Problem in running SDK2.1, FirstJCRClient
naveenkumar
I am trying to run the samples of the SDK2.1. When i ran FirstJCRClient, i got this error.
18:13:26,310 ERROR [transform.magick.AbstractImageMagickContentTransformer] ImageMagickContentTransformer not available: Failed to perform ImageMagick transformation:
Execution result:
   os:         Windows XP
   command:    imconvert "C:\DOCUME~1\161441\LOCALS~1\Temp\Alfresco\ImageMagickContentTransformer_init_source_24527.gif"  "C:\DOCUME~1\161441\LOCALS~1\Temp\Alfresco\ImageMagickContentTransformer_init_target_24528.png"
   succeeded:  false
   exit code:  1
   out:
   err:        CreateProcess: imconvert "C:\DOCUME~1\161441\LOCALS~1\Temp\Alfresco\ImageMagickContentTransformer_init_source_24527.gif" "C:\DOCUME~1\161441\LOCALS~1\Temp\Alfresco\ImageMagickContentTransformer_init_target_24528.png" error=2
Exception in thread "main" org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'serverConnector' defined in class path resource [alfresco/core-services-context.xml]: Invocation of init method failed; nested exception is java.io.IOException: Cannot bind to URL [rmi://localhost:1313/alfresco/jmxrmi]: javax.naming.NameAlreadyBoundException: alfresco/jmxrmi [Root exception is java.rmi.AlreadyBoundException: alfresco/jmxrmi]
Caused by: java.io.IOException: Cannot bind to URL [rmi://localhost:1313/alfresco/jmxrmi]: javax.naming.NameAlreadyBoundException: alfresco/jmxrmi [Root exception is java.rmi.AlreadyBoundException: alfresco/jmxrmi]
   at javax.management.remote.rmi.RMIConnectorServer.newIOException(Unknown Source)
   at javax.management.remote.rmi.RMIConnectorServer.start(Unknown Source)
   at org.springframework.jmx.support.ConnectorServerFactoryBean.afterPropertiesSet(ConnectorServerFactoryBean.java:168)
   at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeInitMethods(AbstractAutowireCapableBeanFactory.java:1118)
   at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1085)
   at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:429)
   at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:250)
   at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:141)
   at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:247)
   at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:161)
   at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:270)
   at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:346)
   at org.springframework.context.support.ClassPathXmlApplicationContext.<init>(ClassPathXmlApplicationContext.java:92)
   at org.springframework.context.support.ClassPathXmlApplicationContext.<init>(ClassPathXmlApplicationContext.java:77)
   at org.springframework.context.support.ClassPathXmlApplicationContext.<init>(ClassPathXmlApplicationContext.java:68)
   at org.alfresco.sample.FirstJCRClient.main(FirstJCRClient.java:64)
Caused by: javax.naming.NameAlreadyBoundException: alfresco/jmxrmi [Root exception is java.rmi.AlreadyBoundException: alfresco/jmxrmi]
   at com.sun.jndi.rmi.registry.RegistryContext.bind(Unknown Source)
   at com.sun.jndi.toolkit.url.GenericURLContext.bind(Unknown Source)
   at javax.naming.InitialContext.bind(Unknown Source)
   at javax.management.remote.rmi.RMIConnectorServer.bind(Unknown Source)
   â€¦ 15 more
Caused by: java.rmi.AlreadyBoundException: alfresco/jmxrmi
   at sun.rmi.registry.RegistryImpl.bind(RegistryImpl.java:123)
   at sun.rmi.registry.RegistryImpl_Skel.dispatch(Unknown Source)
   at sun.rmi.server.UnicastServerRef.oldDispatch(UnicastServerRef.java:375)
   at sun.rmi.server.UnicastServerRef.dispatch(UnicastServerRef.java:240)
   at sun.rmi.transport.Transport$1.run(Transport.java:153)
   at sun.rmi.transport.Transport.serviceCall(Transport.java:149)
   at sun.rmi.transport.tcp.TCPTransport.handleMessages(TCPTransport.java:466)
   at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run(TCPTransport.java:707)
   at sun.rmi.transport.StreamRemoteCall.exceptionReceivedFromServer(Unknown Source)
   at sun.rmi.transport.StreamRemoteCall.executeCall(Unknown Source)
   at sun.rmi.server.UnicastRef.invoke(Unknown Source)
   at sun.rmi.registry.RegistryImpl_Stub.bind(Unknown Source)
   â€¦ 19 more
Please help me.
4 REPLIES 4
finner
This looks like you may be running the Alfresco server already. Stop the alfresco server and run the JCR example from the SDK.
Hope this helps
Finner
finner
If you are still having difficulty with the FirstJCRClient try adding the jars
alfresco-deployment.jar
alfresco-linkvalidation.jar
to the SDK AlfrescoEmbedded project.
See:
http://issues.alfresco.com/browse/AR-1567
The FirstJCRClient example in SDK 2.1 works for me now.
But remember to stop the server before running the example. You will get a NameAlreadyBoundException if your server is running and then you try to run the example.
Finner
naveenkumar
Thanks man…
Cool  Smiley Very Happy
Naveen
unknown-user
You should add the folder where the imconvert.exe is to the PATH. The folder is the ….\alfresco-community-tomcat-2.1.0\bin
For running the JCR examples of 2.1 you should STOP the server as these examples starts an embedded alfresco instance with e.g. RMI server which set up to be bound to the same port as yournormal Alfresco instance using.
