02-03-2010 09:51 AM
02-04-2010 05:18 PM
InnoDB: The log sequence number in ibdata files does not match
InnoDB: the log sequence number in the ib_logfiles!
100204 20:34:40 InnoDB: Database was not shut down normally!
InnoDB: Starting crash recovery.
InnoDB: Reading tablespace information from the .ibd files…
InnoDB: Restoring possible half-written data pages from the doublewrite
InnoDB: buffer…
100204 20:34:42 InnoDB: Started; log sequence number 0 3740772
100204 20:34:43 [Note] Event Scheduler: Loaded 0 events
100204 20:34:43 [Note] C:\ProgExtr\Alfresco\mysql\bin\mysqld: ready for connections.
Version: '5.1.35-community' socket: '' port: 3306 MySQL Community Server (GPL
)And also, in another window named Tomcat (with a Java icon)
04-Feb-2010 20:34:48 org.apache.coyote.http11.Http11Protocol init
04-Feb-2010 20:34:49 org.apache.catalina.startup.Catalina load
INFO: Initialization processed in 3209 ms
04-Feb-2010 20:34:49 org.apache.catalina.core.StandardService start
04-Feb-2010 20:34:49 org.apache.catalina.core.StandardEngine start
04-Feb-2010 20:35:01 org.apache.catalina.core.StandardContext addApplicationList
ener
INFO: The listener "org.apache.myfaces.webapp.StartupServletContextListener" is
already configured for this context. The duplicate definition has been ignored.
20:35:28,012 INFO [alfresco.config.JndiPropertiesFactoryBean] Loading properti
es file from class path resource [alfresco/repository.properties]
20:35:28,050 INFO [alfresco.config.JndiPropertiesFactoryBean] Loading properti
es file from class path resource [alfresco/domain/transaction.properties]
es file from URL [file:/C:/ProgExtr/Alfresco/tomcat/shared/classes/alfresco-glob
al.properties]
20:35:28,757 INFO [alfresco.config.JndiPropertyPlaceholderConfigurer] Loading
properties file from class path resource [alfresco/alfresco-shared.properties]
20:37:26,600 INFO [domain.schema.SchemaBootstrap] Schema managed by database d
ialect org.hibernate.dialect.MySQLInnoDBDialect.
20:37:39,370 INFO [domain.schema.SchemaBootstrap] No changes were made to the
schema.
20:37:44,029 INFO [management.subsystems.ChildApplicationContextFactory] Start
ing 'sysAdmin' subsystem, ID: [sysAdmin, default]
20:37:44,463 INFO [alfresco.config.JndiPropertyPlaceholderConfigurer] Loading
20:37:44,578 INFO [management.subsystems.ChildApplicationContextFactory] Start
up of 'sysAdmin' subsystem, ID: [sysAdmin, default] complete
20:37:51,777 User:System INFO [management.subsystems.ChildApplicationContextFac
tory] Starting 'thirdparty' subsystem, ID: [thirdparty, default]
20:37:51,889 User:System INFO [alfresco.config.JndiPropertyPlaceholderConfigure
r] Loading properties file from class path resource [alfresco/alfresco-shared.pr
operties]
20:37:57,965 User:System WARN [alfresco.util.OpenOfficeConnectionTester] An ini
tial OpenOffice connection could not be established.
20:37:57,983 User:System INFO [management.subsystems.ChildApplicationContextFac
tory] Startup of 'thirdparty' subsystem, ID: [thirdparty, default] complete
20:39:56,875 INFO [repo.admin.ConfigurationChecker] The Alfresco root data dir
ectory ('dir.root') is: C:\ProgExtr\Alfresco\alf_data
20:39:57,121 INFO [admin.patch.PatchExecuter] Checking for patches to apply ..
20:40:04,169 INFO [admin.patch.PatchExecuter] Applying patch 'patch.wc
mFolders' (Ensures the existance of the WCM specific 'Web Projects' and 'Web For
ms' folders.).
20:40:05,866 INFO [admin.patch.PatchExecuter]
=== Applied patch ===
RESULT:
Script completed
20:40:05,868 INFO [admin.patch.PatchExecuter]
RESULT:
Script completed
20:40:05,873 INFO [admin.patch.PatchExecuter]
RESULT:
Script completed
20:40:05,876 INFO [admin.patch.PatchExecuter]
RESULT:
Script completed
20:40:05,880 INFO [admin.patch.PatchExecuter]
RESULT:
Script completed
RESULT:
Script completed
20:40:05,882 INFO [admin.patch.PatchExecuter]
RESULT:
The Web Projects folder was successfully created: workspace://SpacesStore/4d8d69
58-768b-4393-ba5a-dea73178c28d
The Web Forms folder was successfully created: workspace://SpacesStore/4d8d6958-
20:40:05,916 User:System INFO [repo.module.ModuleServiceImpl] Found 0 module(s)
20:40:05,978 INFO [management.subsystems.ChildApplicationContextFactory] Start
ing 'fileServers' subsystem, ID: [fileServers, default]
20:40:06,075 INFO [alfresco.config.JndiPropertyPlaceholderConfigurer] Loading
20:40:07,536 INFO [management.subsystems.ChildApplicationContextFactory] Start
ing 'Authentication' subsystem, ID: [Authentication, managed, alfrescoNtlm1]
20:40:07,653 INFO [alfresco.config.JndiPropertyPlaceholderConfigurer] Loading
20:40:08,200 INFO [management.subsystems.ChildApplicationContextFactory] Start
up of 'Authentication' subsystem, ID: [Authentication, managed, alfrescoNtlm1] c
omplete
20:40:08,542 INFO [management.subsystems.ChildApplicationContextFactory] Start
up of 'fileServers' subsystem, ID: [fileServers, default] complete
20:40:08,543 INFO [management.subsystems.ChildApplicationContextFactory] Start
ing 'imap' subsystem, ID: [imap, default]
20:40:08,693 INFO [alfresco.config.JndiPropertyPlaceholderConfigurer] Loading
20:40:09,184 INFO [management.subsystems.ChildApplicationContextFactory] Start
up of 'imap' subsystem, ID: [imap, default] complete
20:40:09,203 INFO [repo.usage.UserUsageTrackingComponent] Enabled - calculate
missing user usages …
20:40:09,472 INFO [repo.usage.UserUsageTrackingComponent] Found 0 users to rec
alculate
20:40:09,491 INFO [repo.usage.UserUsageTrackingComponent] … calculated missi
ng usages for 0 users
20:40:09,563 INFO [management.subsystems.ChildApplicationContextFactory] Start
ing 'Synchronization' subsystem, ID: [Synchronization, default]
20:40:09,700 INFO [alfresco.config.JndiPropertyPlaceholderConfigurer] Loading
20:40:10,140 INFO [management.subsystems.ChildApplicationContextFactory] Start
up of 'Synchronization' subsystem, ID: [Synchronization, default] complete
20:40:10,858 INFO [alfresco.util.OpenOfficeConnectionTester] The OpenOffice co
nnection was re-established.
20:40:12,717 INFO [service.descriptor.DescriptorService] Alfresco JVM - v1.6.0
_16-b01; maximum heap size 506.313MB
20:40:12,749 INFO [service.descriptor.DescriptorService] Alfresco started (Com
munity): Current version 3.2.0 (r2 2440) schema 3300 - Originally installed vers
20:42:29,853 INFO [management.subsystems.ChildApplicationContextFactory] Start
ing 'wcm_deployment_receiver' subsystem, ID: [wcm_deployment_receiver, default]
20:42:31,193 INFO [alfresco.config.JndiPropertyPlaceholderConfigurer] Loading
20:42:32,898 INFO [management.subsystems.ChildApplicationContextFactory] Start
up of 'wcm_deployment_receiver' subsystem, ID: [wcm_deployment_receiver, default
] complete
04-Feb-2010 20:42:41 org.apache.catalina.startup.HostConfig deployWAR
INFO: Deploying web application archive mobile.war
20:42:52,606 INFO [alfresco.config.JBossEnabledWebApplicationContext] Refreshi
ng org.alfresco.config.JBossEnabledWebApplicationContext@19caef8: display name [
Root WebApplicationContext]; startup date [Thu Feb 04 20:42:52 GMT 2010]; root o
f context hierarchy
20:42:54,856 INFO [alfresco.config.JBossEnabledWebApplicationContext] Bean fac
tory for application context [org.alfresco.config.JBossEnabledWebApplicationCont
ext@19caef8]: org.springframework.beans.factory.support.DefaultListableBeanFacto
ry@1d6ff0e
20:43:00,967 INFO [web.scripts.DeclarativeRegistry] Registered 22 Web Scripts
(+0 failed), 24 URLs
20:43:01,376 INFO [web.scripts.AbstractRuntimeContainer] Initialised Presentat
ion Web Script Container (in 1420.5596ms)
20:43:01,872 INFO [web.scripts.DeclarativeRegistry] Registered 40 Web Scripts
(+0 failed), 42 URLs
20:43:01,920 INFO [web.scripts.AbstractRuntimeContainer] Initialised WebFramew
ork Web Script Container (in 443.9313ms)
20:43:02,145 INFO [web.site.FrameworkHelper] Successfully Initialized Web Fram
ework
04-Feb-2010 20:43:02 org.apache.catalina.startup.HostConfig deployWAR
INFO: Deploying web application archive share.war
20:43:51,030 INFO [web.site.FrameworkHelper] Successfully Initialized Web Fram
ework
04-Feb-2010 20:43:54 org.apache.coyote.http11.Http11Protocol start
04-Feb-2010 20:43:54 org.apache.catalina.startup.Catalina start
INFO: Server startup in 545490 msThis window keept adding lines for some time.Weird that this file is refering to ~dp0alfresco.bat. Is there an alfresco.bat? Whats in the alfresco.bat the alf_start.bat refers to?This is the content of the alfresco.bat file:
@echo off
rem —————————————————————————
rem Start script for the Alfresco Server
rem set Alfresco home (includes trailing \ e.g. c:\alfresco\)
set ALF_HOME=%~dps0
set CATALINA_HOME=%ALF_HOME%tomcat
rem Set any default JVM options
set JAVA_OPTS=-Xms128m -Xmx512m -Xss96k -XX:MaxPermSize=160m -server -Dalfresco.home=%ALF_HOME% -Dcom.sun.management.jmxremote
rem — If SetPaths.bat already exists - assume set by hand and use as is
set PATH=%ALF_HOME%bin;%PATH%
if not exist "SetPaths.bat" goto getpaths
call SetPaths.bat
goto start
:getpaths
call RegPaths.exe
call SetPaths.bat
del SetPaths.bat
:start
rem — Test for Java settings
set BASEDIR=%CATALINA_HOME%
rem — Reset errorlevel hack
verify >nul
call "%CATALINA_HOME%\bin\setclasspath.bat"
if errorlevel 1 goto error
set PATH=%JAVA_HOME%\bin;%PATH%
rem —————————————
rem Start Components
rem —————————————
if not ""%1"" == ""start"" goto stop
if not exist "%ALF_HOME%mysql\my.ini" goto tomcat
rem —————————————
rem Start MySQL
rem —————————————
echo Starting MySQL…
start "MySQL" "%ALF_HOME%mysql\bin\mysqld" –defaults-file="%ALF_HOME%mysql\my.ini" –basedir="%ALF_HOME%mysql" –datadir="%ALF_HOME%alf_data\mysql" –console
rem Uncomment below to pause for some seconds before starting Tomcat
rem Change 5 to the number of seconds delay required
rem ping 1.0.0.0 -n 5 -w 1000 >NUL
:tomcat
rem —————————————
rem Start Tomcat
rem —————————————
echo Starting Tomcat…
call "%CATALINA_HOME%\bin\startup.bat"
rem ———————————
rem Start Virtualization if available
rem ———————————
rem if exist "~dp0virtual_start.bat" call "~dp0virtual_start.bat"
goto end
:stop
rem —————————————
rem Stop Components
rem —————————————
if not ""%1"" == ""stop"" goto nostop
echo Shutting down Tomcat…
call "%CATALINA_HOME%\bin\shutdown.bat"
if not exist "%ALF_HOME%mysql\my.ini" goto nextstop
if ""%2"" == ""nouser"" goto tomcatwait
set /P pause="Please wait until Tomcat has shut down, then press ENTER to continue…"
goto stopmysql
:tomcatwait
rem Change 10 to the number of seconds delay required
ping 1.0.0.0 -n 10 -w 1000 >NUL
:stopmysql
echo Stopping MySQL…
call "%ALF_HOME%mysql\bin\mysqladmin" -u root shutdown
:nextstop
rem if exist "virtual_start.bat" call virtual_stop.bat
goto end
:error
echo Error encountered.
if ""%2"" == ""nouser"" goto end
set /P pause="Press ENTER to continue…"
:endI fail to understand whatever happened, but it seems it is working now because after I tried the link I have been talking about since the beginning and it displayed a log in window in the browser. Then I clicked the Alfresco Explorer on the start menu and it also displayed.02-05-2010 03:56 AM
02-05-2010 09:15 PM
12-03-2010 01:21 AM
04-05-2011 09:54 AM
same for me. I'm not very good at this sort of things and I don't really know what to do (or even what to check). Can someone please help? thank you in dvance
04-11-2011 09:31 AM
