I am trying to run the samples of the SDK2.1. When i ran FirstJCRClient, i got this error.
18:13:26,310 ERROR [transform.magick.AbstractImageMagickContentTransformer] ImageMagickContentTransformer not available: Failed to perform ImageMagick transformation:
Execution result:
os: Windows XP
command: imconvert "C:\DOCUME~1\161441\LOCALS~1\Temp\Alfresco\ImageMagickContentTransformer_init_source_24527.gif" "C:\DOCUME~1\161441\LOCALS~1\Temp\Alfresco\ImageMagickContentTransformer_init_target_24528.png"
succeeded: false
exit code: 1
out:
err: CreateProcess: imconvert "C:\DOCUME~1\161441\LOCALS~1\Temp\Alfresco\ImageMagickContentTransformer_init_source_24527.gif" "C:\DOCUME~1\161441\LOCALS~1\Temp\Alfresco\ImageMagickContentTransformer_init_target_24528.png" error=2
Exception in thread "main" org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'serverConnector' defined in class path resource [alfresco/core-services-context.xml]: Invocation of init method failed; nested exception is java.io.IOException: Cannot bind to URL [rmi://localhost:1313/alfresco/jmxrmi]: javax.naming.NameAlreadyBoundException: alfresco/jmxrmi [Root exception is java.rmi.AlreadyBoundException: alfresco/jmxrmi]
Caused by: java.io.IOException: Cannot bind to URL [rmi://localhost:1313/alfresco/jmxrmi]: javax.naming.NameAlreadyBoundException: alfresco/jmxrmi [Root exception is java.rmi.AlreadyBoundException: alfresco/jmxrmi]
at javax.management.remote.rmi.RMIConnectorServer.newIOException(Unknown Source)
at javax.management.remote.rmi.RMIConnectorServer.start(Unknown Source)
at org.springframework.jmx.support.ConnectorServerFactoryBean.afterPropertiesSet(ConnectorServerFactoryBean.java:168)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeInitMethods(AbstractAutowireCapableBeanFactory.java:1118)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1085)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:429)
at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:250)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:141)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:247)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:161)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:270)
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:346)
at org.springframework.context.support.ClassPathXmlApplicationContext.<init>(ClassPathXmlApplicationContext.java:92)
at org.springframework.context.support.ClassPathXmlApplicationContext.<init>(ClassPathXmlApplicationContext.java:77)
at org.springframework.context.support.ClassPathXmlApplicationContext.<init>(ClassPathXmlApplicationContext.java:68)
at org.alfresco.sample.FirstJCRClient.main(FirstJCRClient.java:64)
Caused by: javax.naming.NameAlreadyBoundException: alfresco/jmxrmi [Root exception is java.rmi.AlreadyBoundException: alfresco/jmxrmi]
at com.sun.jndi.rmi.registry.RegistryContext.bind(Unknown Source)
at com.sun.jndi.toolkit.url.GenericURLContext.bind(Unknown Source)
at javax.naming.InitialContext.bind(Unknown Source)
at javax.management.remote.rmi.RMIConnectorServer.bind(Unknown Source)
… 15 more
Caused by: java.rmi.AlreadyBoundException: alfresco/jmxrmi
at sun.rmi.registry.RegistryImpl.bind(RegistryImpl.java:123)
at sun.rmi.registry.RegistryImpl_Skel.dispatch(Unknown Source)
at sun.rmi.server.UnicastServerRef.oldDispatch(UnicastServerRef.java:375)
at sun.rmi.server.UnicastServerRef.dispatch(UnicastServerRef.java:240)
at sun.rmi.transport.Transport$1.run(Transport.java:153)
at sun.rmi.transport.Transport.serviceCall(Transport.java:149)
at sun.rmi.transport.tcp.TCPTransport.handleMessages(TCPTransport.java:466)
at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run(TCPTransport.java:707)
at sun.rmi.transport.StreamRemoteCall.exceptionReceivedFromServer(Unknown Source)
at sun.rmi.transport.StreamRemoteCall.executeCall(Unknown Source)
at sun.rmi.server.UnicastRef.invoke(Unknown Source)
at sun.rmi.registry.RegistryImpl_Stub.bind(Unknown Source)
… 19 more
Please help me.
