Problem in integrating Alfresco and Drupal
‎05-15-2013 08:15 AM
We have already downloaded the extension module to alfresco and configured settings.php with following content:
# $conf['allow_authorize_operations'] = FALSE;
$conf['cmis_repositories'] = array(
'default' => array(
'user' => 'admin',
'password' => 'alfresco',
'url' => 'http://localhost:8080/alfresco/cmis'
The problem is when we try to access 'http://localhost:8080/drupal/cmis/browser' the repository is not shown!
It gives a HTTP 500 error. What are we missing? Please help.
We followed the following article:
http://www.unorganizedmachines.com/site/software-and-technology/34-software-development/98-integrati...
Archive
‎05-15-2013 12:04 PM
Is that drupal is installed on the same application server where Alfresco is installed?
If not, then specify the host and port where drupal is installed.
Hope this helps!!
‎02-12-2014 01:54 PM
In the last sentence in the above paragraph do you mean:
"If not, then specify the host and port where Alfresco is installed."
It's a connector for Drupal TO Alfresco… right?
So, in my case, it is http://xxx.xxx.xxx.xxx:8080/alfresco/service/cmis where the xxx is the public IP of the Alfresco server.
‎05-16-2013 02:15 AM
yeah, drupal and alfresco are installed on the same application server. I also changed the url to http://localhost:8080/alfresco/service/cmis.
But whenever i try to add an alfresco item..
Following error appears:
Page not found
The requested page "/drupal7/?q=alfresco/browser?r=Q9OZ5RDLic1KMB-cV5RYnCMsgqawOmbR5DHnEzibOzc&n=edit-alfresco-browser-name" could not be found.
Why is drupal still not able to locate alfresco browser?
Kindly suggest..
‎05-16-2013 07:00 AM
‎05-16-2013 07:30 AM
<?php
// $Id: default.settings.php,v 1.51 2010/10/11 23:49:48 dries Exp $
* @file
* Drupal site-specific configuration file.
* IMPORTANT NOTE:
* This file may have been set to read-only by the Drupal installation
* program. If you make changes to this file, be sure to protect it again
* after making your modifications. Failure to remove write permissions
* to this file is a security risk.
* The configuration file to be loaded is based upon the rules below.
* The configuration directory will be discovered by stripping the
* website's hostname from left to right and pathname from right to
* left. The first configuration file found will be used and any
* others will be ignored. If no other configuration file is found
* then the default configuration file at 'sites/default' will be used.
* For example, for a fictitious site installed at
* http://www.drupal.org/mysite/test/, the 'settings.php'
* is searched in the following directories:
* 1. sites/www.drupal.org.mysite.test
* 2. sites/drupal.org.mysite.test
* 3. sites/org.mysite.test
* 4. sites/www.drupal.org.mysite
* 5. sites/drupal.org.mysite
* 6. sites/org.mysite
* 7. sites/www.drupal.org
* 8. sites/drupal.org
* 9. sites/org
* 10. sites/default
* If you are installing on a non-standard port number, prefix the
* hostname with that number. For example,
* http://www.drupal.org:8080/mysite/test/ could be loaded from
* sites/8080.www.drupal.org.mysite.test/.
* Database settings:
* The $databases array specifies the database connection or
* connections that Drupal may use. Drupal is able to connect
* to multiple databases, including multiple types of databases,
* during the same request.
* Each database connection is specified as an array of settings,
* similar to the following:
* @code
* array(
* 'driver' => 'mysql',
* 'database' => 'databasename',
* 'username' => 'username',
* 'password' => 'password',
* 'host' => 'localhost',
* 'port' => 3306,
* 'prefix' => 'myprefix_',
* 'collation' => 'utf8_general_ci',
* @endcode
* The "driver" property indicates what Drupal database driver the
* connection should use. This is usually the same as the name of the
* database type, such as mysql or sqlite, but not always. The other
* properties will vary depending on the driver. For SQLite, you must
* specify a database file name in a directory that is writable by the
* webserver. For most other drivers, you must specify a
* username, password, host, and database name.
* Some database engines support transactions. In order to enable
* transaction support for a given database, set the 'transactions' key
* to TRUE. To disable it, set it to FALSE. Note that the default value
* varies by driver. For MySQL, the default is FALSE since MyISAM tables
* do not support transactions.
* For each database, you may optionally specify multiple "target" databases.
* A target database allows Drupal to try to send certain queries to a
* different database if it can but fall back to the default connection if not.
* That is useful for master/slave replication, as Drupal may try to connect
* to a slave server when appropriate and if one is not available will simply
* fall back to the single master server.
* The general format for the $databases array is as follows:
* @code
* $databases['default']['default'] = $info_array;
* $databases['default']['slave'][] = $info_array;
* $databases['extra']['default'] = $info_array;
* @endcode
* In the above example, $info_array is an array of settings described above.
* The first line sets a "default" database that has one master database
* (the second level default). The second and third lines create an array
* of potential slave databases. Drupal will select one at random for a given
* request as needed. The fourth line creates a new database with a name of
* "extra".
* For a single database configuration, the following is sufficient:
* @code
* $databases['default']['default'] = array(
* 'prefix' => 'main_',
* @endcode
* You can optionally set prefixes for some or all database table names
* by using the 'prefix' setting. If a prefix is specified, the table
* name will be prepended with its value. Be sure to use valid database
* characters only, usually alphanumeric and underscore. If no prefixes
* are desired, leave it as an empty string ''.
* To have all database names prefixed, set 'prefix' as a string:
* @code
* @endcode
* To provide prefixes for specific tables, set 'prefix' as an array.
* The array's keys are the table names and the values are the prefixes.
* The 'default' element is mandatory and holds the prefix for any tables
* not specified elsewhere in the array. Example:
* @code
* 'prefix' => array(
* 'default' => 'main_',
* 'users' => 'shared_',
* 'sessions' => 'shared_',
* 'role' => 'shared_',
* 'authmap' => 'shared_',
* @endcode
* You can also use a reference to a schema/database as a prefix. This maybe
* useful if your Drupal installation exists in a schema that is not the default
* or you want to access several databases from the same code base at the same
* time.
* Example:
* @code
* 'default' => 'main.',
* 'users' => 'shared.',
* 'sessions' => 'shared.',
* 'role' => 'shared.',
* 'authmap' => 'shared.',
* @endcode
* NOTE: MySQL and SQLite's definition of a schema is a database.
* Database configuration format:
* @code
* 'prefix' => '',
* 'driver' => 'pgsql',
* 'prefix' => '',
* 'driver' => 'sqlite',
* 'database' => '/path/to/databasefilename',
* @endcode
$databases = array();
require_once('dbconfig.php');
* Access control for update.php script.
* If you are updating your Drupal installation using the update.php script but
* are not logged in using either an account with the "Administer software
* updates" permission or the site maintenance account (the account that was
* created during installation), you will need to modify the access check
* statement below. Change the FALSE to a TRUE to disable the access check.
* After finishing the upgrade, be sure to open this file again and change the
* TRUE back to a FALSE!
$update_free_access = FALSE;
* Salt for one-time login links and cancel links, form tokens, etc.
* This variable will be set to a random value by the installer. All one-time
* login links will be invalidated if the value is changed. Note that this
* variable must have the same value on every web server. If this variable is
* empty, a hash of the serialized database credentials will be used as a
* fallback salt.
* For enhanced security, you may set this variable to a value using the
* contents of a file outside your docroot that is never saved together
* with any backups of your Drupal files and database.
* Example:
* $drupal_hash_salt = file_get_contents('/home/example/salt.txt');
$drupal_hash_salt = '';
* Base URL (optional).
* If Drupal is generating incorrect URLs on your site, which could
* be in HTML headers (links to CSS and JS files) or visible links on pages
* (such as in menus), uncomment the Base URL statement below (remove the
* leading hash sign) and fill in the absolute URL to your Drupal installation.
* You might also want to force users to use a given domain.
* See the .htaccess file for more information.
* Examples:
* $base_url = 'http://www.example.com';
* $base_url = 'http://www.example.com:8888';
* $base_url = 'http://www.example.com/drupal';
* $base_url = 'https://www.example.com:8888/drupal';
* It is not allowed to have a trailing slash; Drupal will add it
* for you.
# $base_url = 'http://www.example.com'; // NO trailing slash!
if (file_exists('baseurl.php'))
include_once('baseurl.php');
* Cron Key (optional).
* A cron key is generated at installation time to secure access to the cron.php
* maintenance script. Debian package automatically executes the cron script for
* each installed sites in drupal7. To complete setup a $cron_key variable must be
* defined here or in a cronkey.php file.
* Example:
* $cron_key = '<cron_key>';
# $cron_key = '<cron_key>';
* PHP settings:
* To see what PHP settings are possible, including whether they can be set at
* runtime (by using ini_set()), read the PHP documentation:
* http://www.php.net/manual/en/ini.list.php
* See drupal_initialize_variables() in includes/bootstrap.inc for required
* runtime settings and the .htaccess file for non-runtime settings. Settings
* defined there should not be duplicated here so as to avoid conflict issues.
* Some distributions of Linux (most notably Debian) ship their PHP
* installations with garbage collection (gc) disabled. Since Drupal depends on
* PHP's garbage collection for clearing sessions, ensure that garbage
* collection occurs by using the most common settings.
ini_set('session.gc_probability', 1);
ini_set('session.gc_divisor', 100);
* Set session lifetime (in seconds), i.e. the time from the user's last visit
* to the active session may be deleted by the session garbage collector. When
* a session is deleted, authenticated users are logged out, and the contents
* of the user's $_SESSION variable is discarded.
ini_set('session.gc_maxlifetime', 200000);
* Set session cookie lifetime (in seconds), i.e. the time from the session is
* created to the cookie expires, i.e. when the browser is expected to discard
* the cookie. The value 0 means "until the browser is closed".
ini_set('session.cookie_lifetime', 2000000);
* If you encounter a situation where users post a large amount of text, and
* the result is stripped out upon viewing but can still be edited, Drupal's
* output filter may not have sufficient memory to process it. If you
* experience this issue, you may wish to uncomment the following two lines
* and increase the limits of these variables. For more information, see
* http://php.net/manual/en/pcre.configuration.php.
# ini_set('pcre.backtrack_limit', 200000);
# ini_set('pcre.recursion_limit', 200000);
* Drupal automatically generates a unique session cookie name for each site
* based on on its full domain name. If you have multiple domains pointing at
* the same Drupal site, you can either redirect them all to a single domain
* (see comment in .htaccess), or uncomment the line below and specify their
* shared base domain. Doing so assures that users remain logged in as they
* cross between your various domains.
# $cookie_domain = 'example.com';
* Variable overrides:
* To override specific entries in the 'variable' table for this site,
* set them here. You usually don't need to use this feature. This is
* useful in a configuration file for a vhost or directory, rather than
* the default settings.php. Any configuration setting from the 'variable'
* table can be given a new value. Note that any values you provide in
* these variable overrides will not be modifiable from the Drupal
* administration interface.
* The following overrides are examples:
* - site_name: Defines the site's name.
* - theme_default: Defines the default theme for this site.
* - anonymous: Defines the human-readable name of anonymous users.
* Remove the leading hash signs to enable.
# $conf['site_name'] = 'My Drupal site';
# $conf['theme_default'] = 'garland';
# $conf['anonymous'] = 'Visitor';
* A custom theme can be set for the offline page. This applies when the site
* is explicitly set to maintenance mode through the administration page or when
* the database is inactive due to an error. It can be set through the
* 'maintenance_theme' key. The template file should also be copied into the
* theme. It is located inside 'modules/system/maintenance-page.tpl.php'.
* Note: This setting does not apply to installation and update pages.
# $conf['maintenance_theme'] = 'bartik';
* Enable this setting to determine the correct IP address of the remote
* client by examining information stored in the X-Forwarded-For headers.
* X-Forwarded-For headers are a standard mechanism for identifying client
* systems connecting through a reverse proxy server, such as Squid or
* Pound. Reverse proxy servers are often used to enhance the performance
* of heavily visited sites and may also provide other site caching,
* security or encryption benefits. If this Drupal installation operates
* behind a reverse proxy, this setting should be enabled so that correct
* IP address information is captured in Drupal's session management,
* logging, statistics and access management systems; if you are unsure
* about this setting, do not have a reverse proxy, or Drupal operates in
* a shared hosting environment, this setting should remain commented out.
# $conf['reverse_proxy'] = TRUE;
* Set this value if your proxy server sends the client IP in a header other
* than X-Forwarded-For.
* The "X-Forwarded-For" header is a comma+space separated list of IP addresses,
* only the last one (the left-most) will be used.
# $conf['reverse_proxy_header'] = 'HTTP_X_CLUSTER_CLIENT_IP';
* reverse_proxy accepts an array of IP addresses.
* Each element of this array is the IP address of any of your reverse
* proxies. Filling this array Drupal will trust the information stored
* in the X-Forwarded-For headers only if Remote IP address is one of
* these, that is the request reaches the web server from one of your
* reverse proxies. Otherwise, the client could directly connect to
* your web server spoofing the X-Forwarded-For headers.
# $conf['reverse_proxy_addresses'] = array('a.b.c.d', …);
* Page caching:
* By default, Drupal sends a "Vary: Cookie" HTTP header for anonymous page
* views. This tells a HTTP proxy that it may return a page from its local
* cache without contacting the web server, if the user sends the same Cookie
* header as the user who originally requested the cached page. Without "Vary:
* Cookie", authenticated users would also be served the anonymous page from
* the cache. If the site has mostly anonymous users except a few known
* editors/administrators, the Vary header can be omitted. This allows for
* better caching in HTTP proxies (including reverse proxies), i.e. even if
* clients send different cookies, they still get content served from the cache
* if aggressive caching is enabled and the minimum cache time is non-zero.
* However, authenticated users should access the site directly (i.e. not use an
* HTTP proxy, and bypass the reverse proxy if one is used) in order to avoid
* getting cached pages from the proxy.
# $conf['omit_vary_cookie'] = TRUE;
* CSS/JS aggregated file gzip compression:
* By default, when CSS or JS aggregation and clean URLs are enabled Drupal will
* store a gzip compressed (.gz) copy of the aggregated files. If this file is
* available then rewrite rules in the default .htaccess file will serve these
* files to browsers that accept gzip encoded content. This allows pages to load
* faster for these users and has minimal impact on server load. If you are
* using a webserver other than Apache httpd, or a caching reverse proxy that is
* configured to cache and compress these files itself you may want to uncomment
* one or both of the below lines, which will prevent gzip files being stored.
# $conf['css_gzip_compression'] = FALSE;
# $conf['js_gzip_compression'] = FALSE;
* String overrides:
* To override specific strings on your site with or without enabling locale
* module, add an entry to this list. This functionality allows you to change
* a small number of your site's default English language interface strings.
# $conf['locale_custom_strings_en'][''] = array(
# 'forum' => 'Discussion board',
# '@count min' => '@count minutes',
* IP blocking:
* To bypass database queries for denied IP addresses, use this setting.
* Drupal queries the {blocked_ips} table by default on every page request
* for both authenticated and anonymous users. This allows the system to
* block IP addresses from within the administrative interface and before any
* modules are loaded. However on high traffic websites you may want to avoid
* this query, allowing you to bypass database access altogether for anonymous
* users under certain caching configurations.
* If using this setting, you will need to add back any IP addresses which
* you may have blocked via the administrative interface. Each element of this
* array represents a blocked IP address. Uncommenting the array and leaving it
* empty will have the effect of disabling IP blocking on your site.
# $conf['blocked_ips'] = array(
# 'a.b.c.d',
* Authorized file system operations:
* The Update manager module included with Drupal provides a mechanism for
* site administrators to securely install missing updates for the site
* directly through the web user interface by providing either SSH or FTP
* credentials. This allows the site to update the new files as the user who
* owns all the Drupal files, instead of as the user the webserver is running
* as. However, some sites might wish to disable this functionality, and only
* update the code directly via SSH or FTP themselves. This setting completely
* disables all functionality related to these authorized file operations.
* Remove the leading hash signs to disable.
'default' => array
'user' => 'admin',
'url' => 'http://10.54.81.43:8080/alfresco/service/cmis'
‎05-17-2013 03:27 AM
Are you trying to add content in Alfresco from Drupal?
Just wanted to confirm if your Alfresco admin user password is 'alfresco'?
‎05-17-2013 05:05 AM
No, when I enter http://10.54.81.43/drupal7/?q=alfresco/browser, there is a never ending initialization page!
here is the screenshot…
http://thealfrescoblog.wordpress.com/?attachment_id=168
but seems like this initialization never completes, it keeps on loading!
And to your other questions, I am trying to add content 'Alfresco item' in drupal.
And yeah, the admin password is 'alfresco'.
What else could be missing? We are clueless over this issue.
‎05-17-2013 05:24 AM
Please install the recommended release 7.x-1.2 and let me if it works.
http://drupal.org/node/1118770
‎05-17-2013 08:05 AM
Our issue is resolved. We had to use Drupal 6 in order to go for recommended version of alfresco module.
Thanks alot for your help.
