityBehavior.execute(ServiceTaskJavaDelegateActivityBehavior.java:40)
   at org.activiti.engine.impl.bpmn.helper.ClassDelegate.execute(ClassDelegate.java:115)
   at org.activiti.engine.impl.pvm.runtime.AtomicOperationActivityExecute.execute(AtomicOperationActivityExecute.java:44)
   at org.activiti.engine.impl.interceptor.CommandContext.performOperation(CommandContext.java:80)
   at org.activiti.engine.impl.persistence.entity.ExecutionEntity.performOperationSync(ExecutionEntity.java:546)
   at org.activiti.engine.impl.persistence.entity.ExecutionEntity.performOperation(ExecutionEntity.java:541)
   at org.activiti.engine.impl.pvm.runtime.AtomicOperationTransitionNotifyListenerStart.eventNotificationsCompleted(AtomicOperationTransitionNotifyListenerStart.java:52)
   at org.activiti.engine.impl.pvm.runtime.AbstractEventAtomicOperation.execute(AbstractEventAtomicOperation.java:56)
   at org.activiti.engine.impl.pvm.runtime.AbstractEventAtomicOperation.execute(AbstractEventAtomicOperation.java:49)
   at org.activiti.engine.impl.pvm.runtime.AtomicOperationTransitionCreateScope.execute(AtomicOperationTransitionCreateScope.java:49)
   at org.activiti.engine.impl.pvm.runtime.AtomicOperationTransitionNotifyListenerTake.execute(AtomicOperationTransitionNotifyListenerTake.java:65)
   at org.activiti.engine.impl.pvm.runtime.AtomicOperationTransitionDestroyScope.execute(AtomicOperationTransitionDestroyScope.java:115)
   at org.activiti.engine.impl.pvm.runtime.AtomicOperationTransitionNotifyListenerEnd.eventNotificationsCompleted(AtomicOperationTransitionNotifyListenerEnd.java:36)
   at org.activiti.engine.impl.persistence.entity.ExecutionEntity.take(ExecutionEntity.java:381)
   at org.activiti.engine.impl.bpmn.behavior.BpmnActivityBehavior.performOutgoingBehavior(BpmnActivityBehavior.java:102)
   at org.activiti.engine.impl.bpmn.behavior.BpmnActivityBehavior.performDefaultOutgoingBehavior(BpmnActivityBehavior.java:51)
   at org.activiti.engine.impl.bpmn.behavior.FlowNodeActivityBehavior.leave(FlowNodeActivityBehavior.java:44)
   at org.activiti.engine.impl.bpmn.behavior.FlowNodeActivityBehavior.execute(FlowNodeActivityBehavior.java:36)
   at org.activiti.engine.impl.pvm.runtime.AtomicOperationProcessStartInitial.eventNotificationsCompleted(AtomicOperationProcessStartInitial.java:46)
   at org.activiti.engine.impl.pvm.runtime.AtomicOperationProcessStart.eventNotificationsCompleted(AtomicOperationProcessStart.java:45)
   at org.activiti.engine.impl.persistence.entity.ExecutionEntity.start(ExecutionEntity.java:335)
   at org.activiti.engine.impl.cmd.StartProcessInstanceCmd.execute(StartProcessInstanceCmd.java:72)
   at org.activiti.engine.impl.cmd.StartProcessInstanceCmd.execute(StartProcessInstanceCmd.java:31)
   at org.activiti.engine.impl.interceptor.CommandExecutorImpl.execute(CommandExecutorImpl.java:24)
   at org.activiti.engine.impl.interceptor.CommandContextInterceptor.execute(CommandContextInterceptor.java:42)
   at org.activiti.engine.impl.interceptor.JtaTransactionInterceptor.execute(JtaTransactionInterceptor.java:59)
   at org.activiti.engine.impl.RuntimeServiceImpl.startProcessInstanceByKey(RuntimeServiceImpl.java:55)
   at Proxyf138e743_9da0_45a4_be4e_6b2c8e65cd48.startProcessInstanceByKey(Unknown Source)
   at org.activiti.camel.ActivitiProducer.startProcess(ActivitiProducer.java:93)
   at org.activiti.camel.ActivitiProducer.process(ActivitiProducer.java:48)
   at org.apache.camel.util.AsyncProcessorConverterHelper$ProcessorToAsyncProcessorBridge.process(AsyncProcessorConverterHelper.java:61)
   … 32 more
Caused by: java.lang.ClassNotFoundException: javax.xml.namespace.QName
   at java.net.URLClassLoader$1.run(URLClassLoader.java:366)
   at java.net.URLClassLoader$1.run(URLClassLoader.java:355)
   at java.net.URLClassLoader.findClass(URLClassLoader.java:354)
   at java.lang.ClassLoader.loadClass(ClassLoader.java:423)
   at java.lang.ClassLoader.loadClass(ClassLoader.java:356)
   … 137 more
What should I do to make it run?
5 REPLIES 5
frederikherema1
What JDK are you using?
mtomi
JDK1.7.0_09
jbarrez
Seems to be an issue with osgi/service mix and camel more than with Actviti.
Googling that exceptions leads to posts like http://camel.465427.n5.nabble.com/NoClassDefFoundError-javax-xml-namespace-QName-CXF-SOAP-Consumer-t... … but my expertise there is too limited to actuall understand what is going on…
mtomi
I used this (javax.xml.bind is for JAXBElement which was another missing class after repairing javax.xml.namespace.QName):
<code><DynamicImport-Package>javax.xml.bind,javax.xml.namespace</DynamicImport-Package></code>
and it run with:
<code>
org.activiti.engine.impl.javax.el.PropertyNotFoundException: Cannot resolve identifier 'arg0'
</code>
so i thinks it is calling Web Service.
Now I have to learn how transfer the data from bpmn process to Web Service, right?
jbarrez
Good, you are one stap closer. You will indeed now have to make sure to pass the right data to the webservice.
