Problem with Alfresco 2.0 and Liferay 4.3.4 Upgrade
schoony99
Hello, I am trying to upgrade our Liferay 4.2.2 installation to 4.3.4. We use Alfresco 2.0 and CAS for single sign-on. We use a fedora ldap server for authentication.
My problem is as follows: The upgrade seems to somehow break the connection between Alfresco and Liferay as far as user accounts go. For instance, I login to Liferay with user 'xyz', but Alfresco thinks I am user '123' (non-existant and always numerical) so my Alfresco spaces, content, etc. is missing for user xyz. The logout button, which used to say "Logout xyz" now says "Logout 123". All the while Liferay is displaying the correct username and info.
My Alfresco log shows no errors, nor does my LDAP server log show any attempt for user '123'. I do not understand where or why Alfresco is getting these bogus user accounts. Anyone have any ideas? If you need any more info from me, please ask! Thanks!
schoony99
Below is a response I got on the Liferay forum. Does this ring any bells with anyone? If it does, could someone tell me how to do this?
"Well, in version 4.3 Liferay changed userId to integer id. The old id is now called screeName. You probably need to update the ids in Alfresco to numeric ones."
