Problem using repository/process-definition Rest API
chala_chitturi
I am getting the following response when tried to access using the following resource
http://localhost:8080/activiti-rest/service/repository/process-definitions
Response
errorMessage: "unknown type 'user' approver"
statusCode: 400
I am following UserGuide and vanilla version of the activiti wars exploded.
Please see the attachment for the exception on the apache catalina log.
Here is my environment
Using activiti 5.14
I am connecting to MySQL 5.6.14 locally.
Operating System is Mac OS X 10.9 on MacBook Pro
Java 1.7.0_45 and apache tomcat 7.0.47
Here are the details of My mysql instance
| Variable_name           | Value                        |
| innodb_version          | 5.6.14                       |
| protocol_version        | 10                           |
| slave_type_conversions  |                              |
| version                 | 5.6.14                       |
| version_comment         | MySQL Community Server (GPL) |
| version_compile_machine | x86_64                       |
| version_compile_os      | osx10.7                      |
trademak
This question has already been asked on the forum.
The problem is that you are using the example Activiti Explorer process definitions. And those include a user form property which is not known in the Activiti REST application by default. We should fix this to prevent this issue. But it's just a demo data issue. So if you remove the process definition containing this user form property it should be ok.
Best regards,
chala_chitturi
Thank You. It worked.
I removed all demo data except users and groups.
