I have installed Alfresco-Enterprise-3.0.1-Full-Setup.exe in my PC. My PC's RAM size is 2 GB. It has Windows XP as OS. The problem I am facing is, everytime I start the alfresco server my m/c gets freezed and I m not able to start my work on alfresco. I m pasting my logs here.
Please help me to resolve my issue.
Catalina Log:
Feb 25, 2009 4:46:22 PM org.apache.coyote.http11.Http11Protocol init
Feb 25, 2009 4:46:22 PM org.apache.catalina.startup.Catalina load
INFO: Initialization processed in 2432 ms
Feb 25, 2009 4:46:22 PM org.apache.catalina.core.StandardService start
Feb 25, 2009 4:46:22 PM org.apache.catalina.core.StandardEngine start
Feb 25, 2009 4:46:22 PM org.apache.catalina.startup.HostConfig deployWAR
Feb 25, 2009 4:47:32 PM org.apache.catalina.core.StandardContext addApplicationListener
Alfresco Log:
16:48:29,186 INFO [org.alfresco.config.xml.XMLConfigService$PropertyConfigurer] Loading properties file from class path resource [alfresco/file-servers.properties]
16:48:59,264 INFO [org.alfresco.repo.domain.schema.SchemaBootstrap] Schema managed by database dialect org.hibernate.dialect.DerbyDialect.
16:48:59,280 INFO [org.alfresco.repo.domain.schema.SchemaBootstrap] Alfresco is using the Apache Derby default database. Please only use this while evaluating Alfresco, it is NOT recommended for production or deployment!
16:49:00,655 INFO [org.alfresco.repo.domain.schema.SchemaBootstrap] Executing database script C:\Alfresco\tomcat\temp\Alfresco\AlfrescoSchemaCreate-org.hibernate.dialect.DerbyDialect-495.sql (Generated).
16:49:53,295 INFO [org.alfresco.repo.domain.schema.SchemaBootstrap] Executing database script C:\Alfresco\tomcat\temp\Alfresco\AlfrescoSchemaUpdate-org.hibernate.dialect.DerbyDialect-496.sql (Copied from classpath:alfresco/dbscripts/create/2.2/org.hibernate.dialect.DerbyDialect/AlfrescoPostCreate-2.2-MappedFKIndexes.sql).
16:49:53,514 INFO [org.alfresco.repo.domain.schema.SchemaBootstrap] Executing database script C:\Alfresco\tomcat\temp\Alfresco\AlfrescoSchemaUpdate-org.hibernate.dialect.DerbyDialect-497.sql (Copied from classpath:alfresco/dbscripts/create/2.2/org.hibernate.dialect.DerbyDialect/AlfrescoPostCreate-2.2-Extra.sql).
16:49:55,592 INFO [org.alfresco.repo.domain.schema.SchemaBootstrap] Executing database script C:\Alfresco\tomcat\temp\Alfresco\AlfrescoSchemaUpdate-org.hibernate.dialect.DerbyDialect-498.sql (Copied from classpath:alfresco/dbscripts/create/2.2/org.hibernate.dialect.DerbyDialect/post-create-indexes-04.sql).
16:49:55,795 INFO [org.alfresco.repo.domain.schema.SchemaBootstrap] Executing database script C:\Alfresco\tomcat\temp\Alfresco\AlfrescoSchemaUpdate-org.hibernate.dialect.DerbyDialect-499.sql (Copied from classpath:alfresco/dbscripts/create/3.0/org.hibernate.dialect.DerbyDialect/create-activities-extras.sql).
16:49:58,577 INFO [org.alfresco.repo.domain.schema.SchemaBootstrap] All executed statements written to file C:\Alfresco\tomcat\temp\Alfresco\AlfrescoSchemaUpdate-All_Statements-500.sql.
16:50:59,186 ERROR [org.alfresco.util.exec.RuntimeExecBootstrapBean] Bootstrap command failed:
Execution result:
os: Windows XP
command: [C:/Alfresco/openoffice/OpenOffice.org 3/program/soffice, "-accept=socket,host=localhost,port=8100;urp;StarOffice.ServiceManager", "-env:UserInstallation=file:///C:/Alfresco/alf_data/oouser", -nologo, -headless, -nofirststartwizard, -nocrashrep, -norestore]
succeeded: false
exit code: 2
out:
err: CreateProcess: "C:\Alfresco\openoffice\OpenOffice.org 3\program\soffice" "-accept=socket,host=localhost,port=8100;urp;StarOffice.ServiceManager" "-env:UserInstallation=file:///C:/Alfresco/alf_data/oouser" -nologo -headless -nofirststartwizard -nocras
16:51:02,358 INFO [org.alfresco.service.descriptor.DescriptorService] Alfresco license: Creating time limited trial license
16:51:04,030 INFO [org.alfresco.repo.admin.ConfigurationChecker] The Alfresco root data directory ('dir.root') is: C:\Alfresco\alf_data
16:51:04,092 INFO [org.alfresco.repo.admin.patch.PatchExecuter] Checking for patches to apply …
16:51:04,952 INFO [org.alfresco.repo.admin.patch.PatchExecuter] Applying patch 'patch.wcmFolders' (Ensures the existance of the WCM specific 'Web Projects' and 'Web Forms' folders.).
16:51:05,342 INFO [org.alfresco.repo.admin.patch.PatchExecuter]
=== Applied patch ===
RESULT:
The Web Projects folder was successfully created: workspace://SpacesStore/57567941-0a98-4636-b185-1bfd5a407988
The Web Forms folder was successfully created: workspace://SpacesStore/57567941-0a98-4636-b185-1bfd5a407988
16:51:05,358 INFO [org.alfresco.repo.module.ModuleServiceImpl] Found 1 module(s).
16:51:05,467 INFO [org.alfresco.repo.module.ModuleServiceImpl] Installing module 'org.alfresco.module.vti' version 1.0.
16:51:38,061 WARN [org.alfresco.util.OpenOfficeConnectionTester] An initial OpenOffice connection could not be established.
16:51:38,498 INFO [org.alfresco.service.descriptor.DescriptorService] Alfresco JVM - v1.5.0_05-b05; maximum heap size 506.313MB
16:51:38,811 INFO [org.alfresco.service.descriptor.DescriptorService] Alfresco license: Enterprise - v3.0 granted to Trial User limited to 30 days expiring Fri Mar 27 00:00:00 IST 2009 (30 days remaining)
16:51:38,811 INFO [org.alfresco.service.descriptor.DescriptorService] Alfresco started (Enterprise): Current version 3.0.1 (303) schema 501 - Installed version 3.0.1 (303) schema 501
16:51:40,092 WARN [org.alfresco.repo.activities.feed.AbstractFeedGenerator] Still busy …
