When I try to start the virtual tomcat, I'm seeing some errors in the log.
There seems to be a problem binding port 50500. It's a clean machine. I don't have anything using port 50500.
But I do see 50500 referenced in the standard tomcat distributed with the alfresco/tomcat bundle.
Do I need to change 50500 to something else in the virtual tomcat configuration files – I see quite a few files where it is referenced?
The virtual tomcat's configuration already has changed standard tomcat ports like 8080 to 8180, so I thought that the configuration within virtual tomcat on download is probably intentional.
Any idea about what could be wrong?
Thu Mar 13 06:31:50 PDT 2008 Starting Alfresco …
06:33:43,052 WARN [org.springframework.remoting.rmi.RmiRegistryFactoryBean] Could not detect RMI registry - creating new one
06:33:48,069 ERROR [org.springframework.web.context.ContextLoader] Context initialization failed
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'serverConnector' defined in class path resource [alfresco/core-services-context.xml]: Invocation of init method failed; nested exception is java.io.IOException: Cannot bind to URL [rmi://localhost:50500/alfresco/jmxrmi]: javax.naming.NameAlreadyBoundException: alfresco/jmxrmi [Root exception is java.rmi.AlreadyBoundException: alfresco/jmxrmi]
Caused by: java.io.IOException: Cannot bind to URL [rmi://localhost:50500/alfresco/jmxrmi]: javax.naming.NameAlreadyBoundException: alfresco/jmxrmi [Root exception is java.rmi.AlreadyBoundException: alfresco/jmxrmi]
at javax.management.remote.rmi.RMIConnectorServer.newIOException(RMIConnectorServer.java:804)
at javax.management.remote.rmi.RMIConnectorServer.start(RMIConnectorServer.java:417)
at org.springframework.jmx.support.ConnectorServerFactoryBean.afterPropertiesSet(ConnectorServerFactoryBean.java:168)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeInitMethods(AbstractAutowireCapableBeanFactory.java:1118)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1085)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:429)
at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:250)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:141)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:247)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:161)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:270)
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:346)
Caused by: javax.naming.NameAlreadyBoundException: alfresco/jmxrmi [Root exception is java.rmi.AlreadyBoundException: alfresco/jmxrmi]
at com.sun.jndi.rmi.registry.RegistryContext.bind(RegistryContext.java:122)
at com.sun.jndi.toolkit.url.GenericURLContext.bind(GenericURLContext.java:208)
at javax.naming.InitialContext.bind(InitialContext.java:400)
at javax.management.remote.rmi.RMIConnectorServer.bind(RMIConnectorServer.java:625)
at javax.management.remote.rmi.RMIConnectorServer.start(RMIConnectorServer.java:412)
… 38 more
Caused by: java.rmi.AlreadyBoundException: alfresco/jmxrmi
at sun.rmi.registry.RegistryImpl.bind(RegistryImpl.java:123)
at sun.rmi.registry.RegistryImpl_Skel.dispatch(Unknown Source)
at sun.rmi.server.UnicastServerRef.oldDispatch(UnicastServerRef.java:386)
at sun.rmi.server.UnicastServerRef.dispatch(UnicastServerRef.java:250)
at sun.rmi.transport.Transport$1.run(Transport.java:159)
at sun.rmi.transport.Transport.serviceCall(Transport.java:155)
at sun.rmi.transport.tcp.TCPTransport.handleMessages(TCPTransport.java:535)
at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run0(TCPTransport.java:790)
at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run(TCPTransport.java:649)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:885)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:907)
at sun.rmi.transport.StreamRemoteCall.exceptionReceivedFromServer(StreamRemoteCall.java:255)
at sun.rmi.transport.StreamRemoteCall.executeCall(StreamRemoteCall.java:233)
at sun.rmi.server.UnicastRef.invoke(UnicastRef.java:359)
at sun.rmi.registry.RegistryImpl_Stub.bind(Unknown Source)
at com.sun.jndi.rmi.registry.RegistryContext.bind(RegistryContext.java:120)
… 42 more
06:33:48,071 ERROR [org.apache.catalina.core.ContainerBase.[Catalina].[localhost].[/alfresco]] Exception sending context initialized event to listener instance of class org.springframework.web.context.ContextLoaderListener
… 38 more
… 42 more
06:33:48,073 ERROR [org.apache.catalina.core.ContainerBase.[Catalina].[localhost].[/alfresco]] Exception sending context initialized event to listener instance of class org.alfresco.web.app.ContextListener
… 38 more
… 42 more
06:33:54,603 INFO [org.alfresco.repo.domain.schema.SchemaBootstrap] Schema managed by database dialect org.hibernate.dialect.MySQLInnoDBDialect.
06:33:55,952 INFO [org.alfresco.repo.domain.schema.SchemaBootstrap] No changes were made to the schema.
06:34:02,731 INFO [org.alfresco.repo.admin.ConfigurationChecker] The Alfresco root data directory ('dir.root') is: /var/lib/alfresco/alf_data
06:34:02,759 INFO [org.alfresco.repo.admin.patch.PatchExecuter] Checking for patches to apply …
06:34:03,669 INFO [org.alfresco.repo.module.ModuleServiceImpl] Found 0 module(s).
06:34:08,919 ERROR [org.alfresco.smb.protocol] Failed to get local domain/workgroup name, using default of WORKGROUP
06:34:08,919 ERROR [org.alfresco.smb.protocol] (This may be due to firewall settings or incorrect <broadcast> setting)
06:34:09,553 INFO [org.alfresco.service.descriptor.DescriptorService] Alfresco JVM - v1.6.0_03-b05; maximum heap size 506.313MB
06:34:09,554 INFO [org.alfresco.service.descriptor.DescriptorService] Alfresco started (Community Network): Current version 2.9.0 (B 683) schema 116 - Installed version 2.9.0 (B 683) schema 116
Thu Mar 13 06:58:21 PDT 2008 Stopping Alfresco …
